There is a sqeaking noise coming from 1 vent nothing in it that i can find it is blowing air through the vent but it is making an aweful noise..i checked the unit outside and it sounded normal...
I beleve your hearing the fan or fan moter
Posted on Feb 02, 2010
Why is there no air blowing out my dash vents?
the air vent is control in your consul maybe is not properly set up check to the a/c technician
Jun 17, 2013 | 2001 Hyundai Elantra
Air vents in front are not blowing
there is a problem with ur hvac mode door actuator
unless the door is jammed u need the actuator common
problem
Dec 28, 2017 | 1998 Cadillac Seville
A/C blows from defrost and floor vents, nothing from dash vents.
the switch where you turn it to blowing at your head is probably out. you will need to replace the switch control where your defrost, foot, head etc. what make, model, year is your vehicle?
Jul 09, 2009 | 1994 Toyota Camry
Car Fan Motor will not blow air, though it makes noise...
Likely you have a blend(air control) door that is malfunctioning or you have debris stuck in blower fan (you would not believe what I have found in some) If noise changes, likely the motor is working and the problem is not electrical.
Jun 09, 2009 | 1996 Chevrolet Lumina Mini
Squeaking noise from front end in cold weather
Bad ball joints. check out front end and make sure nothing else is bad. Good lucka nd thanks for using FIX YA
Mar 03, 2009 | 2002 Oldsmobile Intrigue
Faulty Fan Heater - The main vents are just blowing out cold air.
all cars have a recycled air weather its called max or just recycle its doing the same thing. So if your getting cold air in one spot and hot in another it means your vents are not blocking where they are suposed to. It could be just a simple fix, by getting into the dash where your vent controls are and looking at the flap that tells air where it can and cant go. if its stuck then it needs to be cleaned and oiled. If the cable is corrodend clean it and oil it so it can move freely, or just reconnecting it may be the fix. it sounds like you are going to have to be adventurous, and play with the mechanics of your vents. Typicaly theres really nothing tough there to work on, just REMEMBER WHEERE ALL THE SCROOS AND CLIPS GO. I have forgotten where a few went in the past and had to listen to sqeaking noises till I took it apart again. There are vent seals wich are no more than the weather stripping you buy at the hardware store the 1/8 inch thick tape. You may need to thin it down with a razor, usually not. but it works great for fixing the seals in car heaters, because its the same thng just a different color. Which no one will ever see.
Feb 01, 2009 | BMW 525 Cars & Trucks
Unable to change the blower position, air is just coming out from the dashboard vents, moving knob doesn't change air direction. also when blower is set at 3 0r 4 unable to turn the temperature down....
the air will not blow through windscreen vents but is blowing through every where else. makes no difference when changing the direction of the knob to the windscreen only. you can hear the air blowing but nothing comes through?
Apr 29, 2008 | Daewoo Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
