Question about Dell Inspiron 1300 Notebook
INSPIRON 1300 upgrade from 40 gb to 120gb seagate hard drive st9408114a which part do I buy Thanks Ray
  • 3,940 Answers
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I want to upgrade my Fujitsu MHV2040AH 40 GB Hard Drive what is the biggest/fastes one i can replace with? i though i found another one but it doesnt have the right connectors. the fujitsu/toshiba site...
Your Fujitsu MHV2040AH is an IDE 2.5" 5400 rpm 40 GB hard drive.
Most Notebooks nowadays will use 2.5" SATA hard drive which is not compatible with IDE.
New IDE are getting harder to find and are therefore in general more expensive to buy than the equivalent SATA
You should be able to update the drive with most 2.5" HDD with either 5400rpm or 7200rpm (faster) with an IDE interface. Common 2.5 IDE capacity would be 120Gb and 250Gb (320GB and 500GB are also available but could be a bit expensive). The important factors are physical size to fit in your notebook/casing and IDE interface. The BIOS support for larger drive can also be a factor but as a rule, worst case situation, a larger capacity drive can always be used at a lower capacity
Hope it helps.
Dec 15, 2010 | Fujitsu MHV2040AH (HDF40000IAH) 40 GB Hard...
Whats the biggest ram I can put in my HP G7000 note book to replace ST9120822AS which is currently in my machine.
Currently the largest drives for notebooks are are
Hitachi Travelstar 5K500 500GB
Seagate ST9500420AS Momentus 7200.4 500GB
Seagate ST9500420ASG Momentus 7200.4 500GB
Seagate ST9500325AS Momentus 5400.6 500GB
Samsung Spinpoint M7 500GB
Samsung SpinPoint M6 500GB
Nov 13, 2009 | Seagate Momentus 5400.3 ST9120822AS 120 GB...
Have an i/o problem with Seagate Momentus 5400.3 ST9120822A - 120GB how can I solve it?
Hi burak02,
There could be a million reasons that your getting this i/o error. First I would check the cable to make sure it's snug on the pins, and then my suggestion is to follow this link HERE and pick the question that best describes what your OS and equipment list are. This is a great spot to solve most of the problems, They also have software you can download to test the drive to see if it's dead or just loose.
Good Luck,
And don't forget to leave a rating
Thanks
Mark
Oct 07, 2009 | Seagate Momentus 5400.3 ST9120822A - 120GB...
Hard drive failure
You can replace the hard drive, but you will need to reload the Operating System from some other source, as it sounds like your Hard Drive is dead.
Mar 10, 2009 | Seagate (9W2041-337) 40 GB Hard Drive
I want to set up my new freeagen go o
I bought a new seagate 120GB external disk drive. I only store a small file of 40KB but the disk is showing that i have used 25 percent which is equal to 28.2GB, i then delete the small file but the 25 percent used is still showing. Please i need some help on what i can do to get my hard drive back to 120GB even if i need to format the drive.
Thanks in Advance.
Apr 13, 2008 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Tryi8ng to install portable 120GB hard drive (seagate)
If your USB ports do not supply enough power (older computers) then the drive may fail to show up in My Computer.
The Seagate should have a special Y cable. There are two USB connectors on one end that must both plug into your computer - one for data and power - the other for power only. The other end of the cable has the mini USB which plugs into the Seagate.
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=External_Drive_Troubleshooter_-_Windows_Error_Messages_-_Common_External_Drive_Errors&vgnextoid=14d24a3cdde5c010VgnVCM100000dd04090aRCRD#clicks
Mar 22, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Hard disk not detected
The problem is that u have done partitions for 160 GB harddisk, so do all the partitions of 40 GB or less than that.
Sep 24, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
No power on psu when Hardrive connected
Yes, I actually experienced it too about 2 months ago. I believe there is short in the board. I have a 200gb barracuda that failed (too soon) and I swapped the boards...just to see what would happen. I was able to recreate the other drives problem and vice-versa. I think if I could get my hands on a working barracuda(if there are any) I could recover my info. curse of the 7200.7's Good Luck, Tim
Feb 13, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
Dell Inspiron 1300 Notebook Logo
275 people viewed this question
Alun Cox
