Question about Brother MFC 240C All-In-One InkJet Printer
Date I would love to know how to change the date on my MFC-240C printer. Every time I fax an item the transmission verification report has the wrong date. Please help me.
  • 434 Answers
You can set the date and time from the control panel:
1) Press <Menu>
2) Press arrows select "Initial Setup" Press <OK>
3) Press arrows select "Date and Time" Press <OK>
4) Use numbers to enter year - last two digits <OK>
5) Use numbers for month, <OK>
6) Use numbers for day, <OK>
7) Use numbers for time - 24 hour format, press <OK>
8) Press <Stop/Exit> to return to normal function
Posted on Feb 02, 2010
Hi could you tell me how to print the report for sending please to keep as proof to a number it was sent
Customizing the Transmission Verification Report You can use the Transmission Report as proof that you sent a fax. This report lists the time and date of transmission and whether the transmission was successful (OK). If you select On or On+Image, the report will print for every fax you send. If you send a lot of faxes to the same place, you may need more than the job numbers to know which faxes you must send again. Selecting On+Image or Off+Image will print a section of the fax's first page on the report to help you remember. NOTE:When the Verification Report is turned Off or Off+Image, the Report will only print if there is a transmission error, with NG in the RESULT column. 1 Press Menu/Set, 2, 4, 1. 2 Press ? or ? to select Off+Image, On, On+Image or Off. Press Menu/Set. 3 Press Stop/Exit.
Jul 21, 2011 | Brother MFC-620CN All-In-One InkJet...
Fax transmission reports
What you are explaining should work. If you need prior activity reports from previous faxes, you can press Function then 2 (Act. Report)
I think you might need to press Function, then 7 then 1
From the manual:
Transmission Verification (Xmit) Report You can use the Xmit Report as proof that you sent a fax. This report lists
the time and date of transmission, and whether the transmission was successful.
When the feature is OFF, the report is printed automatically only if an error occurred during transmission. If the report indicates NG, send the document again. If the report indicates you should check the readability of certain pages, resend those pages.
If you typically send multiple faxes to the same destinations, you may need a reminder to identify each fax transmission. You can select OFF+IMAGE or ON+IMAGE to print a portion of the first page of the fax message on the report.
1 For the FAX, press Function , 7 , 1 .
For the MFC, press Function , 1 , 7 , 1 .
2 Press or to select OFF, OFF+IMAGE, ON or ON+IMAGE and press Set .
3 Press Stop to exit.
Hope this helps you.
Mike
Nov 14, 2007 | Brother MFC 8300 Laser Printer
HOW TO PRINT FAX CONFIRMATIN PAGE MFC440CN
To print fax send confirmation report:
You can use the Transmission Verification Report as proof that you sent a fax. This
(OK). If you choose On or On+Image, the report will print for every fax you send.
Choosing On+Image or Off+Image will print a section of the fax's first page on the report
When the Transmission Verification Report is turned Off or Off+Image, the Report will
Apr 12, 2011 | Brother MultiFunction Center MFC-440CN...
HOW TO PRINT CONFIRMATION PAGE
Apr 12, 2011 | Brother MFC 420CN All-In-One InkJet...
Need fax confirmation report .
1) Press <Menu>
2) Press Up or Down <Arrow key> to select "Fax"
3) Press <OK>
4) Press Up or Down <Arrow key> to select "Report Setting"
5) Press <OK>
6) Press Up or Down <Arrow key> to select "Transmission" or "XMIT Report"
7) Press <OK>
8) Press Up or Down <Arrow key> until the option you prefer appears:
  • OFF - Transmission verification report will print only if a fax is unsuccessful
  • OFF+IMAGE - Transmission verification report will print if a fax is unsuccessful with a portion of the fax first page
  • ON - Transmission verification report will print after every fax transmission
  • ON+IMAGE - Transmission verification report will print after every fax transmission with a portion of the fax first page
9) Press <OK>
10) Press <Stop/Exit>
I hope this helps!
Jan 15, 2010 | Brother Multi-Function Center MFC-240C...
Can't figure out how to reset date/time/header information on faxes & reports.
After you change to fax mode, press menu and then general setup for the date and time. After that you scroll down to fax setup to change the header.
Oct 16, 2009 | Brother Multi-Function Center MFC-240C...
Date and time is way off on fax header. How do we change it? Brother MFC-240C
While the fax mode light is lit, press menu and scroll down to general setup and enter, the date and time is one of the first settings. If you go to reports and print user settings the print is laid out the same as the menu structure like a roadmap to the different settings.
Change date & time on brother mfc-240c
click MENU-then click use the arrow keys down to go to "initial setup" AND CLICK ok THEN ARROW KEYS DOWN UNTIL YOU GET TO DATE/TIME and then you will be able to enter the year, month, day, click ok after each one is entered, and there you go, VERY EASY. GOOD LUCK
Mar 24, 2009 | Brother FAX 510 Thermal Printer
Avoid printing Transmission Verification Report
You have to change the fax menu settings. Here you can compute the machine to avoid the error reports (see manual chap. fax settings)
Jan 07, 2008 | Brother MFC 420CN All-In-One InkJet...
Confirmation print out
Your wanting what Brother calls a Transmission Verification
Report:
RESULT column.
a Press Menu, 2, 4, 1.
b Press a or b to choose Off+Image,
Press OK.
c Press Stop/Exit.
Nov 11, 2007 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC 240C All-In-One InkJet Printer Logo
194 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
