Question about Westinghouse TX-47F430S 47 in. LCD TV
Need to replace fuse in the power supply board. can't get the old fuse out.
    Genius:
  • 1,011 Answers
The picture relates with your board. Your need to de-solder the heat sink cover to get access to its fuse. Open it carefully and replace the fuse.
good luck
Posted on Feb 02, 2010
3 Suggested Answers
SOURCE: Testing the BN96-00249A power supply in an Akai PDP4294
You can get the schematics for the bn96 00249a smps here in pdf format. http://www.wimtv.be/techniforum/files/ps42p3sx_ch._d58a.pdf
Posted on Aug 14, 2007
  • 8457 Answers
SOURCE: sylvania 6842pe blew fuse, replaced fuse, and
Yes,replaced all the boards that related to the power supply.Useally completely dead,it effect all the ICS in the boards,never able to tell which boards.U are not a tv tech.don't do this everyday's will not have skills or any idea which board is dead.
Posted on Apr 06, 2010
How do I know if it is a board or power supply issue?
Without proper test equipment it is hit and miss. I can say that it is most likely the power supply. The only possible way you might be able to check is to unhook the other boards and try again. If it does blow out the fuse then it is the power board. BUT the unit might not power up at all if you unhook the other boards, especially the control board.
Feb 05, 2016 | Emerson 22" Class LED-LCD 720p 60Hz HDTV,...
Samsung ft-p5084 plaza tv went blank. No power at all.
If that fuse is blown chances are its because the Power supply has developed a short. The power supply will need replacement. You can easially install a power supply yourself just a few screws and couple of wire sockets and the old board pops right out. You can get the power boards from www.tvcircuitboards.com
Feb 09, 2013 | Samsung FPT5084 50 in. Plasma HDTV
It's 5 years old we shut it off last night and it doesn't have power. Is there a fuse inside that maybe blown out?
The fuse never died on these tv.But the fuse on the power supply board,that the board,where the power a/c cord plug into it.The power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 07, 2010 | Televison & Video
MY PS3 WONT TURN BACK ON
Either power supply problem or blown surface mount fuse on the main board. First check all SMD fuses on the main board, and the fuse on the power supply board. If the power supply board fuse has blown replace it and try again, if it blows again you need to replace the power supply. If the power supply seems OK check all SMD fuses on the main board. There are 7 on the V3 and about a dozen on the V4 / V5 / V6.
Good luck...
May 30, 2010 | Sony Playstation 3 (PS3) Console
Hi i changed colour cartridge tried trial run printer died; changed fuse in plug; still no power any suggestions please
in the printer there is a power supply board.there is a same type of 3amp fuse on the power supply board.if there is any kind of overheating in the power then the fuse in the plug and fuse on the power supply board blows out.in some cases only fuse on power supply board blows out.this fuse is placed on the board for safety reasons.because in the older model printers when this short circuit problem was happening at that time whole board used to blow out.so in the new model of printer a fuse is placed on the board ,so if any overheating or any power outage or any short circuit occurs.the fuse blows out instead of whole power supply board. You just need to replace the fuse on the power supply board by disassembling the printer.the power supply board is the green color square shaped board.its the board to which your power wire of printer is connected. the fuse is available at any local electric hardware shop.its not any special kind of fuse. This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | Lexmark X5150 All-In-One InkJet Printer
Wont turn on. is there a fuse or something inside
The unit has fuses but you will probably not find any bad ones. I would check the power supply for problems. If you unhook all but the control board it should produce all it's voltages which are usually marked by the connectors. If voltages are good the problem is in one of the boards which are unhooked. It would need replaced. If the voltages are not there the power supply board needs replaced. Let me know how you make out.
hardrocko
Jan 31, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Cannot locate the fuse in the liteon power supply
The fuse is internal, and soldered to the circuit board. It can be replaced by soldering - an old-timers trick is to get a new fuse (with pig-tails) and just solder in parallel with the old - no removal needed.
Jan 31, 2010 | Lite On LiteOn 150W LPX Power Supply...
Does it have a fuse we got hit by lighting and now the Pc wont power up
To fix the problem, you need to disassemble the power supply, replace the burnt out fuse, & also check the bridge rectifier section for burnt out rectifying diodes (these usually get burnt out if the high current gets the chance to leak past the fuse, which could sometimes happen). If you find burnt out rectifying diodes, you will need to replace them as well, as they could burn out the fuse again when you try to use the power supply while they are still there.
Dec 20, 2009 | Codegen : 350W ATX Power Supply With 12cm...
Emerson 32 inch LCD TV will not come on.
I'm sure you already checked the outlet and the surge protector bar. It's lame how the warranty only last a year on this TV.
If your lucky, it will be just the fuse that need to be replaced. It will look like a little glass tube with metal caps on the ends. Radio Shack or an Electronic supply store will have the fuse. Just show them the fuse and they should match up the type and size. It needs to be 4amps and 125volts fuse.
If this doesn't work, you'll need to replace is the power supply board. The board# is BA71F0F01042. Your power supply board should have the same number on the lower right side of this board.
The board is hard to find right now. Only three places I know of to find it.
Ebay,
Discount-Merchant.com,
and Shopjimmy.com
Sadly, nobody has them in stock.
I wish I had a extra board to sell you, because I know how to repair the power supply. I have the schematics diagrams and part# for the pieces on the board.
If you ever come across a replacement board, let me know. I would like to buy your old board. Here's my e-mail, www.dsacco86@hotmail.com
Apr 14, 2009 | Emerson Televison & Video
Open Questions:
My Westy 47 TV has a very strange power-up problem! First, I found that the power supply was bad, I couldn't repair it, so I bought a replacement from ShopJimmy. The replacement seems to be working fine, and sometimes the TV works fine. The little green LED near the bottom edge of the controller board lights up when you connect the AC power, as it should. There is also a small green LED near the upper edge of the controller board that apparently lights only up when the controller is working properly. I've replaced the 470 mFd, 16 V. 'Lytic on the controller board, as everyone says to do. I still observed about 0.8 Vp-p of digital signals on the 5 Volt buss with the replacement capacitor these signals looked kind of like a 300 kHz clock and some other misc. digital stuff, so I added a couple of 0.1 mFd disc ceramics directly across it on the bottom side of the board. That reduced these signals to about 0.4 Vp-p, but the TV still won't turn on. The orange pilot light on the front is lit, but neither the buttons nor the remote will turn it on. The only way I can get the TV to turn on is to do the following: 1. disconnect the two power cables going to the two lamp inverter boards; 2. plug the AC power cable in. The 2nd green LED on the upper portion of the controller board now lights up when AC power is applied. 3. plug in both power cables to the two inverter boards while the power is on. The TV now works fine - all of the lamps light up, good picture, blue LED on the front panel, the remote works, etc. However, if I turn the TV off, and try to turn it back on, the small green LED on the upper controller board goes off, and the set won't come on! I've tried holding the on/off button down for over 10 seconds I read that this might re-boot the controller to no avail. The only way to get it back on is to go thru the 3 above steps again. I've read that there appear to be several versions of the firmware, and I wonder if this might be a firmware problem. If so, how/where can I get the proper firmware to install? Any suggestions? HELP! Please If someone would like to call me, please do at ************. Thanks, Gary W3DTN
Dec 28, 2015 | Westinghouse TX-47F430S 47 in. LCD TV
See all Westinghouse TX-47F430S 47 in. LCD TV Questions
Westinghouse TX-47F430S 47 in. LCD TV Logo
885 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
