Question about TT Systems Lands Phones
BT Paragon 510 phone. Call red indicator will not switch off
BT Paragon 510 phone. Call red indicator will not switch off when I pick up the phone Is there a button to switch it off It will not switch off!
3 Suggested Answers
SOURCE: My BT Paragon 450 corded
I was fiddling around with my computer phone connections and the dial tone came on again.
Posted on Nov 27, 2008
SOURCE: Message light on my bt paragon 650 phone answering machine
You may have a text message come through. Press the TEXT button to read then options to delete.
Posted on Jun 10, 2010
Hi, lost the caller ID on my Gigaset C300 since changing from BT to Vodafone who say it's been enabled- any suggestions please? UK
Does it pick up caller display on another phone? If it does, you may have a compatibility issue. If not, Vodaphone have not switched it on yet.
Feb 16, 2017 | BT Lands Phones
When trying to pair my plantronics voyager 50 to my iphone, i am attempting to get the blue and red light to flash by pushing the up volume and the call button. but no flashes occur, even after 60 seconds...
  1. Turn on Bluetooth within your phone. Put phone into pairing mode.Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
  2. Pick the headset for Plantronics when prompted. Enter "0000" (four zeros)
  3. you should now have a continuous blue light blinking.
  4. Choose "Yes" if your phones asks if you want to bond to the Voyager 510 bluetooth headset.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Just purchased the quantico phone trying to pair it with my plantronic 510 headset but need help
Press and hold both the Speak Volume Adjust Buttons on the base unit until
the indicator in the Call Control Button starts to flash.
Press and hold the headset Listen Volume Adjust + Button and headset Call
Control Button until the Status Indicator flashes red and blue.
Pairing completion is indicated when the Call Control Button indicator
illuminates solidly, and the Status Indicator flashes
Here is link to manual if you need it:
http://www.plantronics.com/us/media/media-resources/literature/user_guides/voyager510_ug_gb.pdf?WT.dl=20
Good luck
Apr 16, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Where do i find the code to program a remote for my tv?
Hello
Four digit codes for Mitsubishi are
0005 0151 0051 0004 0009 0254 0022 0141 0180
Three digit codes for Mitsubishi are
002 102 206 502 510 619 709 803 814 914
004/ 005/ 009/ 022/ 046/ 081/ 089/ 132/ 133/ 180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Switch OFF and switch ON your TV, with its front panel power control main switch each time before trying an other code. OK.
Feb 11, 2011 | Mitsubishi WS-55513 55" Rear Projection...
How temp. disable this timer, without loosing program
You posted under Paragon 42013-20 240Volt indoor-outdoor mechanical timer.
The 'program' is how you set pins on the dial.
Pins cause electrical switch to turn ON-OFF
http://waterheatertimer.org/Paragon-timers-and-manuals.html#42000
http://waterheatertimer.org/pdf/Paragon-42000-sell-sheet.pdf
For example if you disconnect electricity to this unit.
Clock dial stops rotating, but pins are not changed.
When electricity is connected again, manually rotate clock dial until current time lines up with red pointer.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 27, 2011 | Paragon 42013-20 Timer
Message light on my bt paragon 650 phone answering machine, will not go out after deleting all the mrssages.
Mar 20, 2010 | Lands Phones
Blue light blinks all the time its on
Plantronics 510 Voyager Headset - PLN-510 Headset - Light blinking blue.
Good! You'll be happy to know, this is normal.
The Status Indicator flashes blue when the headset is on. When the battery becomes low, the indicator will flash red.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Feb 06, 2010 | Plantronics 510 Voyager Headset - PLN-510...
How to set it up with new phone how do i set up discoverable mode
  1. Turn on both the phone and the headset
  2. To put the headset into pairing mode, at the same time press the Call Control button (side of the headset) AND the volume button marked "+". When the status indicator light flashes between blue and red, you are in pairing mode.
  3. Now use your phones menu to search for bluetooth devices, you should see it say "PLT 510" on the screen. Note, this can take up to 2 minutes.
  4. When it asks for the passkey, enter "0000" (zeros). When the light on the headset turns blue you are successful.
  5. If this fails, try again
  6. If this fails again...reset the headset. To reset, do a long press of the MUTE and volume down buttons simultaneously for about 3 seconds, then try the procedure again.
Oct 16, 2009 | Plantronics 510 Voyager Headset - PLN-510...
My BT Paragon 450 corded phones has been dropped,it appears to be working okay but has no ringing tone.
Nov 26, 2008 | Lands Phones
During moving I must have lost my cd for my blue tooth plantronics 510 ic, now I'm not able to install it on my computer so that I can phone hands free
have you tried to download the driver for your blue tooth plantronics 510 ic?
if not is uggest you go to the manufacturers website checkout the driver-software for your "bt" and download it.... if still can't install it form your pc...try to copy the driver to a disc and install your "BT" using the cd.
Jun 21, 2008 | Computers & Internet
Lands Phones Logo
98 people viewed this question
Top TT Systems Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a TT Systems Lands Phone Expert? Answer questions, earn points and help others
