Question about Sloan M-101526-F42 Flushmate?® Complete Replacement System for FM IV 504
Air leak with Sloan Flushmate 501-B series. Tank
Tank fills with water over 10-15 flushes. Air bubbles can be seen coming from bottom of tank during flush.
  • 62 Answers
SOURCE: I have a Sloan Flushmate, Model #M-101526-F3. The
Absolutely not! Because these tanks have air pressure inside them, a leaking tank could explode with such force that the toilet can be destroyed and someone could get hurt. It does happen. Replace the flushmate tank is the only safe solution
Posted on Jul 11, 2009
  • 22 Answers
SOURCE: My sloan flushmate toil I think is backiing up.
You may have a leak in the discharge extension, lower supply, or drain valve. I suggest you call Flushmate's tech support line (on the Flushmate label) and see if they can help you out.
Good luck
Posted on Sep 24, 2009
bearsfan7538
  • 119 Answers
SOURCE: problem with flushmate m-101526-fnoe enough water
Did you replace the cylinder cartridge?
Posted on Dec 08, 2009
SOURCE: Regal Sloan Valve operates only intermittently
sloan manual valve will not flush unless water is run in sink next to toilet
Posted on Apr 22, 2010
heatman101
  • 43501 Answers
The only adjustment you can make is to crank your water pressure up...
But that probably will not solve your problem...
The best thing to do is to call the 800 number on the top of the tank and get technical assistance from them directly... they also will send you free parts if you need parts...
heatman101
Posted on Sep 08, 2010
I have a sloan toilet model M-101526/ it leaks out of top of tank when i flush it
Depending on the nature and source of the leak, it may be a maintenance issue or you may need to replace a component or the complete system.
You can find troubleshooting procedures, owner's manuals, etc., at www.flushmate.com.
For best results, jot down the serial number and toll-free phone number located on the Flushmate label and call Flushmate between 8:00 AM and 4:30 PM ET (Mon - Fri) for assistance.
Mar 18, 2013 | Sloan M-101526-F Flushmate?® Complete...
Hissing sound after flushing a flushmate
The washer that shuts the water off is failing. It shut stop incoming water completely when the tank is full.
Jan 11, 2013 | Sloan M-101526-F Flushmate?® Complete...
Flushmate 503 sprays water out of top of tank, apparently coming for under the flushmate system. The valve doesn't seem to leak. Iahve pressure tested it.
Turn off the water supply at the wall, flush the toilet to relieve the pressure inside the Flushmate, and call Flushmate Consumer Services at 800-533-3460 M-F, 8:00 - 4:30 ET.
They'll need to know the serial number and approximate date of installation of the Flushmate.
You could alos fill out a confidential "contact" form on the contact page of the Web site, www.flushmate.com.
If yu need to use the toilet in the meantime, you can "bucket flush" it by pouring 2 to 3 gallons of water into the bowl. This will generate a standard siphonic flush and won't give you the pressureized extractiopn but it will keep the toilet usable until a Flushmate support tech can diagnose the issue and provide a resolution.
Aug 17, 2011 | Sloan M-101526-F31 Flushmate?® Complete...
Cant find any thing in bowl ,replaced air tank drain is clear and still does not flush replaced bowl and flushes this is the 4th toilet with same problem cant find anything in any bowl we changed
Try turning off the water to the toilet, then old the handle down until you hear that all the
water has drained out of the tank. Then turn the water back on. Then take a cup of water
and put water on to the plunger on top of the tank. Check for air bubbles, if there are bubbles
then that is the problem. The tank MUST HAVE a certain amount of air in the top of the tank,
or it will not work at all. You might have to remove the plunger assembly and put some vaseline on the big O ring seals. To remove the plunger, take the screws off the stainless bent rod that goes
over the plunger, then remove the rod, or just move it out of the way. The plunger can be removed
by sticking the jaws of a pair of chanel lock "pump pliers", then grab the handles of the channel locks and turn the plunger assembly out.
Sometimes all you need to do is drain the tank down, and the toilet might work for a long time.
It's such an easy fix, a person really doesn't mind draining the tank.
Hope this helps
LeRoy Wolff , North Dakota master plumber # 8401
Nov 01, 2010 | Sloan M-101526-F Flushmate?® Complete...
I have a Sloan Flushmate mod M-101526-F3. It seems to be laking the pressure to flush away the waste completely. Is there an adjustment that I can make?
heatman101
Sep 08, 2010 | Sloan M-101526-F42 Flushmate?® Complete...
Flushmate doesn't activate at times, or runs very slowly. Can this be fixed with a replacement cartridge?
Yes!!! Call the 800 number that is on the top of the Flushmate inside the tank, and they will send you free replacement parts with easy installation instructions...
heatman101
Jun 23, 2010 | Sloan M-101526-F Flushmate?® Complete...
Sloan Flushmate M-101526-F3-Constant Filling
There is a lifetime warranty on the tank and a ten year warranty on parts. Call flushmate and ask. they will not tell you otherwise.
If you use any chemicals in the tank it will void the warranty.
Sep 25, 2009 | Sloan M-101526-F42 Flushmate?® Complete...
My model# is M-101526-F.I purchase unit 7/2000.When I try to flush,I don,t have the pressure that I normally get.I do see some water in the tank.I also need to shake the handle to stop the filling process...
Have you tried the "800" number on the Flushmate label? Loss of air pressure may mean there's a leak in the cartridge, air inducer valve, or possibly even the tank itself.
The handle-shaking thing typically means the handle and rod are binding up and holding the cartridge down after the flush or that you need to increase the clearance between the rod and cartridge cap.
Flushmate tech support should be able to help you identify the cause of the air loss and advise you on the cartridge cap adjustment.
You can also view some helpful videos at www.howto.flushmate.com.
Good luck.
Aug 12, 2009 | Sloan M-101526-F42 Flushmate?® Complete...
Absolutely not! Because these tanks have air pressure inside them, and you can hurt yourself or somebody else. You need to get new one... take a look here Amazon com Sloan Flushmate tank. I hope this was helpful. cheers
Jul 10, 2009 | Sloan M-101526-F42 Flushmate?® Complete...
Sloan M-101526-F42 Flushmate?® Complete Replacement System for FM IV 504 Logo
406 people viewed this question
Top Sloan Home Experts
richochet
ray gallant
Ted Maxwell
Are you a Sloan Home Expert? Answer questions, earn points and help others
