Question about Kenmore Elite 45986 Front Load Washer
We have a 5-year old Kenmore front loading washer. It still runs, but the rubber gasket that seals the door looks like it is not attached to the drum properly all the way around. Also, the drum seems looser than usual. It still spins OK, but moves forward and backward much more than it used to when it's at rest. Any ideas as to the problem?
  • 10,865 Answers
Hello.. That gasket will have to be either reinstalled or replaced, depending upon what kind of shape it is in. If you do continue to use the machine as is, the problem will worsen. If you typically call in a repair man you will not have to read the link I am providing. If you want to do this repair yourself please do read on: http://www.fixya.com/support/t2403296-replace
Regards, Joe
Posted on Feb 02, 2010
How to Replace rubber seal on front load washer
The rubber seal on your washer and similar front loading washers is a relatively easy repair. The seal is held onto the front washer panel and the fixed inside washer drum with separate spring-loaded rings that are reusable. So, don't throw them away! You need to remove the front ring from the front panel before you can remove the front panel. With the ring removed the gasket should be pushed into the washer; noting any drain holes, so that you can reinstall the new gasket in the same orientation. Once the outer ring is removed and the front panel is out of the way, you will have access to the ring holding the gasket to the drum. After the inside ring is removed, the gasket should pull off the fixed washer drum. You are now ready to install the new replacement gasket.
The amount of disassembly of the front of the washer is your option if it interferes with the installation. The door is usually heavy and it is useful to remove it from the front panel. Usually, a couple screws holds it in place. Removal of the front panel may also involve removal of the top of the washer and moving the control panel out of the way so that you can access the screws holding the front panel onto the frame of the washer. The locking latch may have to be temporarily removed but can be left in place if you simply push the front panel out of the way to have access to the inside gasket ring. It is useful to take pictures of each stage of the disassembly process to make sure your reinstall everything as it was.
Installation of the gasket starts with reattaching it to the fixed washer drum flange and then replacing the spring-loaded ring to hold it in place. Make sure the gasket orientation matches the original position. After the gasket is attached to the drum, you can now reinstall the front panel. If you unscrewed the latch mechanism when you took off the panel, now is the time to reinstall it as it can be manually held in place behind the gasket. The door can usually remain off the front panel until installation of the gasket onto the front panel is complete. Now bring the gasket forward and reinstall it on the flange of the front panel; secure it in place with the spring-loaded ring. Your gasket is now reinstalled. Simply reinstall the door and your repair is complete.
Tools needed include a blade screwdriver to help pry the rings off the gasket seal and one or two specialty screwdrivers (usually Torx or Philips) to remove the front panel.
Aug 05, 2014 | Frigidaire Washing Machines
Washer maytag front loading 4000 series assembled and runs but iwith two problems.1) residue on inner surface of door window..lint like oily paste ..gasket rubbing on inner drum?? meaning main rubber
The fault seems to be that the main seal is rubbing against and is thus producing the oily residue on the window. Now the fault seems that the drum is rubbing due to POOR ALIGNMENT or poor BEARING settings.
You need to check the PLAY on the drum and if this shakes a bit then the assembly must be reset with correct aligment and the drum must move without rubbing the rubber seals.
Check this link; replacing bearings
Jan 14, 2013 | Maytag Washing Machines
Kenmore Super Capacity 3.5 Front Load Washer leaves dark lines on light-coloured items and light lines on dark-coloured items! I've cleaned the rubber gasket (? where the door fits into the drum) and there...
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 13, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
The rubber seal kenmore 3.8 cu ft he3t king size capacity
Our rubber seal was torn and we had a Sears repairman replace it - he said it required a special tool to install it (which he didn't have) but through some long and physical process, he was finally able to get it on.
Jan 26, 2009 | Kenmore Elite 45986 Front Load Washer
HE4t kenmore washer rubber drum gasket not attatched.
Removed the top and Front reinstalled the counter balance. the rubber gasket has a 1" tear in it which I patched with a rubber tire patch for now. Two of the locking nuts for the leveling of the machine were loose it went out of level causing the machine to rock and probably caused the counter balance to loosen up. My daughters come in from collage and over load it on weekends which adds to the machines demise. All have been warned.
Jan 17, 2009 | Kenmore Elite 45986 Front Load Washer
Chenging the rubber gasket attached to kenmore H2e front load washer
The following link provides you with step-by-step instructions on how to change the door bellow:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is not a difficult repair. Just follow the steps provided. If you have any questions, please let me know. I hope you find this information helpful.
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
Front Tub Seal
you have to take off the front to do it right.
remove upper and lower access panels
remove solution tray
remove the control panel
remove the front ( you can leave door attached but it will be heavy)
Mar 03, 2008 | Whirlpool LHW0050PQ Front Load Washer
Hotpoint washing machine WMA66
Thank you gittos73.
It's as gittos says. When you open the door and look inside, at the very top of the door is a white square. This holds the metal clip. If you push the little white dot in the middle of this clamp gently, it gives way and you will see the round metal clip that goes all the way round the door rubber (gasket). Remove this and you can put your fingers round the gasket and pull it toward you.
Then take the lid off the machine and you will see a 6mm nut with a spring behind it and a wire clip similar to the front one, going round the gasket where it attaches to the drum. This has a crosspoint (phillips type) head on it and you can get a small screwdriver into it and undo it all the way. Then slide the gasket off and it will come away.
Fitting it is the reverse but it is a little bit tricky as you have to get the gasket behind the lip to make the seal. Take your time and they will both go round properly.
Aug 03, 2007 | Hotpoint WMA66 Front Load Washer
KENMORE H3T WASHER GREY TWISTED FRONT SEAL
I am currently replacing this bellow because of holes and five years of wear and tear. The bellow is attached to the front door assembly via a spring loaded clamp. This clamp is a solid large wire ring with loops on each end where the spring attaches. You do not have to remove the spring, just place a screwdriver between the bellow and the ring or spring to remove. This will allow you to take off the bellow from the lip of the front door assembly to reposition. The spring clamp goes on starting first from opposite of the spring and working in both directions a little at a time. ALL DONE.
Dec 20, 2006 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
13 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
