Question about Garmin StreetPilot C330 GPS Receiver
Garmin c330 GPS
My Garmin c330 is aprox 3 months old, at first it was working excellent , suddenly it wont get any signals and it keeps shutting off. Can you help me?
Thank You
Tom Barnaby
disp154@yahoo.com
  • 3 Answers
Hello, I have had 7 Garmin units and 4 of them where streetpilots like yours.
You can try a reset of the unit. This will restore the unit and you might loose any favorites etc that you have stored. Here's how you do a reset.
"With the unit off, place your thumbnail in the groove located under the Garmin logo on the face plate, gently pull off the face place. Press the reset button and turn the unit back on."
Try this and see how the unit works. If it still gives you the same problem then your unit needs repair. I have sent in at least 2 units to Garmin for repair in the last 2 years.
Thanks
Posted on Feb 19, 2008
Can't find satellite signal
well there's your answer!
it requires a heart transplant ( battery) the average life is 2-3 years depending on use and abuse
Jun 29, 2009 | Garmin StreetPilot C330 GPS Receiver
Mu garmin nuvi shuts off ,
update the device at garmin
update the firmware at garmin
should be good then
Regards
Richard
Apr 20, 2009 | Garmin StreetPilot C330 GPS Receiver
Shuts off, won't charge battery
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 26, 2009 | Garmin StreetPilot C330 GPS Receiver
2 Garmins, BOTH shut off right after they are turned on
>>>>>Posted by judyferris82 on Mar 15, 2009 "My Garmin nuvi 650 stopped keeping a charge for more than 60 seconds. It is still connected to the car charger. Will a battery replacement fix this problem? I have had this unit for 2 years."
<<<<<REPLY: In your case, the battery seems to be getting weak. You must change it.
Mar 15, 2009 | Garmin StreetPilot C330 GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Maps locked
are your maps unlocked when you bought the GPS? try registering the product on garmin website... it should unlock the maps...
Jan 15, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin problems
try contacting garmin they are at garmin.com they should have a dealer near you or take it back to where you bought it they should exchange it no problem as long as you have the reciept hope this helps
Aug 15, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330
You will need to reset the device.
1. On the silver faceplat, under the word "Garmin", there is a tab. Remove the silver-ish fram carefully by pulling on the tab with your nail then by the sides.
2. once removed, press the reset button.
3. Once reset, the unit should work properly.
May 16, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin streetpilot c330 problems
my c330 shuts off after 3 seconds and then wont start back up . on battery or adapter
Apr 15, 2008 | Garmin StreetPilot C330 GPS Receiver
No signal
Try and replace the antenna
Aug 11, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
61 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
