Question about Music
The response I got gave me a place to start however after hours of searching the internet I am unable to locate the capacitors I need. Who sells exact replacement capacitors for this '67 fender super reverb? Are there new versions that are compatible? Also where can I get a picture of the inside components to see if someone before me put in something wrong? I found one site that had a nice photo of the guts on a deluxe reverb, but it's alot different than a super reverb. The internet has not been very helpful in these regards, yet.
  • Music Master
  • 5,603 Answers
Try this site if you have not already:
http://www.tubesandmore.com/
Posted on Feb 02, 2010
Testimonial: "Thank you very much for your help. That site looks like they have everything I need, for now. You have been most helpful. Thanks again."
Yamaha P-70 digital piano. A few keys are making a loud knocking noise. The note still sounds, but the knocking noise on the few keys can be heard at the other end of the house
There's an extremely comprehensive pair of videos about repairing this problem on YouTube thanks to David Allyn. I have embedded them below, or you can search "P70 Noisy Keyboard Repair".
Jan 03, 2014 | Yamaha NP 30 76 Key Lightweight Digital...
Korg M50 keeps freezing up how to fix took it to repair and it still does it
Well looks like you have a capacitors problem. I had this problem too and a friend soldered two new capacitors in place. You can find information on the korg forum but most important is to know where the capacitors are located
http://www.korgforums.com/forum/phpBB2/viewtopic.php?t=92395
Dec 07, 2012 | Korg M50 61-Key Music Workstation Keyboard...
Replace broken hammer key on roland kr 575
I've actually repaired two broken hammer keys on my Roland KR-575, after paying $250 (TWICE) for a repairman to come to my house and fix two other keys.
The repair I completed was about four of five years ago. I searched the internet and found great instructions to print out. Unfortunately, I can't find them again. HOWEVER, I did find this video: Roland Keyboard Repair. It shows you the hardest thing about the repair - how to take the cover(s) off to get to the keys! The video is not as detailed as the instructions I used before - but pretty good. The parts cost me about $25.
Unfortunately (for me) I have yet another key to fix now. This time I will take pictures and notes and update here with my results. It might take several weeks though (I'm trying to finish a big school project). In the mean time, try the video. I don't recommend trying super-glue like the video says, but sometimes finding parts is difficult, so I guess that might be an option if you couldn't get the parts easily. I just don't think a weight repaired with super glue will last very long.
Here are a few suggestions to find the parts you will need:
My other advice is to keep careful track of all the different screws you take out - and away from kids, grandkids, and pets - so you can put them back in the right place after your key repair is finished. (The screws that is ;)
Apr 22, 2012 | Roland Music
Soundcraft GIGRAC 600 pre-amp power supply keep blowing the low valve resistor 1ohm. they are the resistor just before the bridge rectifier, for the low voltage feed. Once resistors replaced the unit...
The resistor is acting as a fuse and will continue to blow until you fix the REAL problem. LIKELY the filter capacitor(s) beyond the bridge rectifier are failing. One needs to use test equipment to measure the current through the resistor and see if it is reasonable. The capacitors can heal briefly and then start to short. One should also check the rectifier in operation with an oscilloscope as one diode could intermittently short.
May 04, 2011 | Soundcraft Gigrac 600 Powered Mixer
Need a capasitor for crossover
Find them at Digikey.com. Search first for "Capacitor" then select "Non-Polar"
HOWEVER there is a part that LOOKS like a ceramic capacitor but it is NOT. It is a "polyswitch" which is a resettable fuse. Go to the Digikey.com site and search for "Polyswitch". Then select 60 volt in the filter and Radial... see if you can find the item. Also consider opening a second speaker if you have it to get the number off one that is still OK. This is part of a protection circuit and needs to be replaced with exact device.
Dec 29, 2010 | Peavey SP2 PA Passive Speaker
I have a piano Kurzweil model EG 20 i would like to sell, i dont know how much to sell it for.
Search Ebay completed items for same model or similar to see what they sell for at auction.
Nov 16, 2010 | Yamaha NP 30 76 Key Lightweight Digital...
Amp volume drop with flabby bass sound.
1) can happen if the speaker is dying - voice coil defective or magnet needs recharging. happens sometimes with low quality speakers.
2) faulty pre-amp section can reduce overall gain resulting in lower output volume.
3) for old amps dry solders in pre-amp & power amp section can have the same effect.
4) faulty coupling and filter capacitors can severely effect frequency response too.
Mar 13, 2010 | Fender Hot Rod Deluxe Guitar Combo...
The plastic bolt that hold the input in place has fallen off
You'll have to remove the amp chassis from the cabinet to get at it. I only came online again today the 27th so I'm sorry I was probably too late to help.Make sure you don't touch anything around the power supply as the capacitors retain a large charge. To partially discharge them, unplug your amp from the wall while it is on and set at low volume levels. Hope I helped.
Nov 26, 2009 | Line 6 Spider Iii 120 Stereo Guitar Combo...
I have a Wurlizer Digital Home Organ that suddenly quit working...no sound at all, but when you turn it off, it makes a ''puffing'' sound. (Sounds like bellows aren't working). I cannot find anyone in the...
Hello there:
on the back of the organ if you remove the back of it and look to the left side there will be a set of fuses that control different features of the organ
there is also capacitors that sit further in the organ so you may want to check them out too there is a wiring diagram on the inside of the back cover this will help you determine what size fuse may be needed
There used to be a piano and organ shop that was located in tyler i dont know if they are still there i live here in dangerfield which is located in northeast texas and i have a dealer here but i dont know if they would do you any good being that far away.
I will post a comment tommorow when they are open to see if they can give me a closer dealer for you ok it is called the music connection so you may want to search the internet for this site ok
best regards michael
Oct 25, 2009 | Music
Channel one doesn't work
The 12AT7 is usually the driver tube for the tubes before it ( the input channels ). It can also be the driver for the reverb or tremelo channel. I'm not sure what model of amp you have or the manufacturer but there are plenty of places to look on the internet for info. http://duncanamps.com/index.htm is a good place to start. If you can't find the schematic for your amp try and find one that is similar to give you some ideas. If you don't have the basic tools like a volt/ohm meter and a capacitance tester. You might have to consider a pro to look at it. You will be looking for resistors and capacitors in the same circuit as the tubes that you originally mixed up. If its a hybrid solid state/ tube amp you will also need a transistor tester. Of course good soldering abilities are necessary and ABSOLUTELY do not work on the amp while it is plugged in and make sure you properly discharge the filter capacitors in a safe and proper manner before touching the circuit. All the info you need to sucessfully do it yourself is available at the library or on the net as long as you are confident in your abilities and first and foremost work in an absolutely informed and safe manner. Hope this helps.
Jul 15, 2009 | Music
Music Logo
62 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
