Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
While driving it there was a rattling in the motor then it lost power and now all it will do is turn over what do i do to fix it
  • 714 Answers
This motor has a known problem for bending push rods.
RECOMENDATIN:
Check for bent push rods.
Change oil every 30 hours of operation or less.
Use a hi quality of oil only.
Hope this tip helps..
R/
David
Posted on Feb 06, 2010
Rattle noise
i dont think the hard drive is fixable at this point.the rattle noise you hear is usually the last indicator that your hard drive is going to crash for good. I have had the same problem with a couple of hard drives. the first time I lost everything. the second time I started hearing that noise from a hard drive ,I jumped into action and copied all I could before it finally quit for good. live and learn.
May 20, 2014 | Fujitsu Computers & Internet
Left side drive began to shake and rattle then gradually lost all function. Right side working fine.
each side has is own pump and drive motor check the fluid level and then you will need to remove it and either replace it or rebuild it
Jul 30, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
My Holden Barina (2001) makes a rattling noise emitting from the right hand side of the engine. It gets louder when I accelerate. Yesterday I lost all power after only driving it for 1km. The oil level is...
Check all of your belts and pullies. Sometimes it helps to remove the belts and turn the pullies by hand. Also run the engine without the belts for a few seconds. If the noise is still there, then it is most likely timing components rattling.
May 05, 2012 | Holden Barina Cars & Trucks
Rattling under hood
Sounds like time for a new engine to me. (severe engine damage due to oil loss or overheating)
Nov 13, 2011 | 1996 Ford Mustang
Battery light turned on. Lost power steering and AC.
You broke your serpatine belt. Needs replacing. It's a $50ish part and easy to do if you have a diagram under the hood of how the belt fits. But if it was "rattling" for a couple of weeks take it in for crying out loud. Let the mechanic look it over to make sure your lack of vechile care didn't destroy anything under the hood.....
Jun 12, 2010 | 1998 Saturn SC
Hi got zxr 600r has just started to rattle but has not lost power pulls good ,the noise is not the bottem end,has no oil leeks did not go bang,
if its on the left side of the motor possible cam chain wearing it will make a rattleing noise have it check out if the chain skips a tooth it could be very costly
Jan 05, 2010 | 1997 kawasaki ZX-6R Ninja
How do you fix driver door that rattles while
you need to remove the door pael to find what is rattling,
remove the washer hose from the rear wiper and try it,if it works from the hose,blow air through sprayer nozzle.
if not it means the tank might be empty,or motor has lost its pressure,replace it.
Nov 22, 2009 | Ford Expedition Cars & Trucks
I have a 1994 shogun with a rattle on the engine which goes off when u turn the streering,new power streering pump fitted but still the same any one help please.
you will get a rattle with power steering if you turn the wheel in either direction will make the car rattle but if this isnt the case then check your motor mounts may need to be replaced
Nov 03, 2009 | 1994 Mitsubishi Montero
I have on rattling sound sound on right front tire when slow driv
Have the tires inspected for a stuck stone or metal object. The anti-roll bar may have lost one of it's rubber bushings where it connects to the suspension on that side. A shock absorber may have lost a rubber bushing.
Oct 13, 2009 | 2004 Cadillac SRX
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
363 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
