Question about XFX GeForce 6200 Graphic Card
Geforce 6200 / dell dimension 4600 resolution problem
Hi, i have a dell dimension 4600 and just installed a geforce 6200 graphics card.
now, my desktop resolution's all messed up.
the screen resolution slider in properties/settings no longer works.
it's stuck on "less" and won't move.
please, help.
  • 1 more comment
  • katymiller Feb 02, 2010
    thank you for your prompt response.
    yes, it is a replacement for an older card.
    my computer is old and this is (supposedly) one of the only compatible newer cards available.
    no, i do not believe i removed the old drivers.
    actually, i know i didn't because i do not know how to do that.
    i did install the new drivers from the cd that came with the card.
    how do i remove the old drivers?
  • simon fitzner
    simon fitzner May 11, 2010
    is this a replacement for an older card? and did you remove the old driver and have you installed the new drivers?
  • 37 Answers
If this is a relacement for an old card 1st make sure the old drivers are ubisnatlled and the goto www.nvidia.co.uk and install the latest wqhl drivers and that should remidy it you may also need to reset you monitor settings
Posted on Feb 02, 2010
Testimonial: "very prompt reply. simple explanation. "
  • simon fitzner
    simon fitzner Feb 02, 2010
    if you go to control panel and add/remove software find the old drivers if its for example an ati card it will be ati drivers if other should be listed under manufacturer name... if no joy pm me or email me support@pctechguyonline.com
Help with upgrading Dell Dimension 4600 GPU
June,
The Dell Dimension 4100 Desktop PC, utilizes an AGP slot on the motherboard, for a graphics card.
http://en.community.dell.com/support-forums/desktop/f/3514/p/17152514/17275500.aspx
There are different styles of AGP expansion slots.
The one on your motherboard was the last current style of AGP -
AGP 8X
Therefore your Dimension 4100 uses an AGP 8X graphics card.
It is (Was) an Nvidia GeForce FX5200 graphics card, and the AGP 8X style.
http://en.wikipedia.org/wiki/AGP
To replace it just use a graphics card that is AGP 8X, and is better, or equivalent to the GeForce FX5200.
You also need to know that your Power Supply in your computer, will handle the power requirements for the computer system, AND your new found AGP 8X graphics card.
Power Supply was rated, at a maximum Wattage rating of 200 Watts.
Problem is; that back in the day when the Dimension 4100 was made, the Power Supply manufacturer 'Fudged' the real Wattage specifications.
Power was (Is) more like 60 to 70 percent of what is stated.
Divide 200 Watts by 10
= 20
Now take that times 6, for 60 percent.
= 120 Watts
Now take that times 70, for 70 percent.
= 140 Watts
ACTUAL power
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4410189&CatId=2234
I would recommend this one, but it requires 250 Watts MINIMUM,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=853908&CatId=2234
[Graphics card manufacturers, base the Minimum power requirements for their graphics cards; based on a test computer system.
So the Minimum power requirement stated, is not only for the graphics card; but ALSO the rest of the computer.
The test computer system is usually based, on all of the top of the line, power consuming hardware components; of that time
Top of the line powerful Processors, and Motherboards.
Add to that the maximum amount of Ram Memory, that can be used.
Two optical drives, (CD/DVD drive)
Processor fan, and at least two computer case fans ]
KNOW THIS:
A) FOLLOW Anti-Static Procedures
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer, and BEFORE taking any new parts out of their Anti-Static bags, or cartons.
Computer on a table, computer Unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return
B) Windows running on your computer, PUT the Installation disk that comes with the graphics card, in your optical drive tray.
(CD/DVD drive)
Install ALL software.
There will be Drivers you are installing, and also a graphical user interface. (GUI)
The GUI for an Nvidia graphics card, (Evga GeForce 6200 is an Nvidia card), is the Nvidia Control Panel.
(For ATI it's Catalyst Control Center)
Driver: Small piece of software that allows the Operating System to communicate with a device
In this case the device is the graphics card.
What version of Windows operating system was not stated.
-> AFTER <- you have installed the software, and if it asks you do you wish to restart your computer; the answer is -> NO
Close all windows, go back to your desktop screen.
Now turn the computer off normally.
Follow Anti-Static Procedures, and Physically install the graphics card.
Note*
The AGP expansion slot on the motherboard, will have a type of Locking Arm on it. With most the end of the arm, has a 'fingerdip' in it.
Makes it look as though you press DOWN, on the end of the Locking Arm, in order to release it. (Unlock)
Actually you GENTLY pull up a little on the PLASTIC Locking Arm, to release it.
Release to remove the old graphics card, and to install the new one.
After the new graphics card is installed, attach the monitor cable to it, and close the computer case.
Turn the computer on.
You MAY have to go into the Nvidia Control Panel, and set Screen resolution, and other parameters.
(Look up your monitor by it's manufacturer name, and model number. {Back of monitor - Model Number}
See what the Screen resolution is.
Example - 1280 x 800 pixels
Set Color quality to High (32 bit)
Have additional questions please post in a Comment, or Reply.
(Below my solution)
[When a device is installed on a computer with Windows, Windows will 'break it's neck' to find suitable, matching drivers.
If THE drivers are not there, Windows will match up one of it's THOUSANDS of generic drivers.
This = NO
A Driver Conflict can result.
Windows: "Which drivers do I use? These or THESE?"
With THE drivers installed first, Windows will find them.
May 06, 2013 | Dell Dimension 4600 PC Desktop
Hello, I have been using my asus vw222u monitor for a while now, connected to my dell dimension 4600 pc. I have been running the resolution at 1024x768, and been getting relatively clear pictures, but...
Your graphics card will not support that refresh rate @ 1680x1050. you may need to upgrade your graphics card.
Here is the best price/performance card for your machine. and will support upto 2048x1536 @ 85Hz
Hope this helps.
http://www.scan.co.uk/products/512mb-pny-nvidia-geforce-6200-graphics-card-agp-8x-4-cores-d-sub-dvi-i-s-video-passive-cooling
Apr 22, 2011 | ASUS VW222U 22 inch LCD Monitor
Hi, I have an EVGA GeForce 6200 AGP, 256MB DDR2
This is a common problem, you need to clear the CMOS which will also reset the BIOS settings. Here's a few ways you can do that:
http://pcsupport.about.com/od/fixtheproblem/tp/clearcmos.htm
Feb 22, 2010 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Scrolling delays, choppy scrolling as if multiple pages
Did you install the original drivers from the vendor of the e-Geforce card if not try doing it it should fix the problem.
If you dont have it download it from here
Also try to update the directx
Nov 29, 2009 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Monitor going to power save mode and freezing
Hi, i have had that problem before and its wasn't the graphics card drivers, it was loose, anyway for you case go to device manager and uninstall the graphics drivers from there then restart and install then manual by updating and locate the exact location from the cd or any other location that has them.
That should help
Cheers
Apr 27, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Replacing a Graphics card: Presently a GeForce 420 (64mb) upgrading to GeFroce 6200 (256mb). System is a Dell Dimesion 8200 w/Windows XP at 2GB with 100+ GB free. Will the card work? Tim
If the type of card is the same,and will fit into the slot,such as AGP or PCI or PCIe, then it wil work after you install the new video card drier for your operating system of windows.
Dec 27, 2008 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Vedio controller GeForce 6200
XFX GeForce 6200, Graphic Card
driver dowunload
Aug 16, 2008 | XFX GeForce 6200 Graphic Card
XFX GeForce 6200 Graphic Card Logo
538 people viewed this question
Top XFX Computers & Internet Experts
David
David
KG John Justin
KG John Justin
marley mcelhinney
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
