Question about Ariston Technologies LL65 Built-in Dishwasher
Hello, I have a LL65 Ariston dishwaher and as soon as I press the start 2 green light begin to blink (progamme 3 and 4) and machine does not work. Do you know what is happening?
DRAIN MOTOR IMPINGEMENT
Posted on Feb 26, 2011
Why Ariston lbf51 washing and drying light rapid flash
AL03 - Drain Timeout (drain problems)
LED 1 (washing) and LED 2 (drying) flashing.
Probably the siphon of the apartment is clogged.
  • Remove the drain hose and make sure that is not clogged.
  • Drain water in a bucket.
  • If the dishwasher drains the water, clean the siphon of the apartment.
Dado
May 25, 2014 | Ariston Technologies LL65 Built-in...
The 4th green light on my Ariston dishwasher flashes. What does this mean?
You did not mention what model number that you had but this is what I found after a little digging:
From http://servicetechhelp.com/discus/messages/2801/6823.html?1205974228 :
For future reference, the technician who replaced the control board for me gave me a complete list of flashing LED fault codes for the Ariston LL65 (which are same as Ariston LL64):
001000 Float Switch: Water in Base Pan
001100 No Drain: Dranin Motor Disabled, Filters Clogged, Dramin Hose Blocked
001010 Main Motor Presure Switch Blocked Filter
100100 Control Board: Software of Control Board not Recognized.
000100 Water Valve: Water Valve Diabled <--- This one sounds like your error
000110 Fill Fault: Water Valve Disabled, Turbine Disabled or Control Board
000101 Heating Element disabled or High Limit Open or Control Board
000010 NTC defective or not positioned or control board
000001 NTC defective or not positioned or control board
KEY: 0 = LED off
1 = LED flashing
I also found this for a different model:
http://www.diybanter.com/home-ownership/89945-resetting-controller-ariston-dishwasher.html
No Program Code Fault condition
1 Heavy wash 1000 Operation of flood
protection system
2 Normal wash 0100 Heating
element/Thermistor/Thermostat fault
3 Rapid wash 0010 Drain pump fault or drain
blockage
4 Soak wash 0001 Not filling to correct
level within 6 minutes
Mar 02, 2011 | Dishwashers
I LOST MY INSTRUCTIONS LIST FOR MY REMOTE CONTROL DEVICE....THE MODEL IS JER321
Configuring codes:
Turn on the component that you want to set up.
1.Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
2.Release the component key.
3.If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
4.Within thirty seconds, enter in a 4-digit code number. The component key lights will blink with an upward motion when a code has been successfully entered. In this case proceed to step #5. If the code has not been successfully entered, the componment lights will not blink. In this case return to strep #1 and start over.
5.Test code by pressing "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 2 and use the next 4-digit code listed.
Auto Code Scan:
The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you!
1.Turn on the component that you want to set up.
2.Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
3.Release the component key.
4.If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
5.Press "0" - "9" The green light will blink as codes are sent.
6.As soon as the remote turns your component off, press the "action" key. The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. 7.If none of the codes turn your component off, return to step 2 and start over.
Thanx
Jul 30, 2010 | Jensen Televison & Video
Ariston LI 45 door will not remain closed and will
Strip the door and re-set the switch. Ensure the metal part of the catch on the machines main body is not distorted
Jan 31, 2010 | Ariston Technologies Dishwashers
I hava a i850 -- when I turn it on and it goes thru its set up then the amber light comes on blinks 7 times stops then blinks again 7 times -- cannot stop it -- also when I open it the print head stays in...
Hello.
From Canon:
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
Hope this helps.
Dec 27, 2009 | Office Equipment & Supplies
I have an Ariston LL65 and the eco and rapid light are flashing
I have the same issue, so Dish-washer Ariston LL65 with Eco and Rapid light flashing. Can you help me to undestand the issue and solve it ? thank you, Regards.
Sep 01, 2009 | Ariston Technologies LL65 Built-in...
Dishwaher not working
switch on water appears to run in after a few minutes second and forth green lught comes on and machine stops it is a IDL500 indesit machine
Jan 09, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Ariston Technologies LL65 Built-in Dishwasher Logo
365 people viewed this question
Top Ariston Technologies Dishwashers Experts
Electro Med Services...
Renee Knafel-Bullock
Dado
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
