Question about Maytag Neptune MAH5500B Front Load Washer
My machine puts out codes PF on start up, and when try to run a load half way through about at the rinse cycle it stops and says nF what are these codes please help
  • Maytag Master
  • 43,501 Answers
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Posted on Mar 07, 2011
NF error code during rinse cycle only.
If the unit was working fine before bearing repair, then I lean toward wiring issue. Do a visual inspection of the water valve and all the wires to it. One might have been put in wrong place. If wiring is correct, then maybe a bad water valve. The water valve has multiple solenoids and the one for rinse might be bad. I still think its a wiring issue. Good Luck!
Nov 23, 2015 | Samsung WF337AAL Front Load Washer
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
Flashing fp on my washing machine and stops half way through cycle please help
"PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Sep 28, 2011 | Whirlpool AWM8143 Front Load Washer
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
Pf and of codes comming up on screen
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Samsung Front Load VRT
I've had that same code, the machine completely stops and you have to start over with the load, the repair man samsung sent out still cannot fix my problem. he says there is a defect on these machines, good luck!
Apr 15, 2008 | Samsung WF337AA Front Load Washer
LG WM1814CW Front load washer PF continues to come on and stops cycle
Seen This before Main control board fixed it It would go through most of the wash cycle and just quit no errors but PF
Jan 29, 2008 | LG WM1814CW Front Load Washer
Error code
My problem was simply that the screens where the hoses connect to the washer were clogged with rust from my well water. I cleaned them and we're back in business.
Nov 28, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
563 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
