Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Thank for taking my Q: it looks like the colors have separated from each other . you can see 3 or 4 pictures in different colors thanks
4 Suggested Answers
  • 1030 Answers
SOURCE: screen lookes like colores separating
Hey try this check under setup do you have the convergence option. if you do not you may have a simple little repair. Check out the article in the tips and trick section of this site intilted "the fl231 problem"
Posted on Dec 06, 2008
  • 1030 Answers
SOURCE: rca p56927 colors out of line
This is a convergence oroblem. First question is do you have the convergence option in under setup in the customer main menu?... if you dont you may have the very common fl231 fuse problem; i have wrote a article on this under the tips and tricks section. this is a very simple inexpesive repair. If you do have the "convergence option" then you may have to replace one of three cuircit boards
Posted on Feb 01, 2009
ekcnoel
  • 998 Answers
SOURCE: 3 color rainbow at top
The problem of your tv is the convergence. Try to adjust it manually by going in the main menu settings. If nothing happens you should replace your convergence IC. Try to open the back cover of your tv then try to look for a large aluminum plate it is connected there and it has a marking of STK-followed by a number and also look for some parts like capacitor it is a cylindrical shape try to look for a swollen capacitor it has a oil spill in the bottom of the capacitor.
Posted on Jun 08, 2011
Periodic color scrambling - out of focus. Seems as though the different colors separate and get out of focus.
Ur tv is having a convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Hitachi 50GX30B 50". Rear Projection...
Picture has color separation and halos. Picture distorted.
Your convergence is bad and you need to replace the convergence ICs. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to fix it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
Apr 27, 2010 | Mitsubishi VS-55601 55" Rear Projection...
LOOKS 3 DIFFERENT COLLORS
The set has lost convergence correction. This circuit actually makes the three colors come together on top of each other for a normal picture. This should not be a real expensive repair. Thanks
Oct 27, 2009 | Televison & Video
Blurry and colors are seperated red green white
if you are viewing from a projection tv, chances are you have to go thru the menu of the tv to 'picture tuning'. here it gives you different things that could be fixed. one to look for is 'lamp alignment'. It should show all the colors and lines with directions to bring them into focus. This should fix the blurriness and 3-d red/green/white separations. hope this helps you!
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Shadows/ghosting is present on screen at all times
What kind of shadowing are you seeing? Doe the picture look like a 3D movire (colors separated)? What is the make and model?
Please update this with the above info and I'll provide possible solutions.
Thanks,
Dan
Mar 20, 2009 | Televison & Video
DOUBLE PICTURE WITH DIFFERENT COLOR
this is a convergence problem,
well worth fixing
I would have a TV repairman take a look at it.
Regards,
daniel.
Jan 12, 2009 | Philips Magnavox 51MP392H Rear Projection...
Color went to grayish green, dull picture.
It ended up being one of the connectors on the composite cable. I did not know that the different colors came through separate cables. I do now, Thanks.
Dec 05, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Looks like picture is out of alignment. like looking at 3 different pictures at once in different colors.
This is a convergence problem. Please post the make and model so I can provide you with the details of the parts required to fix this.
Thanks,
Dan
Sep 08, 2008 | Televison & Video
Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
May 22, 2008 | Televison & Video
Colors out of place.
hmmm...should be a separate function, called degauss. that's standard on all of those sets.. let me check my notes again.
Feb 24, 2008 | Samsung PCL545R 54" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
322 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
