Question about Sylvania Audio Players & Recorders
I get a message that the battery needs charging even thou its fully charged
  • 201 Answers
How do you know it's fully charged? Is there a battery level indicator?
Posted on Feb 02, 2010
How do I know when my lg 2 extravert 2 is done charging
The battery bars indicator at the top of the screen will be full and when fully charged the message will say battery fully charged, if you unplug the charger and reconnect and the battery is fully charged you will see this message!
Oct 18, 2014 | Verizon Communications LG enV Cell Phone -...
Tip
Batteries & USB Devices & Charging
I see lots of people have trouble with their batteries for their various USB connected devices. Unfortunately you cannot usually charge a totally flat battery, or even a 1/2 charged one... from the USB port. These are only used to "Top Up" the battery... & keep it charged up via a "Trickle Charge". at very low current.If your battery is in this condition then you need to replace it with a fully charged one, and then use the USB to keep it fully charged.Another way is to connect the "Flat" battery up to a power supply or machine that charges them, at the right Voltage (Usually 3 - 6 V) & Current rating, and once fully charged, then use the USB.
on Jan 29, 2010 | Computers & Internet
Battery is not charging fully even after i changed my battery it charges only up to 30% when i switch it off and on once again it becomes to just 4% .I cant send messages from the mobile W705 ,I have...
Ifthe recharable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Feb 14, 2011 | Sony Ericsson W705A Cell Phone
Low Battery
Your battery may be losing it's ability to hold the charge or your charger may be fully replacing the charge in the battery. Personally, I suspect the battery.
Don
Jan 13, 2010 | Brady TLS2200 Thermal Label Printer
I can't hear thru the headset even thou it is charged & commuatat
remove the headset from the charger socket and place it in the head set socket
Mar 21, 2009 | Motorola Cell Phones
Charged cell phone
do not charge your mobile battery each night for best battery use, you need to charge the phone only when the battery is completely dead.
You should take the phone and have it fully check and service
Jun 28, 2008 | Motorola Mobility RAZR V3
"CHA" message - will not take picture
believe it is the film card. Try a different one.
Jun 21, 2008 | Nikon D70s Digital Camera
My unit just shuts off and will not turn on again until I plug it in as if to recharge the battery. I checked the battery when I first turned it on and it said the battery was fully charged.
Hi there!
It probably does need a battery replacement.
Even though it may show fully charged, and even test as fully charged, it may no longer have the capacity to deliver it for any sustained period.
If you think of a comparison between a 12V car battery, and a 12V alarm battery. Both show full charge, and the same output voltage, the difference is the available plate area. This is reduced due to degredation, and will no longer provide the same output.
Hope this helps.
If you want to make the battery last longer, charge for the recommended time (as was the first charge), then run the battery right down before charging.
If this solves the issue, Please rate as Fixya! thanks.
Jun 20, 2008 | Magellan GPS
I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Mar 24, 2008 | Panasonic KX-TG6051M Cordless Phone
Symbol RF MC9060S - Internal Battery is dead
You have to first charge the backup battery, for charging insert a fully charged main battery into the MC906x. Then the backup battery will starts charging leave it there for one day. if that message is still coming then the problem is with the backup battery and u have to replce it
Jul 06, 2007 | Laser Symbol Technologies MC9060S Mobile...
Top Sylvania Audio Players & Recorders Experts
David Payne
David Payne
Tre Elkins
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
