Question about Microsoft Windows XP Professional
Why is firewire is listed under network adapter?
    Scholar:
  • 42 Answers
Firewire is a robust technology that does a lot of things including networking. You can see here from the Internet Society how network connectivity can be achieved for both IPv4 and IPv6.
IPv4 is what most of the internet currently uses and IPv6 is the replacement that is quickly up and coming.
RFC 2734 describes how IPv4 works over Firewire here at http://tools.ietf.org/html/rfc2734 and RFC 3146 describes how IPv6 works over Firewire here at http://tools.ietf.org/html/rfc3146.
In Network Connections it is perfectly normal to see Firewire listed as a networking device. It can simply be ignored or disabled. If you disable it, it will continue to work for cameras, scanners and other devices.
Posted on Feb 03, 2010
    Sniper:
  • 68 Answers
Hi....
1394 device is listed under network connections only whne the drivers of the network adapter are not installed properly.
please reinstall the network drivers.
Posted on Feb 02, 2010
How to Know if a Computer Has a Wireless Networking Card?
I'm not 100% but think that quite simply if nothing shows up under the wireless connectivity options and you are in range of a known wifi netowrk, then possibly not.
On a PC you can go to "control panel" then "system" "device manager". Then look under "Network Adapters" and expand the list of adapters. Look for "wireless," "802.11," "WLAN" or "Wi-Fi" anywhere in the list.
If that is there then you have a wireless adapter installed and will be able to connect to a known network if there is a networking card present.
The other possibilty is you have a card but you have no way to see the local network. if this is the case then card is damaged or the connection to the card is damaged, which sometimes occurs in laptops from being bumped around.
Oct 18, 2016 | Computers & Internet
How do i know if my desktop has wifi
Assuming that you are using the Windows operating system, right click on the My Computer icon (on the desktop or in the Start menu).
Select Properties from the drop down list.
When the System Properties window opens, select the Hardware page tab then click on the Device Manager button.
In the Device Manager window, expand the Network adapters line (click on the + sign on the left) and look at what actual hardware adapters you have installed.
Most desktops do not normally have wireless adapters installed by default so you may only see any Firewire (1394) and Ethernet adapters.
An alternative approach to using the Device Manager would be to download and install a copy of the free Belarc Advisor utility which will take an inventory of your installed hardware and software, then display this in your default web browser. You can then look at what network adapters are installed that way too.
Dec 24, 2011 | HP Computers & Internet
Does this card work on Windows 7 64 bit desktop?
It's made for Windows XP & 2003.
You can try using those drivers.
Jun 27, 2011 | Belkin Components FireWire 800 and USB...
Getting a no network adapter detected message after a nearby lightning strike. No Network folder listed under device manage either. Windows ex sp2
this network cards are the most commun problme on computer if the card is not detected on device manager remplace it
they cost about 10 to 15 dlls
May 04, 2010 | Dell Ethernet Card Network Adapter
I want to download video from Canon HV10 to computer, the Zoombrowser only has stills, can you help
How are you connecting the camera - often this is the case if you use USB - to download the video you need to use the firewire connection - sometimes known as IEEE1394
All the manuals and info is here http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=369&modelid=14059
Page 64 of the manual shows the connection and refers to DV cable, and talks about using the DV for video IEEE1394 If you are unsure if your PC has a firewire connection look for this type of connector http://img.tomshardware.com/us/2004/04/02/go_external/i.link.jpg OR Have a look at device manager Press the Windows key (bottom left of the keyboard} and at the same time press the R key, now in the search box that appears - type devmgmt.msc - on the screen that appears look for network adapters, use the + sign to open the network adapters - and you should see an item with 1394 listed if you have a firewire connection
If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more
Mar 25, 2010 | Canon HV10 HDV Digital Camcorder
My computer does not recognize the adapter
You will need to check the device manager.
Open the device manager.
In that list you will see the option network adapter.
Under network adapter you will see your adapter.
right click and go to properties. you will get the exact error message.
If you don't seethe adapter under network adapter list.
then search for the option " other devices " there might be listed.
Unplug the adapter and check if you any change in the device manager list. Plug it back in and check if you see any change.
The change in the list will be the adapter. right click on it and check the error message under device status.
Click here for more info about networking
Dec 01, 2009 | Netopia 3-D Reach (TER/GUSB-N1)...
Replaced hard drive on HP dv4000. Install XP Pro and drivers from recovery disk. Updated to SP3. Do not have 1394 net adapter listed in network connections. Connected external hard drive to firewire port...
I would check in device manager (control panel) and see if the network card is listed. It probably has a yellow exclamation point next to it. If there is an exclamation point there, then right click the card and click uninstall. Next, using your wifi to access the internet, download the latest network card driver from the PC vendor website / Motherboard vendor site / discrete network card site.
Install the network card driver and you should be back in business.
Jul 09, 2009 | HP A6795A#0D1 Network Adapter
Np wireless connection..
hey
which laptop is it or if it is desktop check under device manager if we have the ethernet controller available under other devices
check their properties and go to pcidatabase.com and find out teh manufacturer for the device and download the drivers
Apr 13, 2009 | Computers & Internet
Wireless connection disapeared from computer
Hello!
I am not sure exactly where you are checking for Wireless connections.
Anyhow, now a days we are hearing many Wireless adapter missing from Device manager issues.
Please get back to us with the Brand name of your laptop, OS installed.
Also check in Device manager for Wireless adapter.
Please follow these steps to open Device Manager:
1. Right Click on 'My Computer' icon on Desktop and choose Properties.
2. The System properties Window opens.
3. Click Hardware tab and then click the Device Manager button.
Expand + Network adapter and check if the Wireless adapter is listed there or not.
If it is not listed there, then the issue is with the Wireless adapter itself.
This is most comon issue in HP COMPAQ notebooks.
if you are not aware of the Wireless adapter under + Network adapters in Device manager, then get back to us with the complete information under + Network adapter.
So thatI can help you in better way
Aug 09, 2008 | Computers & Internet
General Networking question
lets see here, your NVIDIA thing is for your ethernet port in your computer.
the wireless PCI adapter, is well, a wireless adapter, its used to connect your wireless, and a 1394 Net Adaptor Connection is basically Win2k/XP's way of telling you that you have a Firewire interface installed in your system.
so, if your going wireless, you dont need NVIDIA, and as your device manager shows that it has a red x on it, it shows that its disabled. as for everything else, i wouldent worry about it.
May 08, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
127 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
