Question about Honeywell Programmable Thermostat Heater
I went away for the weekend and didn't turn my heater on for a day. I think my pipes are frozen. What should I do?
  • Honeywell Master
  • 3,248 Answers
Hi get some secondry heat in to the house and try to thaw the heating out fix any leaks if you can , not much else you can do
Posted on Feb 02, 2010
HOW DO I UNFREEZE MY WATER HEATER I HAVE KEPT THE DOOR OPEN AND A SMALL HEATER IN FRONT OF IT BUT IT MAKES NOISE BUT NO WATER FLOW YET
it is probably not the water heater that is frozen but pipes in the area. Close the door leave the electric heater on and open a valve to let water trickle when it starts to flow.feel the pipe on the hot side of the heater if it is warm it is not the heater. try to stop any drafts and you can use a hairdryer to try to warm pipes that you think might be frozen. a torch will also work if you know how to use one and avoid any flammable areas.
Jan 17, 2015 | Water Water Heaters
"nf" error code on Maytag front load stackable
I think your hunch is probably correct. "nf" is "no fill" or "slow fill" so if the machine is in a cold enough location it likely has frozen supply lines or inlet water valve. About all you can do is slowly warm the area around it with a space heater or wait until Spring. I wouldn't try to warm it in a day though. Frozen pipes that are thawed too quickly can break, leaving you with a real mess on your hands, possibly even structural damage to the property. All you need to do is get the temps above freezing, it doesn't need to be balmy. If you use an electric heater make sure it is well away from combustibles and the machine if possible. When water lines break they tend to spray where they want so keep that under consideration when placing the heater and make sure it's off the floor. If i started warming the room today i wouldn't even try to use the machine for a week. And i'd babysit it as much as humanly possible. Good luck.
Jan 24, 2013 | Maytag Washing Machines
Boiler losing pressure and overflow pipe dripping water
replace that leaking safety valve first
May 12, 2017 | Water Heaters
Steady yellow light
To reboot unplug the unit for 30 minutes. then plug back in. This may fix the problem, and try this link for troubleshooting PDF.http://homeappliance.manualsonline.com/manuals/mfg/bionaire/127176.html...
Apr 20, 2017 | Holmes Products BH3955-U Bionaire Utility...
Heater in Cabin in Colorado
Not a good idea, because if one malfunctions your whole log cabin will go up in smoke. Not sure if your homeowners insurance would compensate you for it either.
Get your HVAC system installed first so that you can set the thermostat temps to 60 F. Go down to Home Depot and buy heat tape to wrap around the pipes and plug them into an outlet. The heat tape has a thermometer on it that turns on the heat tape whenever the pipes get too cold. Also, leave the cabinet doors open underneath sinks so the room temperature can equalize.
Feb 24, 2010 | Heating & Cooling
Water line to heater is frozen. What do I do?
That will depend on how much is exposed to conditions/weather, that caused it to freeze. A good place to start is to heat valve and and piping that you suspect is frozen, with a hair dryer, or heat gun, if possible. Try to move it along entire area, rather than concentrate on one spot. Where it's located obviously will have a bearing on how you do it as well. Can you give a little description of how much pipe, etc., that you suspect is frozen, and where it located, as in access wise?
Jan 03, 2010 | Rinnai Webstone The isolator EXP tankless...
No heat in zone with Honeywell rth230B
It is not your thermostat, it is an airbound zone. The gurgly noise you heard was that water and air flowing through the radiator. The zone needs to be purged either at the boiler, or through vents on the radiator. Hope this helps
Nov 01, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
47 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
