Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Shutting off keep shutting off after 30 mins or so
  • debbie055 Feb 19, 2008
    what do that mean?
  • 979 Answers
Power supply problem; could be caused by regulator, filtering or even X-ray protection coming on...accordianman
Posted on Feb 19, 2008
Regulator or power supply problem. Could also be X-ray protect coming on...accordianman
Mower blades will not engage when hot
overheating safetybsprings are wore out. they either got over heated or reached their limits
Jul 24, 2014 | Cub Cadet Garden
Dc 30 tracker collar keeps shutting down, I have changed battery and recharged unit and it still only runs for about 1 min.
3 PointsProblem with Cars & Trucks
Dc 30 tracker collar keeps shutting down, I havecars and trucks,my car has no tracker., does yours, ,omg
Oct 12, 2013 | Cars & Trucks
2007 Panasonic 50in Plasma shuts off after being on 30 min sleep timer off, is the problem the cooling fans out/ over heating
Yes, cooling fan could be a problem. Just see whether it goes off during before shut off. If yes, the TV might need service. To know whether the fan goes off first or the TV, stick one side of any thin vibrating membrane such as a silver paper (like the one you see in cigarette packets) on the fan outlet, without blocking it, so that you can see whether it stops before the TV shuts down. Alternatively you can hand an inflated balloon which keeps flying off from the area of the fan and shall stop when the fan stops. I suggest this, in order to save your time looking at the rear all the time until the TV stops. Even then, one is likely to overlook whether the fan stops or TV stops first.
Aug 29, 2012 | Panasonic Televison & Video
Notebook keeps shutting down
there are numerous cases why the computer keeps shutting down. One is the pc is slow to react, the other is when the pc is in idle mode, it did not respond accordingly to its idle time to come back to its original settings. These are just the samples.
To solve this problem, kindly turn off the computer and remove the battery and cables to it. Then using your forefinger, press & hold the power button in between 8-12 secs. Then reinsert the cables and battery to it. Turn on the pc and let your computer be idle in 30 mins. If in 30 mins your pc will shut down, that means there is trouble on your memory module inside your laptop. The RAM (Random Access Memory) keeps your computer in safe and running condition for it is avoiding the pc to automatically shutdown. That is the time to consult ASUS about this issue...
Sep 02, 2010 | ASUS Eee PC 1000H Laptop
Have a small Kenmore freezer (31" high x 24" deep by 21" wide). It works fine as far as freezing, but it never cycles off. Just keeps on going and going, driving me crazy. I also continually hear a subdued...
the wooshing maybe the oil/freon migrating thru out the internal system...
The cycle depends on 2 things... t'stat operation and timer. The timer usually shuts off freezer every 6 or 8 hrs for 20 to 30 mins. But the t'stat (once it reaches desired temp. should shut off freezer every 15- 20 mins. for an average 10 -15. So 15 mins off min 15 mins on (that is if the doors is not open) you get my point something like that...
but the way you describe to me it sounds like the t'stat. set it at 1 if it dont shut off and you are absoultely sure you got zero degrees (use a temp. reader) then replace the t'stat
hope this was helpful
let me know if this didnt work then plan B
Mar 09, 2010 | Freezers
Gas dryer runs for 30 mins then shuts off.
This is a common problem that is not a good one. But the motor is goin bad. If you try to start it you will hear like a hum then start. Motor is going bad and over heating and shutting down on overload. Sorry. Hope this helps.
Jan 31, 2010 | Kenmore Dryers
Keeps turning off by itself after about 30 minutes
Is your air intake clean or clogged.. Maybe it's overheating causing it to shut off.. Had the same problem didn't replace the bulb but cleaned the intake and it works great again. Worth a try.. Intake is located on the left back pannel of the tv.. outside pannel pops off easly.
Apr 27, 2009 | Toshiba 42HM66 42" Projection HDTV
Rca shutting off and on
try unpluging it for 30 min. and then reset your menu settings,if it still does it you have a possible eprom error or tuner faulty.
Oct 30, 2007 | RCA 32F531T 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
