Question about Bosch Washing Machines
Is the Bosch Classixx 1000 washing machine hot or cold water fill
The washing machine worked fine when it was on the hot water pipe, but it consumed my hot water. I had it changed to the cold water pipe and I don't get any water inside. Researching online, I saw that Bosch Classixx has a cold water fill. I just want to make sure, maybe the guy who did it forgot to turn on the water. If so, how do I turn it on? (I live in UK)
  • 4,066 Answers
You should be able to select hot/warm or cold for any wash cycle using the selector switch on the control panel. If it's been changed to just a cold water supply, look on the back where the hoses are connected to the water supply. There should be two.Usually left hot and right cold. You can turn either one on and off from there. Cold water wont clean as good as hot or warm.
Posted on Feb 02, 2010
Hot water barely comes out,
If you switched the feed hoses over and the problem reversed itself, cold has gone from fast to slow useing the hot water pipe and hot from slow to fast useing the cold water pipe then this would indicate a fault in the water supply from the hot pipe. What sort of pressure is coming from the hot pipe when not connected to the machine but filling in to a bucket? Are there any shut off valves before the pipe that supplies the hot water? Are they fully turned on? Any kinks in the feed pipe for the hot water? Has the hot water feed pipe collapsed internally? Change the pipe to check this and not just at the machine side.
Dec 31, 2012 | GE Spacemaker Washer and Dryer Electric...
I've just had a bush a126q washing machine delivered but the delivery man could not install it because he said our cold water pipe was not working. The other machine that we are replacing just had a...
it will work fine but the problem is that all the rinses will be done with warm water, this causes seriously wrinkled washing thats v hard to iron out.
Jul 06, 2011 | Washing Machines
Just bought a new washer (refurbished, therefore doesn't come with a handbook). our old washer had both the cold and hot pipe connected, our new one (a bosch 1400 classixx) only has a white valve. do we...
You just need to collect the cold pipe- the washer does the heating itself for hot washes. It uses the water cold for rinses ;-0)
And for a manual-
you will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 24, 2011 | Bosch Classixx WFL 2066 Front Load Washer
I have been delivered a Aquiras Extra WMA 40 but I only have a cold pipe but I notice the machine has a hot and cold pipes do I connect to just the cold pipe and will the machine heat the water inside
No, the machine does not have a heater unless it has a sanitizing cycle which heats already hot water even hotter.
For the machine to work as advertised, you'll need hot and cold water connections. However, if you just hookup the cold water and run the machine on its cold-water setting it will wash -- the laundry may not be as clean as you would like in some cases, but the machine will operate properly.
Charlie
Jan 06, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
My bosch washing machine is a cold filled and the cold pipe is frozen as we got it in the garage can we us the hot fill with water min setting
You could, but bear in mind that it will be rinsing in hot water, so it could affect your washing.
I would suggest wrapping hot cloths round cold inlet hose and hope that will unfreeze it.
Also possible water could be frozen in the valve as well, which could burst when water unfreezes.
Dec 19, 2010 | Bosch Washing Machines
Bosch classixx washing machine is not heating the water
Have you interchanged the hot and the cold water valve? Check your installation. If the installation is correct, the hot water valve might be the problem. You probably need to replace it with a new one.
http://www.washingmachineadvisor.com
Nov 09, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Softener won't empty in Bosch Classixx 1000
take out the soap drawer clean in hot water inside the machine where you took the soap drawer out at the top look for the hole where the water runs out it may be blocked with mildew dettox mildew spray is very good at breaking all that down spray in leave for a while put soap draw back in and do a wash without clothing as spray contains bleach
Mar 30, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
67 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
