Question about Gaggia Titanium Espresso Machine
Brew draw blocked - Gaggia Titanium Espresso Machine
  • richardandch Feb 04, 2010
    sorry about that i meant brew unit blocked regards odbogen
  • ifr500 May 11, 2010
    brew drawer or brew unit
  • Gaggia Expert
  • 109 Answers
Ok if brew unit is displayed,the cause is the brew unit needs to be to cleaned of all old grease and coffee grounds.
Once cleaned you will need to regrease the big oring at the top of the brew unit,pretty much anywhere that moves needs to be lubed and the two smaller ones near the back of the dreg drawer.
In some cases a tight or siezed brew unit can damage the main control board.
Posted on Feb 05, 2010
Brew Unit Blocked
open the door and see small screw in the middle of the brew unit. Take it off with small screwdrive and pull out the brew unit.Then put the small thing (something like a pipe) to the brew unit with the small screw. Then without brew unit in the machine press the switch inside the machine where stayin the brew unit and the switch witch is stayin the top of door .Switch on the machine and wait while self test is making,then put the brew unit in the machine and that it.Enjoy!
If you have any question -ask me.
Nov 25, 2013 | Saeco Royal Professional Espresso Machine
Won't draw up water to brew
What is the model number of your unit?
Nov 21, 2012 | Cuisinart DGB-700 Grind & Brew Auto
Brew unit blocked message The brew unit removed and switches jumped, motor turns message still blocked brew unit . what could it be and ways to tests.
I had the same issue. Very difficult to fix. You must remove brew unit and reset the machine while apart. You must trick the machine to think brew unit is installed and door closed. Look at door and brew unit and use screwdriver or butter knife to engage machine and run through cycle to reset.
Jul 09, 2011 | Starbucks Saeco Italia Digital Barista...
Water is being heated in the reserve but no water coming out at all
Send us brand / model please and thank you.
My initial thought is concern as water should not be heated in the reserve. It may be warmed through conduction but not deliberately. The reserve should keep water fresh until it is used for brewing. Not that this addresses your concern directly. You still aren't getting water fed where it is needed. . .
Most coffee makers have a "pause" function where if the pot is removed the water will not flow from (or to) the brew area and if the mechanical trigger for this feature is blocked, stuck, or jammed it will pause permanently. Similarly espresso pumps will not draw unless certain features are "in place" and standing-by. My initial guess is this safety / convenience function is malfunctioning for you.
Sorry I could not be of more assistance.
Feb 21, 2011 | Coffee Makers & Espresso Machines
My gaggia titanium says it's brew unit is blocked
Try cleaning and relubing the brew unit.
If that fails you require a new main board.
Jan 03, 2010 | Gaggia Titanium Espresso Machine
Dredgedraw has been locked in by brewunit and won't release
dredge draw being locked usually means the brewgroup is locked in place. Brewgroup locked in place will stop the dredge draw from coming out.
Now the question is why did the brew group locked up. There's a screw on the brew group that you can unfasten, turn the machine on and it may set it back to default position. Then you screw it back in and everything shoudl be fine.
If the group doesn't go back to default it could be a few other things. If it doesn't set back to default and is still locked up i'd suggest sending it in to a repair shop as it could be broken gears, compacted coffee in the brew group, or a dead brew group motor.
Sep 07, 2009 | Saeco Royal Professional Espresso Machine
Gaggia Titanium Brew Unit Blocked
Check the shower screen on the brew unit.
Aug 04, 2009 | Saeco Incanto Classic Espresso Machine
Brew unit and waste unit in place, brew unit is blocked
For Brew Unit Block:
  • Turn Off
  • Hold small coffee & hot wate atthe same time
  • Turn on with light (numbers sill appear)
  • Hold medium coffee util arm returns to normal position
May 27, 2009 | Miele CVA615 Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
228 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
