Whirlpool Duet GHW9150P Front Load Washer Logo
Glenda Dean Sweet Posted on Feb 02, 2010
Sometimes the next morning after I have washed a load of clothes that evening, even though at night there is no water in the bottom of the machine, the next morning there is a small puddle in the bottom. It doesn't happen every day, but once in a while.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Feb 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
3957
Points
35
I think the drainage of your washing machine, is not functioning well,or it has a leak, that's why some water remain in the bottom of your machine..
check this one..
http://www.washingmachineadvisor.com/
1helpful
What to fix if a Frigidaire Washer - FTF2140FS1 - fills with water after the wash is complete?
check the cold water solenoid is allowing water into the machine,this can happen even when the machine is not in use
Water is in the washer the next morning
The inlet solenoid valve is dirty and doesn't shut off completely so there is a tiny leak over time. Generally this will get worse over time. You can simply turn off the water at the tap after each use or replace the solenoid, pretty cheap part. Some solenoids can be opened and clean the grit out.
Washing machine leaking
It sounds like the water valves are not shutting off completely.
You have faulty water valves & need to replace the leaking one.
I have a whirlpool duet steam front loading washing machine model # WFW9600TA01. recently when my wife starts a load of laundry at night when she wakes up in the morning the washer is still turning at a...
I would assume the load in the washer is a small load and the washer has a difficult time adjusting the load to spin. I would push pause, wait for the system to unlock the washer. Check the load for how much water in the garments. If heavy, the unit has a unbalance issue, just try to continue the load. If the clothes are light than unload the washer into the dryer. Was the unit ran on delay? This may be a non issue if the unit ran on a delay and just never finished yet.
Give those a try and get back to me, I and interested in the status.
Iā€™m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
4helpful
Will fill and drain, not agitate or spin though
I am having the exact same problem with the same brand machine.  I put in a load of clothes to soak till the morning, but in the morning, the washing machine would only fill, spin, and drain.  The agitator would not wash the clothes, so they came out with the soap of course still crusted in.
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
2answers
GE Front load washer clothes coming out with holes/torn/even shredded
Metal inside washer drum may be faulty and causing tearing of clothes (run your finger around the inside when empty and you will feel where it snags). Had same problem, only got worse and ruined many expensive t-shirts! Replacement of drum is required and is extremely costly if not under warranty!
Low water level
It depends on how old the machine is, the newer machines by law,take in way less water but still wash ok. TIP.try it with out load and check water level Ire bye
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
