Question about HP Photosmart C6180 All-In-One InkJet Printer
C6180 Turning off, on,off, on etc.
I am having issues with my printer turning off, on, off, on, etc.I have tried the resetting pressing the # and 6 keys and also the # and 3. Any other suggestions?
  • 4 Answers
Try the instructions provided in the web link below
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01330181&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Regards
Mithun T
Posted on Feb 05, 2010
How do I reset displaylanguage to english HP C6180
You can do a reset on your printer.Unplug the power cord of the printer.Press and hold the # and 6 buttons together and then plug the power cord back into the outlet.Keep holding the 2 buttons until the display goes blank or RESET is displayed.If the printer automatically turns off, turn on the printer.The printer should start up and you will be able to select language code.
Oct 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
Error 0xc18a0101
I think this may be an ink problem try resetting the printer
Follow steps below to reset Hewlett-Packard (HP) All-in-one Printers (products with keypads only).
Resetting your printer will reset your printer to its original state.
For products with keypads on the control panel:
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold “# and 6′ keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
Mar 25, 2010 | HP Photosmart C6180 All-In-One InkJet...
Photosmart C6180 All in one printer will not start although live
Strange because I have the same issue, and I've had this printer for over 3 years but the problem just started about a month ago.
I reset the printer by: 1) Unplug power to the printer 2) Hold #6 on the keyboard 3) Plug power cord back in while holding #6 Eventually (10 seconds?) the printer will shut down. Once it does, release #6 and power up the printer again.
Warning: This reset all the configuration settings.
This works for me, but there is still an issue because I have to repeat this every time I turn off/on the printer.
Mar 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
Printer never completes the startup sequence, it
just reset the printer
unplug the power cable without turning off the printer
press and hold # & 9 Button
while holding down pluggin the Power cable and it will reset the printer (everything)
**** U will lose everything that has been saved in the printer settings
Oct 16, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 boot - init loop / power on-off loop
The Formatter board (main logic board) is faulty. You need to take the printer in for repairs to HP, in my experience though it usually works out better to replace the printer.
Aug 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
I have a 2 yr. old C6180. It will not turn on as of yesterday. Power is coming from the socket as the little green lights on the plug are lighted. I have unplugged all cords and plugged them back in but...
try unplugging power cord and holding #6while your plugginmg in the power cord hold the button down until you see the display lights turning on and release if you are printing wirelessly you will have to do the wireless setup wizard again.
if that doesn't work try plugging it directly to the wall
if all else fails it may be the printer
Jul 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
My HP c6150 keeps turning off and on. I have
HI
i have a sure shot resolution for this which worked John Oneill who had the similar problem ,
try this out
The best way to deal with this issue is making sure that the printer isn't plugged to a surge protector
and performing a partial reset
youcan achieve this by unplugging the power cable and pressing # and 3 andthen replugging the cable and hold the # and 3 buttons until you seethe lcd lit up
also try the # and 6 and then # and 9 to reset it to factory defaults if the previous doesnt work
Jul 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
Cannot turn printer on
might as well do a reset:
for partial reset:
1.unplug the power cord wthout turning the printer off
2.while the cord is unplugges, press # and number 3 simultaneously
3.hold the 2 button for 10 seconds while inserting the plug back
4.release the 2 buttons when the printer reinitialized.
for semi-full reset:
follow same steps but press # and number 6
semi full means the printer is set back to factory settings or default settings.
Mar 04, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error Code 83C00029 with Clock display
Try to reset the printer by unplugging the power cord without turning off the product and wait for 30 seconds. After that try to press and hold the power button for 5 seconds. Then press and hold the pound "#" key and the number 6 key on the number pad for faxing at the same time while plugging in the power cord. Release both buttons when you are prompted on the display like "Semi-full NVRAM reset". It would reset the printer to its factory settings
Aug 21, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 AIO Scanner Failure
hi,
The "Scanner Failure" usually refers to the hardware of the printer. try to do a reset.
Performing a semi-full reset of the All-in-One
  1. Use the On button to turn on the product.
  2. Remove the power cord from the product.
  3. Press and hold the # and 6 buttons.
  4. While holding the buttons down, connect the power cord to the product.
  5. Continue to hold the buttons down until the color graphics display becomes blank, then release the buttons.
  6. Use the On button to turn on the product. The reset information appears on the color graphics display.
If the issue still not resolve, please call HP 1-800-474-6836. Also check the warranty status of your printer.
thank you so much.
adonscott
Jul 25, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
62 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
