Question about Victor CSR350D Oxygen Regulator
I can't adjust these gauges. How do I do it? - Victor CSR350D Oxygen Regulator
The only part of the gauge that adjust is the tee handle in the middle. the gauge on the left tells you the line pressure to the torch, the gauge on the right tells how much oxygen is in the bottle, usually on a K bottle it is 1800 to 2000 lbs. if you turn the tee handle and the left gauge that tells line pressure does not respond you probably have a bad diaphragm in the gauge. Seek qualified repair man. Thanks
Posted on Feb 07, 2010
Adjust the parking break on a 2010 f-150?
Hi Jeff, Inspect the back plates of the brakes to see if there is a slot for inserting a feeler gauge. I would think there will be. Insert the feeler gauge into the slot and adjust until friction is felt on the blade. Adjust both rear brakes to the same clearance. Front Disc brakes are self adjusting (As should be the rear?)
Nov 10, 2013 | 2010 Ford F-150
Fuel gauge
Hi Van, you can not adjust the gauge but you can adjust the sending unit float arm. Have nice day.
Jul 29, 2013 | Harley Davidson Motorcycles
How do I adjust the idle on 2003 GMC Envoy SLT
ok so for idle on new cars you cant adjust it but for the idle problem take out your idle air control valve and clean it with carb spray or replace it for sixty dollars and if you need more help lemme know
Aug 25, 2012 | 2003 GMC Envoy
I just bought this unit took it home read the instructions loaded the gun with nails hooked up the cables opened the gauge turned on the unit and i waited for the tank to fill with air and the gauge...
There are usually two gages, one for the pressure in the tank, the other is for the regulated pressure in the hose going to whatever tool you have connected. I assume the tank filled up and the tank gage registers pressure in the tank. When you said you "opened the gage" I am guessing that you turned the knob counter-clockwise which would be the normal direction to open a valve. However, this is not a valve, it is a spring loaded regulator device. When you turn the knob counterclockwise you are removing all pressure from the spring which sets the regulator to allow zero pressure in the hose. Turn the knob clockwise to increase the pressure in the hose. I hope this was helpful. Good luck.
Feb 18, 2011 | Porter Cable Air Tools & Compressors
I need to adjust my rear brakes. 95 camaro
ADJUSTMENT
  1. Raise and safely support the vehicle.
  2. Remove the tire and wheel assemblies.
  3. Remove the brake drums.
  4. Set drum-to-brake shoe clearance gauge J 21177-A, or equivalent, so that is contacts the inside diameter of the brake drum. Fig. 1: Set the brake clearance gauge to the inside diameter of the brake drum . . . 88149g24.gif
  5. Position the gauge over the brake shoes. Fig. 2: . . . then place the gauge over the outside of the brake shoes 88149g25.gif
  6. Turn the brake adjuster until the brake shoes contact the clearance gauge. The outside diameter of the primary shoe and the secondary shoe will be about 0.050 in. (0.127mm) less than the inside diameter of the drum on each wheel.
  7. After the adjustment is complete, install the brake drum.
  8. Install the tire and wheel assemblies.
  9. Carefully lower the vehicle, then test drive the vehicle, making several stops applying a firm force to the brake pedal. Repeat this until good pedal reserve is built up.
Jan 08, 2011 | 1995 Chevrolet Camaro
Gauge and knob seem to be leaking on right gauge from behind adjust knob, bleeds of my air when ac is unplugged. Do I order a new gauge/knob adjust? Can I get it from you or how do I order. Is this a...
Best thing you can do is to take it back to the place of purchase, if it is under warranty you will void this if you play with the compressor. Remember to take a copy of your invoice.
Nov 23, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
I need a diagram for the rear drum brake for 2002 Ford Ranger
Copy and paste this into your search window: 2002 ford ranger rear brake diagram
You should see four pictures pop up, select the brake parts diagram or the brake picture.
Sep 03, 2009 | 1993 Ford F150 SuperCab
The print is only clear on the left side of the forms...
Platen Gap Adjustment (Figure 35)
IMPORTANT Only do this procedure if the original equipment shuttle frame assembly or platen has been replaced by a new or
refurbished unit.
1. Prepare the printer for maintenance (page 338).
2. Remove the shuttle cover assembly (page 357).
3. Loosen the platen open belt (page 415, steps 2, 3, and 4).
4. Raise the forms thickness lever (1) to the fully open position.
5. If you are adjusting any model except the 6400-i20, select a 0.011 inch (0.28mm) flat feeler gauge.
If you are adjusting a 6400-i20, select a 0.012 inch (0.30 mm) flat feeler gauge.
ATTENTION Do not force the platen against the feeler gauge. Damage to the hammer tips will result.
6. Insert the feeler gauge (2) straight down between the hammer bank cover plate (3) and ribbon mask (4), within four
hammer positions of the left end of the hammer bank.
ATTENTION Adjust the platen set screws less than 1/4 turn on one side, then check the other side. Adjustment sensitivity is
approximately 0.03 inch per revolution of the set screw. Also, insert the feeler gauge no more than two inches down
from the top of the ribbon mask.
7. Gently close the forms thickness lever (1). As the platen is closing, gently slide the feeler gauge up and down, keeping it
between the hammer tips and ribbon mask. If the feel is too tight as the platen closes, adjust the 3/32 inch set screw (5)
counterclockwise. If the feel is too loose, adjust the set screw clockwise. With the forms thickness lever closed all the way,
the feeler gauge should contact both the tips and the ribbon mask and move with light friction. Shift the gauge slightly to
verify.
8. Repeat steps 4 through 7 at the right end of the hammer bank.
9. After adjusting both sides, check the gap again at both ends. Readjust if necessary.
Aug 25, 2009 | IBM 6400 Matrix Printer
How to adjust the valve adjustments
you need to remove the valve cover and if they are even adjustable there will be locknuts on a stud on one side you need feeler gauges and adjust by loosenin the nut with cylinder in compression sequence tightrn stud with screw driver or allen wrench whichever applies put feeler guage probably.018 between rocker and vale tightrn untilfeeler gauges move with some resistance lock nut tight but be sure you can still move feeler gauge get all cylnders then reinstall valve cover
Jul 21, 2009 | 1992 Daihatsu Rocky
Havin trouble adjusting carburator for a 78 regal 3.8L, just runs a little rich and cant seem to adjust to correct specs at least close enough.
Warm up the automobile to operating temperature then use a vacuum Gauge attached to the intake manifold (not the carb).  Turn the idle adjustment screw "IN" until the car is about to cut out then turn the screw "OUT" 2-2 1/2 turns.  Look at the vacuum gauge if the gauge is steady at 18-22 then you are fine where you are at.  If not adjust 1/8 turn in or out until needle on the gauge is steady.  BTW the car has to be warm and You NEED the vacuum gauge....  Autozone or Shucks has one for loan so you have no excuse not to use one.  DO NOT over-tighten the adjustment screw if you do you can/will break off the tip in the metering passageway and then the carb has to be rebuilt or replaced.(  Yes this can and will happen and you can't just replace the crew.)
Mar 23, 2009 | Buick Regal Cars & Trucks
Victor CSR350D Oxygen Regulator Logo
195 people viewed this question
Top Victor Welding Tools Experts
Bill Boyd
Are you a Victor Welding Tool Expert? Answer questions, earn points and help others
