Question about Canon S 750 InkJet Printer
Print faint Every second line is comming out faint. I have done printer maintenance and it shows me that the nozzle is the problem. How do l fix this
  • Anonymous Aug 27, 2008
    s 750 the third lines are faint. I have clean the heads
    Scholar:
  • 60 Answers
It sounds like you need a new print head. You can order through Canon...
"To order an internal replacement part, please call 1-800-828-4040. The hours of operation are 9:00 A.M. to 8:00 P.M. EST from Monday to Friday."
Posted on May 08, 2008
  • Jane Doe May 19, 2008
    Did this resolve your issue?
The color is not printing correctly. Things are coming out mostly pink or yellow. I tried the MAINTENANCE tab. The nozzle check showed that the top section (PGBK) looked good. The second section (C)...
The printhead has either become too clogged to flush out with with the internal cleaning operation (which uses a LOT of ink), OR, the nozzles are not firing. If after several cleaning operations there is still no significant improvement, you will need to replace the print head. I see this frequently with Canon and Epson, and Brother inkjet printers. Usually, it is due to leaving the printer idle for too long, or removing a cartridge and not replacing it right away. The air gets to the residual puddle of ink in the head and dries it.
You can find the replacement print head by Google searching "MP830 print head". Prices can vary from around $70 - $90. Changing it out is fairly simple. You only need to lift a lever that holds the head in place. Make certain that it is squarely seated, and then run a few pages of a color document, or do a couple of standard cleaning operations to "prime" the head.
Make sure the hed is NEW and not used or "refurbished". Here is one source on eBay that sells it for $78.00:
http://compare.ebay.com/like/330643273134?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&_lwgsi=y
Nov 27, 2011 | Canon MP830 All-In-One Printer
HI, can you tell me the procedure for 'cleaning the ink heads' on my EPSON STYLUS DX4400, Please. thank you, MARK
  1. Open the Printers or Printers and Faxes folder.
    In Windows 7, click Start then Devices and Printers. In other versions of Windows:
    • Click Start > Settings > Printers, or
    • Click Start > Printers, or
    • Click Start > Control Panel then double-click on:
      • Printers, or
      • Printers and Faxes, or
      • Printers and Other Hardware then View Installed Printers.
    • See How to open the Printers or Printers and Faxes folder in Windows in the Related Articles section for detailed instructions.
  2. Right-click on the icon for your printer and select Printing Preferences.
    Example: Windows Vista
  3. This will display the Printing Preferences window.
  4. Click on the Maintenance (or Utility) tab.
  5. Click on Head Cleaning. This will launch the utility.
  6. Click Start and wait for the printer to finish the first cleaning cycle.
    caution.gif Caution: Never turn off the printer while the On light is flashing. Doing so may damage the printer.
  7. Click Print Nozzle Check Pattern. This procedure will confirm the effectiveness of the head clean. You can also access the print Nozzle Check option from the Maintenance or Utility menu.
  8. Click Print.
  9. The printer will print a nozzle check. Compare the print out with the next window. If there are gaps, the print out is faint, click Clean, and then Finish when the procedure is complete.
    • If the nozzle check prints correctly (showing no breaks in the pattern), but the text is still broken you may need to run the Print Head Alignment utility - see How do I use the Print Head Alignment utility? for assistance.
  • If the nozzle check is complete, click Finish.
  • If there are gaps or faint print on your printout click Clean.
If gaps are still present, perform another head clean (without printing a nozzle check between the cleans). Once the second clean is complete, power off the printer.
Wait one minute before powering it back on, then print a nozzle check. Compare the printout with the example window (above).
  • If it is complete, click Finish.
  • If there are gaps or faint print on your printout carry out another set of head cleans.
  • We recommend only a maximum of six head cleans.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 10, 2011 | Epson Office Equipment & Supplies
Hi, my Epson 2100 is printing with faint lines at regular intervals right across the page. I've done various alignment tests and cleaning tests but can't seem to clear the lines. Any advice much...
Are your alignment tests show good results? If they are, try head cleaning 3 consecutive times without printing nozzle checks. After 3 head cleanings do the nozzle check. If problem persists try printing at BEST PHOTO or whatever is the slowest print setting for your printer. Good luck!
Jan 14, 2010 | Epson Stylus Photo 2100 InkJet Printer
The colour is faint, a new catridge was installed
When printing becomes faint or colors are incorrect, even if ink remains in the ink tanks, the print head nozzles are probably clogged. Follow the procedures below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
If white stripes are noticeable
Step 2 : "Aligning the Print Head"
If print quality is poor
Step 2 : "Print Head Cleaning"
if the problem remains
Step 3 : Print Head Deep Cleaning"
if the problem still remains
Step 4 : Replacing Ink Tanks.
Note : * If the ink tank replacement does not resolve the problem, contact the Customer Care Center.
* You will be alerted if low ink warning is enabled.
* When the Maintenace button on the operation panel is pressed, the maintenance mode is shown. Numbers and functions that can be selected on the maintenance mode as follows :
01 : Printing the Nozzle Check Pattern
02 : Print Head Cleaning
03 : Print Head Deep Cleaning
04 : Aligning the Print Head
05 : Reset the ink counter.
06 : "Display" or "Not Display" remaining ink volume.
07 : Date and order setting.
Printing the Nozzle Check Pattern : Print the nozzle check patterb to determine whether the ink ejects properly from the print head nozzles and to verify print head alignment. Use this function when printed results are blurred or the color is incorrect,
1) With the printer on, load a sheet of Letter paper in the printer.
2) Print the Nozzle Check Pattern.
a) Press the Maintenance button,
b) The Maintenance icon and 01 appear on the LCD.
c) Press the OK button. The nozzle check pattern is printed.
3) Examine the nozzle check pattern output by the printer.
a) Lines missing in this pattern indicate that the print head of black ink requires cleaning. Perform the Print Head Cleaning.
b) White stripes in this pattern indicate that the print head of color ink requires cleaning. Perform the Print Head Cleaning.
c) Uneven patterns indicate that the print head requires alignment.
Perform Aligning of Print Head.
d) Noticeable white stripes in this pattern indicate that the print head require alignment.
Print Head Cleaning : Clean the print head if you suspect that the nozles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
1) Ensure that the printer is on.
2) Start print head cleaning.
a) Press Maintenance button.
b) Press right arrow once to display 02 on the LCD.
Important : Do not perform any other operations until the print head cleaning finishes. This takes about 50 seconds.
Note : After the print head cleaning finishes, print the nozzle check pattern to verify that the print head nozzles are clean.
If the problem persists, perform printhead deep cleaning.
Print Head Deep Cleaning : If print quality does not improve by standard print head cleaning, try print head deep cleaning, which is more powerful process. Print head deep cleaning consumes ink, so perforn this procedure only when necessary.
2) Start Print Head Deep cleaning.
b) Press right arrow twice to display 03 on the LCD.
Important : This process takes one or two minutes to complete so simply wait until the Power lamp stops flashing.
Note : After printhead deep cleaning finishes, print the nozzle check pattern to verify that the printhead nozzles are clean.
If the printhead is still not clean after the second deep cleaning, replace the ink tank.
If ink tank replacement does not resolve the problem, the print head may be worn out. Contact the Customer Care Center.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 07, 2009 | Canon i475 InkJet Printer
Poor quality printing - lines through words, some lines very faint, some words barely readable.
Try doing maintenance in the printer settings in control panel , (Nozzle clean, Clean cartridges)
Nov 09, 2009 | Canon PIXMA iP1600 Printer
Photos printed come out faint and lines andblack streaks across the photos how do i solve this/
lean The Print Head Nozzles (Windows) The following contains instructions to check the nozzles for poor print quality and perform cleanings of the print head nozzles as necessary. If print results are faint or streaks are printed, the print head nozzles may be clogged. Print quality can be improved by performing print head cleanings or print head deep cleanings. aution: Only used the approved methods below to clean the print head. Use of other methods may further clog the nozzles on the print head and may cause permanent damage the print head.
Note: It is important to check the cleaning results by printing Nozzle Check Pattern after each cleaning. Cleaning and Deep Cleaning consumes a certain amount of ink. Only perform a cleanings when necessary.
Print a Nozzle Check Pattern
  1. Confirm that the printer is connected to the computer and the printer is turned on.
  2. Complete or cancel any print jobs in progress.
  3. Open the Printers folder.
  4. Click the Maintenance tab. (The Maintenance window opens.)
    Note: The layout varies depending on the printer and version of Windows you are using.
  5. Insert a piece of letter-sized plain paper in the paper tray.
  6. Verify the desired paper source for the Nozzle Check is selected on the unit by changing the Paper Feed Switch if necessary.
  7. Select 'Nozzle Check'.
Aug 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma ip4200 colours are yellowy orange on teh photos - dont match on screen colour nozzle check shows the second of the cyan lines as very faint
(Had already done two deep cleans)
1. removed all print cartridges keeping them together and upright
2. qtip (cotton ball on a small plastic stick) soaked in generic nail varnish remover {alcohol based)
3 cleaned print head where cartridge sits repeatedly until no more ink came off on the cotton wool
4. did a deep clean twice
printer then functioned properly
Dec 04, 2008 | Canon Office Equipment & Supplies
Prints Faint green horizontal lines
Go to control panel and printers and faxes and right click on printer icon then hit printing preferences, go to maintenance and do head cleaning cyles and print nozzle check. if it comes out fine trash and reinstall driver
download driver from support.epson.com site after selecting the printer mdel on the lists
Apr 12, 2008 | Office Equipment & Supplies
Canon S 750 InkJet Printer Logo
66 people viewed this question
old marine
old marine
