Question about Asko 24 in. D3250 Built-in Dishwasher
The basket at the bottom of the dishwasher has water in it, is this a plumbing problem?
    Brigadier General:
  • 3,513 Answers
Thanks for writing to Fixya.com.
Normally the dishwasher gets to accumulate lots of broken glass, coins, and other debries in the bottom. The impeller that drains the water out gets worn and doesn't work as well. Also check for the clogged drain hoes.
Thanks for contacting Fixya and please accept the solution if it has helped you.
Posted on Jun 02, 2010
  • 62 Answers
As the dishwasher ages and broken glass, coins, ect get in the bottom the impeller that drains the water out gets worn and doesn't work as well. The other cause could be that the drain hoes is partially clogged.
Posted on Feb 16, 2010
GE quiet power 3
First, check the basket that collects junk at the bottom. Another likely problem is a clogged line to the drain that usually plugs into the garbage disposer. You may try to disconnect that hose and plumb it with a coathanger or the like or hook it up to a shopvac to break the clog free.
Apr 25, 2014 | GE Dishwashers
Electrolux dishwasher overflows
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 09, 2012 | Dishwashers
My Frigidaire dishwasher has dirty water.standing in bottom. Dishes are not clean
Aug 08, 2012 | Dishwashers
My samsung DB.710DB dishwash has standing water after a complete cycle, I've removed the baskets and arm to try to get to the drian screen what next
Check your drain hose and the house plumbing the drain hose enters for blockage. make sure your drain hose isn't severely kinked.
Feb 06, 2011 | Samsung Dishwashers
Water isn't coming out, and after a while, a slight burning smell arises. Any suggestions?
When you find that the dishwasher is not draining fully, you'll have to take up certain steps of plumbing to assure that it begins to function properly again. Here's how:
Identify Type
First of all, identify the type of dishwasher that you have. Is it a forward reversing or direct drive dishwasher. A direct drive dishwasher is one in which the dishwasher simply drains out the water. Whereas a forward reversing dishwasher has a motor in it that will stop and start to move in the opposite direction. If there is a problem with the motor, then the end result is that of the dishwasher not draining fully and that's where the problem lies.
Check for Garbage Disposal
Sometimes, a garbage disposal is installed into the kitchen area that shares it's space with the dishwasher unit. Check to see if the knock-out plug of the garbage disposal was removed before installing it. If this was not done, then simply remove it and the dishwasher should work as good as new.
Check the Drain
More often than not, the clogging of the drain will lead to dishwasher not draining all the way. Check to see if the water in the sink takes a long time to go into the pipe and whether it is accompanied by water bubbles. If this is the case, it means that you need to unclog kitchen sink Disconnect the pipe and check to see if there is any debris or build up. Then use sink drain repair to get rid of the problem.
While you are at it, check to see the pipe that separately connects the water supply to the dishwasher. The build up might well be in this pipe.
Inspect the Dishwasher Basket
Check the dishwasher basket next. Slowly and gently, disconnect the basket and check to see if there is any gunk and debris build up in this. If there is plenty, this might be the problem of why dishwasher not draining completely. All you need to do is clean all the parts thoroughly. But be careful not to exert any pressure or force and bend the parts out of shape. Remember you have to fit them back again. Clean the basket with wet rags and then fit back.
Dec 18, 2010 | Whirlpool Dishwashers
My KichenAid KUDS011 has functioned well until this morning. When I push any of the buttons on the keypad, nothing happens. I noticed there is still water in the bottom of the dishwasher from the last...
If the drain or screen are clogged, the machine may no operate.
Unscrew the the 2 long screws on bottom, remove the basket, there may be a flapper under the basket,
For pics, see here: http://www.contractorssolutions.com/dishwashers.htm
Mar 15, 2010 | Dishwashers
Bottom spray arm on our LG dishwasher LD-14AW3 won't spin.
sounds like no water going into the machine. you may need a water inlet valve.
Nov 07, 2009 | LG Dishwashers
Water left in the bottom of a hobart (kit aid) dishwasher
Drain valve not opening, kinked or blocked drain hose. Remove the hose from the sink plumbing and look for debris. try running the drain hose into a bucket to eliminate a domestice plumbing issue, but hold onto it when it starts draining, or you will have a wet kitchen. Timer contacts may not be opening drain valve.
Sep 15, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Small amount of water remaining in bottom basket
There is a screen in the drain that is plugged.
Apr 15, 2009 | Viking DFUD042 Built-in Dishwasher
Hub nut and strainer basket
Call a service tech!
May 19, 2008 | Dishwashers
Asko 24 in. D3250 Built-in Dishwasher Logo
136 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
