It lights up but no response to TV. Cannot program. HDMI connected
  • 443 Answers
Have you selected the correct HDMI input on the TV-
press the input button on your TV or the TV remote to select the correct "input".
Good luck !
Posted on Feb 02, 2010
How do i program my sony dvd player dvp.sr200p to work on my philips tv
No special programming is required. Connect the DVD player to the TV using an HDMI cable. Note which input jack you used on the TV (example: HDMI 1 or HDMI 2, etc.) Turn on the DVD player and insert a DVD disc and play it. Turn on the TV and select the input you used to connect the DVD player (example: HDMI 1 or HDMI 2, etc.). You should now see and hear the DVD disc playing. Most settings are pre-set at the factory so everything will work without adjustment. However, both the DVD player and the TV have a Menu where you can adjust settings for picture, sound, etc. if desired.
Jan 01, 2016 | Sony DVP-SR200P DVD/CD Player
How do i play movies from a tablet i plugged a hdmi cord but no response
You mentioned a "usb cable" but you cannot connect an external display to a tablet's USB ports. If you are using an HDMI cable, then you will need to select which display is active through the tablet's settings (Android) or control panel (Windows) and also make sure that the TV is set to the appropriate HDMI connection through the input selection.
Dec 31, 2014 | Toshiba 19SL410U 19 LCD TV
WE JUST BOUGHT ROKU , HOOKED IT UP , CAN'T GET ANYTHING ELSE TO COME UP
You must match the TV's input connections and the Roku output on your remote. This means if the Roku's output is connected to your TV's "HDMI 2" (or A/V 2, etc.), you must be able to select HDMI 2 (or A/V 2, etc) on the TV - either with your remote or pressing a button on the TV itself.
Sometimes, the TV will skip over unused inputs when it was first set up. This is done to reduce the number of button presses to go from say "HDMI 1" to "HDMI 4" by programming OUT the HDMI 2 & HDMI 3 choices.
You'll need to program IN the input that your TV uses to connect the Roku if it isn't already available. You MUST connect cables properly if not using HDMI. RGB is Red-Green-Blue and must be connected to RGB jacks at the Roku and TV for a picture and the the White & Red (left and right) audio must connect the the corresponding Red / White audio jacks - or it will provide strange results.
Make sure the power plug is connected to an outlet that is ON and connected to the power jack on the Roku box itself. Unless you have a defective Roku box or TV, it SHOULD work. You can try using a different HDMI or A/V jacks on the TV to determine if it is the TV jacks or not.
Sep 10, 2013 | Televison & Video
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Trying to connect HP M9060N and Sharp Aquos through Denon AVR 1508, only get 'no signal' response. Have HDMI 1 set to DVD, HDMI 2 to AUX, HDMI 3 to TV, which is order of HDMI outlets on receiver.
Depending on your TV inputs, you are better off to run video componenets through TV first then, connect TV to reciever via digital optical. Recievers have video pass through but, noyt the best route. You can use TV's menu to choose what you watch and, only have the one output from TV to reciever. Make sure you scan through TV and reciever menus to make sure you are selecting the right channel.
Jun 21, 2011 | Denon AVR-4306 Receiver
Tv will not stay on but if u turn it on,green light comes on and you hear tv click on but goes back off....
how are you connecting your tv to view programing? the cable/cables that connect from your receiver to your tv. are you using a coax cable? are you using rca? are you using hdmi? the first pic is a coax cable, the second pic is a rca cable and the third is hdmi.
Nov 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cannot connect ps3 to tv connected with hdi cable but no response, just saying not supported or no signal
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps3 will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
Jan 01, 2010 | Televison & Video
I have my PS3 and TV hooked up to the HDMI ports. I have programmed the unit to show them under TV and DVD respectivly. When I change the source to TV or DVD, nothing shows up on my TV as expected
Sounds like you hooked them both up to HDMI input ports. Make sure that the PS3 is connected to an HDMI input port on the AVR-1508, and that the TV is connected to an HDMI output port (not an input).
Oct 21, 2009 | Denon AVR-1508 Receiver
No signal on my TV
try connecting the ps3 to the HDMI only, now when the ps3 is off and all but the single red light is on rest your finger on the on button for about 8 seconds, as soon as you touch it it will turn on but just wait a bit and you'll here the a second beep- this should reset your ps3's video output settings. Try it out, it works for me when i go back and forth from av to HDMI.
Please remember to rate my response if helpful.
May 30, 2009 | Sony Playstation 3 (PS3) Console
Trying to connect a new high definition digital box to tv with hdmi but keeps flashing and saying its searching
Turner,
I looked through the Hitachi web site for your owners manual, no luck. If you're trying to use HDMI as the type of connection from your digital TV box to the TV, keep in mind that HDMI is not a network, but a one way point-to-point connection. That said, make sure that the cable is seated firmly at both ends. Next, grab the owners manual from the cable box and make sure it is programmed to be sending HDMI. The cable box MUST be programmed before it will send HDMI. The TV is most likely ok, check the cable boxes programming.
If the cable box has a regular "video out" connection, temporarily use that to be able to "see" the cable box and go through it's menus. Find the HDMI section, turn that signal on and you should be good to go.
Jan 21, 2009 | Hitachi 55HDS69 55 in. Plasma Television
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
