Question about Pegasus Technologies Pegasus Toilet Paper Holder Chrome With Sand Black
Toilet flushing mechanism not working. pegasus dual flush toilet just stopped working.
  • 659 Answers
SOURCE: New Pegasus Dual Flush Toilet Water does not enter Toilet bowl
There is a small plastic tube that comes from the fill valve and attaches onto the overflow tube on the flush valve. If no water is coming out of that tube, then it is clogged internally. You can remove the tube from the fill valve and take a small piece of wire or a straight pin to try and clear it from the outside. If that doesn't work, then I would recommend replacing the fill valve. They are inexpensive to replace. If you don't know how to get into the fill valve's internal guts at the top, then I would recommend replacement of the valve. One more thing, there also could be a water saver where the outlet is on the little tube I just explained. It is usually light blue, you can remove that and discard it.
Posted on Mar 21, 2009
  • 297 Answers
SOURCE: Pegasus Dual Flush Toilet - How to repair damaged handle
any good plumbing supply company will help you. " Furgoson " i think thats how you spell it.
Posted on Jul 22, 2009
  • 297 Answers
SOURCE: pegasus HET toilet splashes water when it flushes
make sure the fill valve is not cracked,that's the long tower looking thing on the right side of the toilet when you stand in front of the unit. you can replace this part at homedepot. it is called a fluidmaster 400A.good luck.
Posted on Jul 27, 2009
snap101
  • 117 Answers
SOURCE: PEGASUS TOILET DOES NOT FLUSH COMPLETELY EVERY TIME
sometimes if you change the flapper and add more water to the tank by adjusting the fill valve they will flush with more power
Posted on Aug 08, 2009
jyackle5
  • 8197 Answers
SOURCE: Pegasus Dual Flush Toilets
Yesc you can install in the basment
Posted on Sep 16, 2009
How can we stop our 1.5 year old pegasus dual flush toilet from continually running?
Remove the lid from the tank. Verify that the tank is full. Shut off the water to the tank, at the wall. Wait 5 minutes. If the level has fallen in the tank, the flapper valve in the bottom of the tank is the culprit. If the tank remained full, the issue is with either the fill valve assembly or the overflow tube.
--W/D--
Jan 16, 2011 | Foremost Pegasus Series 1940 1-Pc White...
My toilet handle turns but the toilet won't flush. i heard a snap and then it didnt turn to flush
Your attachment to the flapper valve broke...it is either a plastic connection or a metal chain type connection...easy fix.
Please rate me
Oct 13, 2010 | Pegasus Technologies Pegasus Elongated...
Flush mechansim
pegasus products are a home depot brand can get repair/replacement parts there or,there are multi plumbing supply companies online or can check ur local plumbing supply but most flush valves--flapper-parts can be changed or repaired with parts off the shelf at ur local hardware-wal-mart-home improvement stores
Jul 07, 2010 | Pegasus Technologies Two-Piece Round...
Parts for duel flush
Your going to the wrong store instead of home depot Try Ace hardware they will have the parts you need there.Also some of the new toilets have a flapper valve that has a hole in them and they don't work very good so replace the flapper valve with one without a hole in the flapper and one that has a float on it this way the float will hold the toilet open long enough to flush and not stop in the middle of flushing. The handle should be a standard handle. If you need more help ask and I will give you more information.
Feb 05, 2010 | Pegasus Technologies Two-Piece Round...
My pegasus won't flush with enough pressure to complete it...
Maybe the shut off valve is not open all the way .....
can you adjust the fill valve so that more water comes into the tank ... more water more flush !
Dec 07, 2009 | Pegasus Technologies Two-Piece Round...
PEGASUS TOILET DOES NOT FLUSH COMPLETELY EVERY TIME WE SOMTIME FLUSH 4-5 TIMES
Aug 08, 2009 | Pegasus Technologies Pegasus Toilet Paper...
Jul 18, 2009 | Pegasus Technologies Pegasus Toilet Paper...
Pegasus Technologies Pegasus Toilet Paper Holder Chrome With Sand Black Logo
275 people viewed this question
Top Pegasus Technologies Home Experts
john h
Jim Goldsmith
Jim Goldsmith
Paul Carew
Are you a Pegasus Technologies Home Expert? Answer questions, earn points and help others
