My magicolor 2530DL is giving me a Fatal Error Code 17H. Turning the machine off and back on clears the error but as soon as it tries to print one page I get the same result. What can I do to correct the problem. Thanks, Chuck
    President:
  • 2,306 Answers
It may just need a good cleaning, 17h says the cartridges are not rotating properly. You need to check that all toners are fully seated with no parts hanging out or pieces of protective materials from shipping are removed. If there was a jam it could be paper scraps inside or just toner buildup on the sensor for cart. rotation. Some refilled toners are overfilled and don't turn properly too. It's a general error that covers cartridge drive and rotation.
Posted on Feb 02, 2010
Model 2530DL - Fatal Error Code 08H - help!
Worcesterlad came up with this some time ago: it's not a solution but somewhere to investigate:
Error 08 relates to the main motor having problems turning. Quite often this is caused by a faulty consumable (opc,toner or transfer belt). Could also be that the lid is not closing properly and stopping the toner carousel turning freely
Jul 14, 2011 | Konica Minolta Magicolor 2530 DL Laser...
Fatal error 17h
17H is the Rack Rotation error. If your toners are not rotating correctly, or if you have the wrong type (IE 2400 series toners in a 2500 series printer) you will get this error.
Feb 18, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Magicolor 2530dl
IF YOU LOOK AT THE PRINTER FROM THE TONER BOTTLE END THERE IS A SMALL CLUTCH IN THE TOP LEFTHAND REAR CORNER OF THE PRINTER.
YOU WILL NEED TO REMOVE THE TOP COVER TO ACCESS IT.
IT IS BEHIND A PLATE BUT FASTENED TO THE MAIN FRAME OF THE PRINTER.
YOU NEED TO SPRAY INTO IT WITH SOME LUBRICANT LIKE WD40 NOT OIL.
THIS CLUTCH GOES RUSTY AND DRIVES THE CAROUSELL SO GIVES 15H CAUROSELL ERROR
Oct 25, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Where are the toner cartridges in magicolor 2300 dl
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing
rack rotation
open door, remove waste toner box then you have to find a small switch in left side and push it wit screwdriver or something, then you can rotate the toner rack manually. then install the waste toner box again and power up printer.
Sep 01, 2008 | Konica Minolta magicolor 2300DL Laser...
Fatal error 17H
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing rack rotation
<Remedy>
Electrical components for detection of the malfunction
Rack motor (M2)
Rack clutch (CL1)
Rack home position sensor (PC4)
Master board (PWB-A)
Controller control board (PWB-P)
Rather than try to explain in more detail i can forward you the service manual (4.17mb) if you update with an e mail address
Jun 05, 2008 | Konica Minolta magicolor 2300DL Laser...
Minolta 2300 dl laser printer fatal error 17H
had printer for approximately 2 years. Used daily in office setting. today the printer tried to print, then just stopped and it said fatal error 17H in the window. We cleared paper jam and rebooted, gives the same error message. Anything we can do?
Apr 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Minolta Magicolor Fatal Error
Remove each of your cartridges one at a time and see if you can spin the toner rollers by pushing on the little white plastic gears with your finger. They will be tight but you should be able to spin the roller by moving the little gears around.
My printer started giving the Fatal Error Code 17H and I did all the removal of the four color cartridges and re-seating each of them to no avail. After removing each cartridge and checking to see if I could rotate the toner roller I found that the yellow cartridge was extremely tight. I took the cartridge outside and used a can of compressed air to blow all the toner off the roller and tapped the cartridge on all corners and shook it back and forth several time. Finally I was able to get the toner roller so that it would rotate when pushing the little white gears like the other three cartridges.
After replacing the cartridge in the printer it worked with no more error codes. Hopefully this will fix the problem until I can order a new yellow cartridge.
Keith
Jan 07, 2008 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta 2530DL
I had the exact problem with the paper stopping at the same point in the printer. The fault was not the paper feed but the fact that the drum stopped at this point due to a loose toner cartridge. I rotated the cartridge using the menu for relpacing it and removed the cartridge and then re-fitted making sure it was fully seated in the printer. It now works fine. I would check each of the toners again.
Chris
Dec 12, 2007 | Konica Minolta magicolor 2300DL Laser...
Fatal error 17H
Try going through each toner cartridge again. The error is linked to incorrect rotation usually caused by badly seated toner cartridges.
Chris
Dec 06, 2007 | Konica Minolta magicolor 2300DL Laser...
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
