I just bought a used copier that says "close section properly" but everything is closed
What make and model is it?
Posted on Feb 02, 2010
Close section properly
Its not talking about the bypass tray. Its saying the right side door isn't closed. There is a cover above the fuser that may not be closed. Open the right side door and see if you see any broken parts. If everything is closed correctly and not broken, the message will go away.
Jan 24, 2014 | Konica Minolta bizhub C250 All-In-One...
Close section properly Minolta di620
problem on section door switch or any door open please close it properly.
Oct 26, 2013 | Office Equipment & Supplies
Message on screen saying 'close section properly'
You must be changed the broken parts or improvised something because the open door affected the vertical transport tray of the paper.
Apr 11, 2013 | Konica Minolta Office Equipment & Supplies
The fax/ printer says close adf cover then press stop, the cover is closed down properly and there is no paper jams everything is closed properly ?? what do i do to fix it? thanks!!
the ADF cover is the automatic document feed. make sure the cover above that tray is closed tightly. maybe try opening it and reclosing it. sometime the sensors get jammed up.
Nov 08, 2012 | Office Equipment & Supplies
Bizhub 500
There is another cover at the down right side of machine.Below the side door.Open it and then close it.Then bring out the tray and close it.Machine will start working.if not then tell me...
Nov 15, 2011 | Konica Minolta Office Equipment & Supplies
What is the finisher front cover? And how do I close it?
You are standing in front of it, the machine has sensors that sarround its operating peoperly therefore pay attention to its claims. closing is simply closing when you open the front door of the machine same way close it firmly but gentle, make sure everything inside is properly set accordingly to mini instructions inside the machine follow them they will guide you. The machine has atleast three doors the front and two side doors. look for them and just make sure they are closed nicely and properly.
Aug 01, 2011 | Sharp AR-M350U Copier
There is an open door of transport carriage not properly cosed. Insure you have closed all doors and transports correctly.
Thanks.
Dec 15, 2010 | Minolta Di251 All-In-One Printer
Minolta Copier's sorter bin won't close properly.
This 20 bin sorter uses an interlock switch and actuator to show that the sorter is properly attached to the machine. Pull the sorter away from the machine and look at the rear side of the copier that faces the sorter. There should be what looks like a spike mounted to the copier. That spike goes into a hole in the sorter which then actuals the switch. Make sure the spike is not broken or loose. Make sure the tray that the sorter sits on is not bent. Correct any issues with these 2 and you should be good to go.
Jan 07, 2010 | Minolta EP4000/5000 CS/PRO Copier
Door close message
Witch section are you talking about ????
Apr 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
14 people viewed this question
jasbo
jasbo
