Question about Westinghouse LTV-37w2 HDTV
Wall mounting my t.v.
Need to know how to remove stand. I removed 8 screws from the bottom and it still will not move.
Cheak for clip
Posted on Feb 19, 2008
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
I need to know how to remove the bottom from my Toshiba Regza TV so that I can put it on a wall mount.
What you need to do is with the model number GOOGLE to see if you can find a service manual or even a owners manual.
Most of these sets you carefully lay the set on a padded surface face down and look at back-----should be four or more recessed holes with bolts that secure the base to the back/bottom of the set.
Most of these also you have to remove that base to get the back off which is a hint---usually no small screws but bolts.
Hope this helps you
Mar 17, 2012 | Televison & Video
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
How do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Feb 07, 2010 | Televison & Video
How do I take the stand off of the TV? (For wall mounting)
There will be clips or screws on the back of the TV which will need to be removed and the base stand will slide out of the bottom of the TV. Do NOT start taking screws out of the back of the TV without the wall mount with instructions. Sometimes there are spacers that need to be used with the wall mount and generally only four screws need to be removed from the TV. The TV should have instructions on how to prepare the TV for a wall mount as well. All are different, but very similar to do. If you lay the TV face down on a soft surface (do not slide it around) you probably can see what screws need to be removed to remove the TV base. Keep the screws with the stand for later use if desired because you will need them to re-install the case later. Here are two examples;
I hope this helps and good luck!
Nov 12, 2009 | Televison & Video
Removing back stand supports
First I am not to sure about the brand you got there, But if it is not wall supportable you do not need to reove anything but by a wall mount that will hold the bottom in place and yes there are wall mounts for this tpye of arrangment see not all flat panels go on walls thus hence you cannot remove the stand easy. Try finding a wall mount the has a L shape to it, it will hold the bottom of the tv and it comes with a little strap to hold it back into securement. Please do not try to remove the stand I would suggest a diffrent wall mount- Rulds2008 TV expert for 20 years
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 14, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Removing the stand on Insignia LCD 26F TV
My insignia 26 inch dvd combo TV stand can be removed by removing the access cover to your input connection. There are eleven black phillip-head screws. The three bottom screws also hold the plastic base cover in place. Remove all eleven screws and pull the stand out from below. The four philip-head screws on the back center of the TV is for the location of the wall bracket mount. Good luck.
Jan 26, 2009 | Insignia LCDTV26 26 in. Television
Remove base of Insignia ns-ltdvd26-09 lcd tv for wall mounting
Open up the panel on the back of the TV which covers the various input connections. At the bottom of the area previously covered, there are 8 screws (two rows of four screws). Remove them, and the entire stand should now slide right out of the TV. You can then replace the screws back in their holes, so you don't lose them. You do not need to disassemble the stand to do this.
Jul 11, 2008 | Televison & Video
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
Akai 32"
I just purchased this unit and briefly looked at removing the stand though I haven't taken it off yet. Anyways, I think you need to remove the black metal mounting frame from the TV before trying to unscrew the stand (4 screws) from the metal frame. After the frame is off the TV, I think you can then get at a couple of hidden screws to remove the stand from frame. I don't know if the frame goes back on the TV or not.
Dec 01, 2007 | Akai LCT3201AD 32 in. LCD Television
Westinghouse LTV-37w2 HDTV Logo
126 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
