Question about Ovens
Creda convection oven wont heat up
Hi my gas oven suddenly stopped working...... the initial flame comes on as usual (which usually lasts for maybe 30 seconds) but the main burner doesn't come on at all.
The gas burners on the hob are working okay, with normal pressure, and i can't see anything visibly wrong. Is there a control thermostat in the oven which might have blown?
The cooker is about 10 years old and i've never had this problem before..
Any ideas please?
My ge profile double electric oven, bottome convection wont heat up
Posted on Nov 02, 2009
I have a propane Jenn Air gas wall oven. The broiler works fine, the bottom log will not light because it isn't getting gas. The light to ignite the gas is working fine. What do I do? I do not have the...
Hi I think that the Thermo-couple is bad That is the part that senses the flame or electric heat coil-heater warming up to ignite the flame for pilot light. there is a rod that is next to the electric coil which senses the heat coming from the coil. If that isn't working properly the pilot wont light and the log won't lite because the gas valve won't turn on for safety factors. The part is nit too hard to replace but you need to lay on the floor to get at it.
Sometimes the lower shield or bottom lifts up and removes
to service it . the thing is small about 1 in long with a copper tube, or steel braided jacket around the wire. the coil is maybe 6-10" long when rolled out. But don;t roll it out or bend a sharpkink in the thin copper tube because it will be ruined. The part doesn't cost much $10.00 -30.00. you may need some screwdrivers and 3/8 "or 7/16" open end wrench and maybe a 1/4 in. nut driver pliers..
Good luck, Bill
Jan 07, 2018 | Jenn-Air 30 in. Pro-Style Electric Single...
What causes the flame switch to cut out ion an Imperial ICVD convection oven
This flame sensor switch is a safety device that only allows the main valve to open after is is satisfied there is a pilot flame. Otherwise if there were no pilot and the main valve was allowed to open, the inside of the burner area would quickly fill with gas and pose an exposion hazard. The original capillary tube type switch is obsolete and a new electronic unit conversion kit is available. Contact Imperial tech support for more information
Apr 29, 2012 | Imperial ICVD-2-HH Turbo-Flow Gas Double...
I have a caloric oven, prestige series. Don't know model. it is about 15 years old. last year the oven wouldn't heat and smelled gas. That was repaired. Now, oven ignitor comes on but oven...
The ignitor is bad again,if it (ignitor) comes on but no flame/heat its the ignotor again, what would make the ignotor go bad so fast (usually last 10-15 years) is a problem with the oven burner, so now BOTH the ignitor and burner would need to be replaced,if it is 15 years old the ignitor is readily avaliable but the burner may not be
Aug 04, 2011 | Ovens
I have an bajaj oven and im trying to bake a cake and everthg i bake it the sides of the cake get baked and the middle portion remains raw..ive tried all the up flame,down flame and also both the up and...
if your oven is gas its is very difficult to make perfect baking of of the uneven heating,if your oven is elecric is with convection that one good compare to gas oven on an electric oven without convection, the advantage of oven the with convection is even heating.
Dec 24, 2010 | Ovens
Creda cf50g cooker oven not getting hot
sounds like the ffd is at fault, this is a safety device that alows the main flow of gas through. when the cooker is cleaned the sensor can be moved by accident from its position over the flame, another reason could be a build up of grease etc, stopping the flame reaching the sensor. if none of these then the ffd unit needs to be replaced. they are about £20.00 for the part
Apr 06, 2010 | Ovens
My Creda convection oven does not heat up. The
Nov 20, 2009 | Ovens
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.
The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.
If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.
The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Please do rate the solution and revert for further assistance.
Sep 10, 2009 | Kenmore Ovens
No gas coming through
Hi. you will need to replace two devices. you will need ot replace the ignitor and you will also need to replace the coil assembly that is located on the burner assembly. these two devices are faulty and, this is causing the interruption you are experiencing.
The coils actually control the gas valves. they provide the resistance that initiates the opening and closing of the valves and, the ignitor ignites the flame.
May 21, 2009 | Creda Ovens
Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Mar 04, 2009 | GE Ovens
Ovens Logo
234 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
