Question about Ruud Heating & Cooling
How do i tell what ton my ac condensing unit is by the model number on a ruud?
  • 1,253 Answers
Get me the model number and I'll tell ya.
Posted on Feb 03, 2010
  • alberto30047 Mar 23, 2011
    ebd2x30ba1
  • Dennis Boxerman Mar 24, 2011
    in most all cases, the 30 is the btu rating. That is, 30K btu or 2 and 1/2 tons cooling. The numbers off the compressor could confirm that as it is designed to "Pump" a certain amount of refrigerant that is equated to the tonnage of the equipment.
What are the tons of a RUUD AC HANDLER MODEL UBHA-17J11 SO SFFA SERIAL NUMBER MOO500 03485 and what type of CONDENSER & TONS CAN IT HANDUE WITHOUT PROBLEMS?
You can find the tonnage in the model number which increases by increments of 12, so if the model number is 24 =2 tons. Model number on your a/handler is 17. Thats a ton and a half. Really should match the evap and condenser for the best efficiency. ...
Sep 24, 2015 | Ruud Heating & Cooling
Where can I get a service manual for a Ruud Ac model UAPC-42JAZ
Go to the following web address:
www.servicemanuals.net/‎
Oct 07, 2014 | Ruud Heating & Cooling
Trying to figure out how many tons my ac is. Ruud ubhc 14j065fd
it souds like that is a 5 ton rheem and ruud are very weird hat way call this number and they will tell you forsure 865/546-7941
Sep 11, 2010 | Ruud UBHC Air Conditioner
We are replacing a 22 year old ruud UACC030/36AHW38 (this is listed as the equipment being removed from our home by one of the companies who has given us a quote). One of the companies is telling us that...
Hi, there are 12,000 btus per ton of cooling. You go by the numbers in the model number. I see you have a 030 which would be a 21/2 ton. I also see a /36a which could stand for a 3 ton, but its the 030 number you want. It is a 2.5 ton unit, no question! 2x12 is 24+6=30,000 btus, a 21/2 ton unit. Hope that cleared it up for you.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Jul 12, 2010 | Ruud UBHC Air Conditioner
I need to find out how many tons my condenser is the model number is ckl49_1A
Thats not the correct number, go to the outside of the unit and get both model and serieal number again. Hint: if you see a 024 it is a 2ton, 030
is a 2.5 ton, 036 is a 3ton, 040 is a 3.5ton,048 is a 4ton
Jul 04, 2010 | Ruud UAKA042 Air Conditioner
I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Jun 28, 2010 | Ruud Handler Air Conditioner
Can't identify ton rating of condenser unit
the model number tells me it's a 4 ton. the 048 is what it gives it away. 1 ton is 12,000 btu's . 4 ton is equal to 48,000 btu's
May 23, 2009 | Heating & Cooling
Need info for RUDD upflow oil furnaces
Contact your nearest Ruud DISTRIBUTOR, usually The Noland Company, and ask them if they could go into the historical documents and print out or send you the files for the wiring, spec's and parts breakdown. From the model number, that unit is rated for 3 tons of a/c. You can find a 3 ton coil that will fit in the space and get a straight cool condenser of 3 tons cooling and swap thermostats so it brings on the furnace and fan in heat and the condenser and fan in cooling. Or just add a simple White - Rogers model 444 for the cooling. Ron
May 06, 2009 | Ruud UBHC Air Conditioner
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Heating & Cooling Logo
429 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
