Question about Crunch Powerzone P2200 Car Audio Amplifier
I have a qiestion on a 1300 watt 5 channel crunch amp.
  • 24 Answers
Whats the question? if its a power zone its a very good amp
Posted on Feb 06, 2010
Crunch 2000.4 car amp, need help tuneing
re-check the speaker connections are correct and use a matching ohm test speaker on the other connections for a sound check. Sounds like hi frequency output into the sub amp. Sub-woofers are a mono signal!!
Jul 17, 2017 | Crunch Car Audio & Video
Can I Bridge 2 Pioneer 12 1300 Watt 4 Ohms to boss 2600w 4 channel amp
Yes, one sub to channel one and two and the other to three and four. Ensure you set the crossover to lowpass. If you don't get the sound you want, as long as you have the correct enclosure, I would recommend an external adjustable crossover.
Mar 21, 2016 | Pioneer Car Audio & Video
I have a lanzar vector VCT-2210 2000 watt amp hooked up to two menace 1300 watt subs. when i turn the volume up on the head unit the amp goes into protection mode. i checked all my wiring and it seems all...
Things to check: Is the wire between the amp and the subs heavy enough to pass 167 amps? 2000 * 12 = 166.66666 amps. Max volts on the subs are 10 volts....close enough. Are you sure you're using the line out on the head unit? You may be over driving the amp if it's anything else.If the head unit doesn't have line out connectors then you'll need to get an attenuator for each channel. Do you have caps on the 12 v power in wires? They'll keep the headlights from dimming and the alternator will last longer if you do.
Apr 09, 2014 | Lanzar VCT2210 Vector Series 2 Channel...
Does crunch blackmaxx take aux for iPhone?
The amp is a discontinued model, but I do think I found the specs on it. It will produce :
350 Watts X2 @ 4 ohms
700 Watts X2 @ 2 ohms
1,400 Watts X1 @ Bridged at 4 ohms
It is designed to be ran inline between your stereo and a set of, or a single, sub woofer.
This could be a significant amount of work for a beginner in car audio, but it can be done.
I would do a little research and decide if you want to use this amp. Join in on forums like http://www.caraudio.com/forums/forum.php, and http://mobileaudioforum.com/forum/forum.php to learn what can be done, and how to do it. good luck.
Jan 19, 2014 | Crunch Car Audio & Video
I was thinkin bout buyin a planet audio ac2600.2 car amplifier but cant find what gauge power an ground wire it takes and how many watts it puts out 2 channel @2ohms rms. can you help?
Here are your specs. RMS 900 Watts Nominal and Max 1300 on 2 Channel @ 2 Ohms.
4 Gauge should do fine but if you like to feed the beast go with 2 gauge.
Looks like going rate is $110 on Amazon or elsewhere.
If it attains the RMS wattage it would be a good amp. I like monoblocks but
you will pay more. I looked into Tri-Mode and it is straight forward but people
are having problems figuring it out. With your 2 speaker operation you should
avoid the issues others are having.
Good luck and remember, rearview mirrors were meant to fall off!
Mine: JL 1800A monoblock into 2-JL 12" W3's in series for low bass 20-80 Hz; Lanzar Vibe 266 bridged into 2-12" Memphis in series for mid bass 40-200m Hz. 2 guage wire to mononblock-250 amp fused at battery, 4 guage to Vibe w/250 amp at battery.
Anarchy Series 2-Channel Car Amplifier
  • RMS Power Rating:
    • 2 ohms: 900 watts x 2 chan.
    • Bridged, 4 ohms: 1800 watts x 1 chan.
  • Max power output:
    • 2 ohms: 1300 watts x 2 chan.
  • Total Power Output: 2600 watts
  • Pulse width modulated MOSFET power supply
  • Convenient remote subwoofer control
  • LED power (green) and protect (red) indicators
  • Variable Bass Boost 0 to +18 dB
  • Bridgeable Tri-mode operations
  • Chrome-plated connections enhance durability
  • Variable high and low pass crossovers
  • Illuminated logo
  • 3-Way System Protection circuitry (thermal, overload, and speaker short protection)
  • Dual speaker terminals simplify the hookup of multiple speakers
  • Heavy duty aluminum alloy heatsink for extreme heat dissipation
  • Low level high inputs
  • Heavy-duty set-screw terminals
  • Input sensitivity:
    • Low level: 100mV-2V
    • High level: 2V-8V
  • Variable high-pass filter (45-90 Hz, 24 dB/octave)
  • Variable low-pass filter (50-500 Hz, 24 dB/octave)
  • Damping factor: >125
  • Signal-to-Noise Ratio: 102 dB
  • Frequency response: 20-20,000 Hz
  • Dimensions: 15-9/16"L x 10"W x 2-3/16"H
  • 1/0-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
  • 1-year Manufacturer's warranty
Mar 19, 2011 | Planet Audio Car Audio & Video
I have a Crunch Powerzone Pzi2250 1000 Watt Amplifier. and the red light blinks. What does that mean
My crunch powerzone pzi2250 1000 watt 2ch amp is stuck in protect mode. How do I fix this at home
Jan 16, 2011 | Crunch Powerzone P4175 Car Audio Amplifier
I have a DA 1200.5 5 channel amp. It stopped
diconnect all your speakers from the amp and see if the light turns green. if it does, reconnect one speaker at a time to find out what speaker is making the amp go into protect mode
Feb 24, 2010 | Crunch BlackMaxx BLX2000D Car Audio...
The gain control no longer works on the clean/crunch channel. all other features work fine, whats wrong with my amp?
Hi there. Try re-soldering the control pot to circuit board connections. If not, use ohm meter to verify pot functionality. If bad, replace.
Thanks
Paul
Jul 10, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Crunch Powerzone P2200 Car Audio Amplifier Logo
66 people viewed this question
Top Crunch Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Matthew Spark
Matthew Spark
Tygh Duval
Tygh Duval
Are you a Crunch Car Audio and Video Expert? Answer questions, earn points and help others
