Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Sometimes my dryer heats and sometimes it's just cool air. I have to dry it over and over. Please help!
3 Suggested Answers
SparkyNZ
  • 43 Answers
SOURCE: most of the time it takes two cycles to get load dry
Sounds like an intermittent fault on the heating coil (or possible intermittent pilot failure). Or thermostat out of calibration (but I doubt that last one is likely)
This fault sounds a bit dodgy and I'd recommend getting a qualified appliance serviceperson to troubleshoot this.
Posted on May 10, 2009
SOURCE: have heat & tumbling but will take 3 hrs to dry a load/ no jeans
Likely that your Dryer vent is clogged up. Especially if its long. Check that by hooking up a shopvac to one end with duct tape to seal any air leaks between the vent pipe and the vac hose. Turn it on and check the other end of the vent pipe for suction. If its faint then there may be a crapload of lint in there or a birds nest. Compressed air in the pipe with an agitating device may work or shopvac hose if run is short. Be prepared for a mess on either end.
Heather
Posted on Jul 28, 2009
Put the cloths in the dryer like usuall and waited for peep to let me know its dry. but when i heard the peep assumed the cloths will be dry, the cloths were just like i got out of the washer, wet. it is...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 02, 2011 | LG DLGX8388 Gas Dryer
Kenmore Series 80 Dryer not drying with heat. Cool air only
heatman101
Dec 27, 2010 | Kenmore 62802 Electric Dryer
Regardless of settings, my Amana Commercial Dryer does not stay hot all the time whilst drying. Sometimes when I open the door, the air clothes are cool to the touch. Then some time later they are hot...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 26, 2010 | Amana Dryers
No Exhaust? Very Damp-not dry clothes
i would check for further blockage. also check the blower fan to make sure it is blowing properly. sometimes the blower fan can wear on the motor shaft and slip, thus reducing the air flow considerably. sometimes i have found the blockage just at the point of the blower fan.
good luck; jay
Jan 04, 2010 | Maytag MDE6000 Dryer
The dryer heats up right away then cools off. Takes a long time to dry.
Sometimes blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Nov 26, 2009 | Roper RGX4634KQ Gas Dryer
The dryer doesnt get hot enough to dry clothes
Pull the dryer out and remove the lint hose . Turn on the dryer and feel if there is good air flow and if you feel heat . If there is good air flow and heat , dry a load of clothes , to see if they dry normally .
If there is not good air flow , then the blower wheel is probably stripped and needs to be replaced . If there is good air flow and heat , then the problem is in the vent ducting , between the dryer and to where it vents to the outside . Dryer could be pushed back too far , causing the hose to " kink " , restricting the air flow to the outside .
Remember , a dryer either heats or doesn't heat . If no heat , then a dryer problem exists . If heat , but dryer does not dry , then a vent problem is the cause ( except for maytag , which the blower wheel sometimes strips out ) .
Nov 08, 2009 | Maytag PYE2300AY Electric Dryer
I have a gas dryer. Dryer heats up but doesn't dry clothes completely all the time. Sometimes I have to run it 2 -3 times. What do i need to replace? Maytag Performa Model # PYG2000AWW REV. 10 Serial #...
I got cut short.. and disconnected...so if this is a repeat, please forgive me:
Dryers 101
1. Heat alone does not dry clothes
2. Air alone does not dry clothes.
3. Only dry, heated air passing over and through clothes will dry them...
I recommend the following:
Set the dryer for "Air Dry".
Go outside and check the dryer exhaust.
Confirm that the exhaust is spewing out lots of air.
If it is, then you have a need for a technician to inspect everything - in person.
If it is NOT, the you need to determine the clog - or reason that air is not moving through your dryer, clothes and exhaust system.
ONLY 2 possibilities exist:
1. Fan motor is frozen and needs replacement....or
2. Duct/exhaust is clogged with lint and will not allow air to pass through.
Please check for both, clean/clear/fix as needed.
Nov 04, 2009 | Dryers
Dryer is not heating, only blowing cool air
Its best to take it to an appliance repair man. This is usually an electrical problem related the the board or the relays behind the control panel. Beware though, sometimes its cheaper to buy a new one than fix the old. Hope this helps.
Sep 13, 2009 | Uniden Cordless Phone
Dryer won't start
The timer mechanism is faulty. replace it asap.
Jul 23, 2009 | Roper RES7646KQ Electric Dryer
The dryer sometimes heats up to dry the clothes and sometimes it is just cool air. The drum still turns
I had this problem on my Hotpoint dryer and it turned out to be the timer.
Jun 16, 2009 | Hotpoint Dryers
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
11 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
