Question about Tappan 24 in. Freestanding Gas Range Kitchen Range
No gas going to oven
I have a 1 yr old Tappan gas stove (not sure of model number off hand) where the oven is not working. It appears that it is not getting gas to the oven portion. The cooktop stove is working properly on all 4 burners. Don't see any wires or lines disconnected. Any ideas?
  • Tappan Master
  • 2,558 Answers
Hi blocked oven pilot , ffd not working oven burner blocked injector blocked
Posted on Feb 02, 2010
Gas Tappan oven will not power up after power outage
make this test and use the multimeter. God bless you
No power
Make sure there's power getting to your range, oven or cook top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
Nov 04, 2013 | Tappan Kitchen Ranges
TAPPAN MODEL 3 TGF367CFSA, GETTING A F3 CODE, OVEN DOES NOT WORK
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
Feb 07, 2010 | Tappan TGF364AS Gas Kitchen Range
OVEN PILOT WENT OUT
hopefully the gas smell isn't too strong and posing a hazard to you. If it is, reach behind the range and turn the valve until it is across the gas line and not parallel to it. You should be able to raise the top of the range from the front and see all the workings underneath. There you will find the pilot light.
Feb 14, 2009 | Tappan 24 in. Freestanding Gas Range...
Hello, Can't find model/serial number. Older Tappan custom gas stove. Burners work but oven does not. Told it has electric ignition that could be problem. Where to find it, how to remove, where to get...
Serial number labels are usually located in any one of a number of places -
Under the cooktop in one of the corners
Inside the oven door frame (not on the door)
Behind the bottom drawer pullout on the oven, left hand side
Oven back.
If this unit is anything less than 20 years old, there will be a label somewhere.
Reply back you findings and I can give you more information as to how to repair, and we can identify part numbers. You might also try www.repairclinic.com and see if you can drill down through parts when only knowing the manufacturer.
Jan 30, 2009 | Tappan TGF363 Gas Kitchen Range
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
Oven thermostat - schoenberger gas system 1975
Will need to find the correct model # somewhere on the range then go to www.appliancepartspros.com or www.www3.sears.com and you will find it there. I found thermostats on those sites for a model # close to yours and most likely the same one. Sears was about $72 and appliancepartspros was about $78. Hopes this helps.
Oct 08, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Jul 20, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan 24 in. Freestanding Gas Range Kitchen Range Logo
428 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
