Question about Dryers
DRYER TURNS ON FOR 1 TO MINUTES THEN STOP GETTING
DRYER TURNS ON FOR 1 TO 5 MINUTES THEN STOP GETTING WARM THE DRYER IS ONLY 3 YEARS OLD
  • Steve Allison
    Steve Allison May 11, 2010
    This post probably won't get you a pertinent reply; you must list the model number of your dryer.
  • 51 Answers
There is a thermister at the top of the machine just inside that needs to be replaced, this will solve the problem
if you need further assistance, email me at appliancesdav@hotmail.com
pallesappliancerepairs.com
Posted on Feb 02, 2010
  • appliancesda Feb 02, 2010
    there is a thermister at the top of the machine just inside that needs to be replaced, this will solve the problem
Dryer Miele T9800- 3 years old Lately the air doesn't get hot, it will be warm and it will take over 90 minutes to dry clothes that before were done in 15 minutes.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Sep 13, 2010 | Miele T9800 Electric Dryer
The gas dryer does not get warm?
to have it get warm there are 3 things have to be working together:
1- Ignition needs to be on to start the burning.
2- Gas valve needs to be opened after ignition is on.
3- Gas continues jetting in until a thermal switch turns the valve off.
You can open the rear panel to observe if the ignition is glowing or not. If it is not then that the culprit. If it is on then glows off after a while since the gas valve is not open, then you can just replace the thermo sensor if it is separate from the gas controller. Some controller has it integrated then you have to replace that. Good luck.
Apr 21, 2010 | Kenmore 98702 Stacked Washer/Dryer
Our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
Mar 20, 2010 | GE Dryers
Whirlpool Ultimate Care II dryer trips breakers.
No way to know unless you do some checking. This video shows how to get into the machine: HERE
I have a repair manual that features the same basic style of dryer you may want to take a look through: HERE
Feb 14, 2010 | Dryers
This is an electric dryer. Over the past week when
one of 3 things could be wrong/1)dry,tight motor bearings/2)drum bearing bad/3) bad motor windings,remove belt off drum and see if anything turns hard i.e. motor,drum each one isolated then run motor w/o drum belt on drum and see if motor gets overly warm or hot especially around the bearing ends
Nov 15, 2009 | Kitchen Ranges
Dryer runs and has heat, but takes 3-4 cycles to dry
inspect your dryer vent if it is clogged or has standing water in it, that will cause your problem
May 12, 2009 | Dryers
Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Apr 04, 2009 | Maytag Dryers
Microwave oven turns off
Many over-the-range microwave ovens suffer from intermittent problems caused by excessive moisture from the range/stove entering the microwave cabinet and collecting on the circuitry. Often the problem is with one or two simple connections that may need tightening or soldering. But, to repair these components, the microwave cabinet needs to be opened. So we recommend that you seek the assistance of a qualified appliance repair technician.
It may be worth getting it repaired. Shop around for prices and see if it is worth your while to repair it or simply buy a new one :)
Sep 29, 2008 | Microwave Ovens
Dryer problem
hi thanks for the question are you saying that the whole dryer shuts off after 2 minutes or just the heat if your dryer runs for 2 minutes and then cuts out then you wait 10 minutes it goes again then its the motor thanks the appliance doc
Aug 25, 2008 | Kenmore 62872 Electric Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
49 people viewed this question
Top Dryers Experts
