Question about Educational Insights Hows and Whys Of Science
As more water is pumped put of the ground, what will happen to the water table? how will this affect the wells?
  • Lucy Gibson
    Lucy Gibson Sep 20, 2017
    Great question about the outcome of the water table after a well is pumped. My parents are looking to build a cabin in a remote area. If they do decide to build, they'll need to have a water well dug. I would assume that if you get good weather with rain, it would replenish the water table, but I'm not an expert and this is just my opinion. http://advanceddrillingllc.com/well-dril...
  • 394 Answers
We lived and raised our children in South Dakota. When the big farms started irrigating our 30 foot bored well water level dropped. When we brought this up we were told to dig a deeper well. We could not afford it. 300 foot wells were expensive. We learned how to recycle bath and laundry water. We got our kids raised up.
Posted on Feb 02, 2010
Why is their about 15 gallons of water built up under my house within a couple of days, but no visible leaks?
Drain pipes might go under the ground. You have slab leak. Plumber will figure it out, or check blue prints of Your house if You have those(will show You "What Where")
Jan 29, 2015 | Plumbing
How does a home well water system work?
Deep well.
Pressure valve located on front of above-ground-storage-tank will turn pump on-off depending on amount of water pressure inside tank.
When water is consumed inside home, the pressure valve responds to the lower pressure and closes electrical contacts... sending electricity to water well pump located deep underground.
The pump turns on and lifts water through a pipe into the above ground storage tank.
When the tank is full of water, the pressure valve senses the higher pressure and turns off electricity going to pump
Pump shuts off.
There is a one-way check valve on the water line going down to pump, and this keeps water from flowing back down into well.
The above ground tank maintains water pressure for the house.
When pressure is reduced by taking a shower, the pressure valve turns pump on again, and cycle repeats.
Aug 20, 2014 | Water Heaters
What causes a well to lose prime
Generally, that happens when you draw so much water that the foot valve starts sucking air instead of water.
An unused well has a certain amount of "head", or surplus water in it above the foot valve. The top of the water will be just about at your area's water table, the foot valve will be below that.
As you use water, if you use it faster than the water table can replenish it from the bottom or sides of the well, the water level in the well gradually drops until it reaches the foot valve. At that point, air gets drawn into the suction line & travels up to the pump as a big bubble. If the bubble is big enough, the pump loses prime (it can't draw more water, all it can do is stir that air bubble around).
Mar 05, 2014 | Plumbing
My alarm on my liberty sump pump is going off. Its a brand new house a little over year old. What is the problem, because I can still hear water being pumped.
While it still pumping, the unit recognizing the water table being higher than expected. Could happen for a few hours after a serious down-pour. If it's longer, would seek professional assistance to figure out if your pump's output works properly, or you have just too much ground water coming in. Don't wait too long. If it's a unit defect after all, it should still be under warranty, according to manual at libertypumps . It also describes how the water sensor is supposed to be mounted. Make sure it didn't fall off (into the water).
Oct 08, 2013 | Liberty Almp1 Indoor Water Alarm 115v
Is it ok to drain an in ground pool
CAUTION !!! WARNING !!! some pools are next to the water table and will POP out of the ground. no joke and not cool.THEY FLOAT LIKE A BOAT most pools have a plug in the main drain and will need a pump placed on it to pull the water from around the pool out of the ground for SAFE POOL REPAIRS !..any lakes around you ? this can help you judge your water table in your area.. THAT being said if you know your high and dry .. suck away..
I\'M GLAD YOU ASKED. SMART !!
Jay.. the pool pump (doctor) motor repair guy in longwood Florida 32750
Jun 04, 2013 | Pool & Spa
We have a 400 year old house, and have a problem with a large amount of water pooling in the kitchen. We are having trouble establishing where it is coming from, with no obvious leaks found as yet. The...
Hello
First verify you have nothing leaking in your kitchen.Sink, refrige,drains.Heating system is it hot water? make sure its not leaking also.
Im guessing this home is on a slab or has no basement?One way to find out if the water table is high is too go outside and dig down about 2 feet on all 4 sides of the house.Wait about 4 to 6 hours and see if the holes fill with water.If any of them do then you have a high water table or the old well is filling up.
Your water main if its city water should come in off the street,find the shut off near the curb and follow it too the house.
As far as testing the water,your local health department or water dept should be able to test it for you.
Or there are some places to get your own.http://www.filtersfast.com/water-test-kit-cat.asp
If the water table is that high your going to need to have a contractor pump the ground out by putting long pipes in the ground and hoses and actually pumping out the water.Or have the well sealed and filled.
Apr 11, 2011 | Heating & Cooling
Fuel pump not working. every few weeks pump qiuts working.let set for couple days starts working again.it was happening once got below freezing but today it was 6 degrees out ran allday fine then nothing....
It sounds like something is shorting or grounding out. If the temperature was affecting the pump itself, it would mean that water was freezing it stationary, which water in the gas is a major issue in and of itself. Most likely, there's a wire that's loose or corroded and it's intermittently causing malfunctions. The pump could be going bad as well, and is pretty likely. I personally do not suggest working on items as sensitive as a fuel pump unless you are a bona fide mechanic. A repair shop is most likely the best solution.
Sorry! No easy fix today... hope my answer helped you out though!
Happy Holidays!
~CK Systems
Dec 11, 2009 | 1994 Oldsmobile Bravada
Motor running but not pumping any water, why?
You very well could have a bunch of Sediment on the Intake for the Water OR The water table has Drpped Below the Pump.
Jan 19, 2009 | Flotec 1 Hp Deep Well Pump
Educational Insights Hows and Whys Of Science Logo
159 people viewed this question
Top Educational Insights Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Educational Insights Toy Expert? Answer questions, earn points and help others
