Question about Dell POWER SUPPLY Power Supply
Power supply plugged in but will not charger - Dell POWER SUPPLY Power Supply
  • 3 Answers
U need to check the cable wire, if it's ok then, u definitely need to change ur battery cuz' there's a life-time for a battery.
Posted on Feb 15, 2010
Jumper box
Go to a radio shack or a place like it, you can buy a charger with universal plugs that will fit in your charger, the other end will plug in your wall outlet.
Jun 06, 2013 | Computers & Internet
Charger was plugged in and working fine, went into
OK unplug power supply from back of laptop, remove battery, insert power supply, if NO light, on laptop, power supply is broken..Replace. IF it is OK, hold power button ON for a while, or until, the PC starts, if/when it starts, shutdown, with power ON key, and then take out power supply, replace battery, replace power supply, turn laptop on, now should be OK.
Mar 01, 2010 | Toshiba Satellite A70-S249 Notebook
My laptop will not charge
Even if it's new it doesn't mean that it works. Either get another charger or power supply, or check the battery. But I'll go with the "new" charger.
Oct 07, 2009 | Computers & Internet
I have a Sny dcr-hc48 camcorder which stopped working some time back. this week i had my friend who came with the same camcorder and i swapped in his battery and my camcorder started working. but if i...
First: put your battery in your friends camcorder and use ur friends charger to charge the battery.
Then put your battery back into your camcorder to see if it works.
If the battery works then this eliminates the battery as a problem.
Next plug your charger into your friends camcorder to see if it will power the camcorder without battery, if this works then the problem will most likley be the connector in your camcorder.
If this does not work then the problem will be the plug or the charger.
Next plug your friends charger into your camcorder if it does not work this will verify that the problem is the connector on your camcorder
binary6
Sep 16, 2009 | Sony Video Cameras
Cant get my hitachi dz-acs3 ac adapter battery charger to work
the light will not come on when it is plugged in and the batery is set in the charger to charge, even with the dc out power supply the dvd cam will not work, could the charger go bad? does this happen often?
Sep 15, 2009 | Hitachi DZ-GX20A DVD Camcorder
Archos Gmini220 Power Supply?
The charger which came with my Gmini 220 is 5V DC, 1.6A. It measures about 5.18V. The +5V is applied to the normally unused pin on the USB connector. The charger's plug is built so you and plug the charger into the Gmini and then plug the USB cable into the charger.
Aug 01, 2007 | Archos Gmini 220 MP3 Player
Overseas Use
If this is true, then why does the manual for my new PowerShot SD1100 IS say, "Do not connect compact power adapters or battery chargers to devices such as electrical transformers for foreign travel because it may lead to malfunctions, excessive heat generation, fire, electric shock or injury."
Is this just a standard disclaimer in case something weird happens by using a transformer to charge the battery?
Aug 31, 2005 | Canon PowerShot S20 Digital Camera
Overseas Use
Yes. The power supplies and battery chargers supplied with all Powershot Digital Cameras are designed to work on input voltages from 100-240 volts (50/60 Hz). The only item that you may need is a plug adapter that allows you to plug the U.S. type power supply or battery charger into the foreign type wall outlet. Plug adapters should be easily available at a local electronics store.
Aug 31, 2005 | Canon PowerShot S10 Digital Camera
Dell POWER SUPPLY Power Supply Logo
74 people viewed this question
Alun Cox
