Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
DD603I with custom front panels... leaking rinse agent dispenser
DD603I has leaking rinse agent dispenser.  This is the model where you use your own wood panels on the front and attach the little control panel to the wood.  Took the front off and found that the rinse agent container is cracked.  In addition we have been getting codes intermittently.  I had Sears come out and give an estimate which was $466.04.   The parts needed were  1 Kit Dispen at $91.11   1 Sub controll at $188.98.   1 Bung assy at $4.71.
This isn't brain surgery.  If I had a parts list I could replace these items.  Where can I buy parts?
  • 145 Answers
That's crazy! That dispenser is very easy to change, you just need a torx bit screwdiver.
try http://www.fisherpaykelparts.net
Posted on Dec 11, 2008
Rinse agent dispenser leaks won't allow to fill
If the dispenser is leaking, it's probably because of a faulty cap, or faulty or missing seal in the cap. And if you can't add any rinse-aid to the resevoir, It's probably full of water (which leaked in through the same faulty seal).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Mar 20, 2015 | Kenmore Dishwashers
Rinse agent (blue liquid) is leaking into the bottom of the dishwasher compartment. Every time I refill, it leaks out within a few days. Any idea what is causing this?
There is a lot of info missing like brand and model, but it a general way they all work the same. A preset amount is dispensed in the last rinse cycle by an electric circuit. Sense this appears to leak the entire amount the valve/ opening is not shutting. A repairman would just replace the rinse aid dispenser assembly. They are hard to clean because the are a molded/sealed assembly.
Dec 29, 2014 | Dishwashers
I have a 2 year old GE dishwasher that the rinse agent dispenser stays full & the product never comes out or works. My dishes come out clean, yet spotted.
If you are handy you could take the front panel aprt and see if the tube that connects to the selonoid to dispense at the proper time is plugged with crystallized chemical or it could be broke and just leaking out the door and into the bottom of the dishwasher.
Jul 25, 2014 | Dishwashers
White film left on the dishes after going through the dishwasher. Why?
Too much rinse agent. If you are using powder or gel, set pointer knob on rinse agent dispenser to a lower setting. If you were using the tablets, they have rinse agent built into them, and the additional rinse agent from the dispenser equals a double dose, so the film shows up. Stop using tablets until liquid rinse agent dispenser is empty.
Apr 14, 2011 | GE Dishwashers
I have an Ultra Wash II, 665.1675590 dishwasher that works like a charm, my only problem is that when I put a rinse agent in the rinse dispenser, the minute I close the door it all runs out. I can fill it...
  • 1 .Cut back on the amount of detergent used during the wash cycle. Sometimes this alone will solve your problem.
  • 2 Make sure the appliance is level by adjusting the front feet up or down.
  • 3. Take off the lower front panel and check the hoses for leaks.
  • please comment on this post stating how it help you with your dishwasher
  • Dec 21, 2010 | Kenmore Dishwashers
    DISHWASHER LEAKS FROM RINSE AGENT DISPENSER
    Replace the Dispenser,This is not a problem you let continue! There is a risk of electrical short that can occur .And can cause fire.Take the inside front door panel off.Remove rinse Aid container and replace it.
    Jun 08, 2008 | Whirlpool Dishwashers
    Rinse agent runs out
    Without the manufacturer and model number, it is very hard to help much. If this dishwasher is several years old, this may be the beginning of many, many problems so you may want to consider replacing the entire dishwasher.
    It you want to attempt a repair, you start with removing the door panel screws around and near the door gasket. When you get it open, take some pictures of what you see. Closeups to hep you reassemble.
    Zero in on the rinse agent dispenser reservoir and look for leaks. Identify what has failed and order either locally or on line.
    Good Luck!
    May 05, 2008 | GE 24 in. GSD3400G Built-in Dishwasher
    The only "fast" way is to remove the dispenser completely and rinse with warm water until clean! (by removing front panel and then disconnecting jumpers and clips...can be tricky to do alone, as you need 3 hands to pry clips from dispenser to remove from door!) Oshie.
    Sep 28, 2006 | Bosch 24 in. SHU43 Built-in Dishwasher
    Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
    668 people viewed this question
    Top Fisher and Paykel Dishwashers Experts
    Brian Coughlan
    Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
