Question about Frigidaire Dishwashers
Hi
The leak could be caused by a problem with the rinse dispenser or by a worn out corner seal. If the seal looks bad, dried out, etc., replace the seal. Otherwise, you'll need to take the door apart and see what's going on there.Some leaking around-under-from the door on dishwashers can be traced back to a split in the spray arm. If the lower spray arm develops a split in it, the spray arm can turn too fast, and shoot water directly at things that it is not suppose to spray water at....sprays water at the door vents or edges and
can create water leaks.
However a leak during drain usually indicated a leaking drain hose. Pull the machine out from under the counter and remove the left side panel exposing the blue float assembly. Turn the machine on and observe the fill cycle. If water comes out anywhere on the fill mechanism then the inlet valve needs to be replaced. Once the machine has filled and begun to cycle cancel the program and drain the unit. Observe closely where the leak is happening.
Check this usefull bellow link thoroughly,you will be helpfull
http://www.the-appliance-clinic.com/dishwasher.html
Thanks for contacting fixya.com
Posted on Feb 02, 2010
Jul 30, 2010 | Washing Machines
Sep 10, 2017 | Frigidaire Refrigerators
Mar 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Jun 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Apr 04, 2009 | LG WM2277HBW XL Front Load Stackable...
Nov 08, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Sep 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Nov 16, 2007 | Maytag MAV7600 Top Load Washer
Feb 05, 2007 | Bosch SHU9915UC Dishwasher
Jun 11, 2006 | Hotpoint 24 in. FDW60 Free-standing...
Dec 12, 2017 | Frigidaire Dishwashers
