Question about Quartet gbc CC85 CC Shredder
My shredder motor had burning smell i open the cover of the motor there was one blac wire out i dont know where to put that black wire if u can provide me direction or the map of the interior motor Thanks
We have a cross cut shredder MOPD29CC which has the overload warning light on and a very obvious burning smell. What is the problem?
the problem from the smell and light is that the motor is burning out
take it in for a service repair before it gets so bad that a spark sets fire to the shredded paper
Dec 14, 2016 | Cross Office Equipment & Supplies
I would like to know what makes that the Jeep smoke after rearranging the vacuum lines is it the EVAP system on HBO or the engine vacuum lines vacuum lines
the book is free,
and real
and posted here over 300 times, search much.
all that is covered in the SM. (how to put it back as it was new)
no clues as to what the smoke is.
or where it emits from. (tail pipe end)
white smoke or black
black is rich running.
white can be burning oil and smells like burning oil (lingers)
white can be steam,aka, antifeezes burning, goes the vapors dont linger like oil smoke does and smells sweet, unlike oil smoke.
EVAP is only FUEL vent , fumes. gas fumes.
there are lots of vacuum lines
to engine
evap
brake booster
the engine hood sticker covers the majors, (smog related, )
SM , serv. man. click WK and read.
free
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
Dec 11, 2016 | Jeep Cars & Trucks
Replacement engine warranty
Are you putting too much clothes in at once? Bad motor. It could be bad bearings causing the motor to go bad.
Dec 28, 2014 | Washing Machines
Wiring diagram for a Fellowes PS 60CC shredder
I own a Fellowes PS 60 shredder.
I DO NOT THINK THE LINK WILL HELP YOU, BUT AT LEAST YOU WILL HAVE IT.
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Jun 29, 2012 | Fellowes Powershred PS-60 Shredder
Our shredder is a Kobra 240 ss5. It will turn backward but not forward. The circuit board has a burn on it. Can I order a new circuit board for it?
By now you mave resolved your prob however.... yes you can order replacement PCB's.
The part # is 27.045
Before you just replace the "blown" pcb you should also check the motor; or, when you install the new pcb you will just blow the new pcb also.( if the motor is faulty.)
To check the motor you will need a multi meter.
There are 3 wires...black, red & blue wires. Using black as the common wire measure black to red..this should be approx 6 ohms, the same when you measure black to blue. Between blue and red you should get about 12 ohms. If you get a short on any of these readings then the motor will have to be replaced BEFORE YOU REPLACE THE PCB.
You don't say what country you are in..these readings and the part number are good for the USA &Canada.
The part # will be different if you have the 240 ss5 E/S model.( has a blue light on the panel.)
Hope this helps.
Apr 05, 2011 | Elcoman 240 SS5 Shredder
I have an office max shredder OM99729 that quit working. the motor runs but it won't pull the paper into the shredder. I opened the cover and found the gear is stripped that runs directly off the motor....
I have the same unit witht he same gear off the motor that has a couple of teeth srtipped. Anyone out there know where to get a replacement gear?
Thanks...
Dec 22, 2010 | OfficeMax 0M96431 Shredder
I was driving down the road when all of the sudden i smell burning plastic.I pulled over turned my radio down stepped out popped the hood .I didn;t see any problems i cranked my car and my radio was dead...
arent you still under warranty?! check the positive terminal of the battery(common gm issue). check the wiring at the starter motor and look for burned wires. if there is consider the warranty. BY THE WAY, IF YOU HAVE HEAVY SMOKE AGAIN, DO NOT "POP" THE HOOD! IT CAN CAUSE AN AIR FEED AND POSSIBLY IGNITE A FIRE IN YOUR FACE. ive put out car fires in iraq. its not fun getting or treating people for burns. let me know if you need further assistance. cheers
Jan 20, 2010 | 2007 Chevrolet Cobalt Coupe
It stopped as I was pushing leaves through it
there might be a red button (overload) on the motor.
Nov 07, 2009 | RTO Deluxe Electric Leaf Shredder
Jammed shredder
First UNPLUG THE MACHINE.
Unscrew four (4) screws, two in front underneath top cover and two in back of top cover. BE careful not to disconnect any wires.
Rotate motor gear or belt in reverse to remove jam. Do not put oil on paper because it expands the paper thickness and only makes it worse.
Sep 02, 2008 | Fellowes Powershred 480 Shredder
Hsm 125
Sounds to me like a the main control board is fried. That smell was probably a resistor or a rectifier burning. The fact that you hadn't oiled the shredder in 3 years didn't help, probably put an extreme load on the drive motor. You might be better off, shopping for a new shredder, unless this is a high end industrial strength model.
Sep 05, 2007 | HSM 125.2hs Shredder
Quartet gbc CC85 CC Shredder Logo
396 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Pie-man
Level 1 Expert
graybeard32301
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
