Question about HP Photosmart M425 Digital Camera (5MP, 3x, 1.7 ) Commercial Channel only
Power button isnt working..how do i get the photos
Powerr button isnt worling..how do i get the photos off the camera without pressing the power button
    President:
  • 1,564 Answers
You might try removing the storage/memory card and insert it into your printer or computer.
Posted on Feb 02, 2010
I have a Philips PhotoFrame - SPF3408/G7 (SPF3408T/G7). When plugged in no picture comes on screen. Screen does not light up. I viewed pictures yesterday - but - I don't get anything today. I know...
Keep in mind that Digital Photo Frame can display the same photo continuously for 1000 hours without any damage to the LCD screen.
If you can enter to the settitgn menu, first make sure the system is properly powered. Then use a pin to trigger the reset button located on the side of the power button on the back to restore the system...
If this isnt work try...
  1. Load all the photos you want to upload to the Photo Frame in the root directory of your memory card.
  2. Power off your Photo Frame by pressing the Power button.
  3. Insert the memory card into the slot in the frame.
    A For a Compact Flash card, firmly slide card in the larger slot end first and face down.
    B For an xD, SD, MMC, or Memory Stick card slide card in the smaller slot end first and face up until it locks into place.
  1. Restart Photo Frame by pressing the Power button.
  2. After a few seconds, all photos in the root directory of the memory card will be automatically added to Photo Frame. The root directory on memory card will not be emptied after this operation.
    Please do not remove the memory card just after inserting it in Photo Frame or when Photo Frame is counting the Photo.
    Wait until the screen is stable.
    NOTE: This operation does not apply to photos in sub-directories.
If anyone of this procedures work fine, I suggest contact your local service (check if even is underwarranty).
Good luck.
Jul 05, 2011 | Video Game Consoles & Games
My sony DSC H10 cameras flash isnt working what could it be?
If the flash is not functioning, then the Camera flash may be turned off or ot is set to Auto and will only flash when the taking pictures in poorly lit environments. To turn on the flash so it works regardless of the lighting conditions, press the flash button on the Camera until the Forced Flash icon appears on the LCD screen. The flash button on the Camera has a lightning bolt symbol on it.
If the Forced Flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting it enabled, the flash will still not work in the following settings.
When shooting movies.
When shooting in the Twilight or Handheld Twilight mode.
When shooting with the Burst or Multi Burst mode.
Shooting with the Fireworks or high sensitivity mode. (ISO)
Following the above steps should resolve the issue. However, if the issue persists try resetting the Camera back to factory settings and specifications.
Try power resetting the Camera to check if it resolves the issue. To power reset the Camera, turn off the Camera and remove the battery pack. Press and hold the power button for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery.
This should resolve the issue.
Thanks for using FixYa.
Jan 27, 2011 | Cameras
2 problems. I have the Coolpix L100. Sometimes my photos are blurry and also. there is a delay when I snap a photo which isnt good when trying to get action photos.
With autofocus digital cameras, blurred photos are almost always a result of camera shake. You need to hold the camera still even after pressing the button, as there is often a short delay before the shutter fires.
Many digital cameras have a two-stage shutter press- first pressure causes the camera to focus, then the follow through pressure takes the picture. If you are rushing this, you may get unfocussed shots.
If you take lots of action pictures, you will have to work on a technique of partially pressing the shutter to get focus in anticipation of the shot (perhaps focussing on where the action will occur), then holding it part-pressed until the moment you want to capture. This is really no more of a problem than setting an anticipatory focus on a manual focussing film camera use to be. Some more complex digital cameras will allow you to turn off auto focus and focus manually.
Nov 05, 2010 | Nikon COOLPIX L100 Digital Camera
My canon rebel xti will not turn on, I have recharged batter and bought a new one and charged that. I put them in and it still will not turn on. I also cleaned the connection inside the camea.
Give the camerra some light taps as you are putting it on by pressing the powerr button. If there is no action the fault is internal and must be checked. Since the camera spares are not regularily available, it is most ideal to get the camera checked and estimated at Canon. This is bettter as the delicate mechanism is not meant without experience.
Sep 20, 2010 | Canon EOS Digital Rebel XTI Digital Camera
Canon PowerShot A480 won't take photo. Pressing on button camera on then pressing silver button to take photo when pressed down screen turns black no picture taken. Batteries new. This is the story; camera...
its just a matter of batteries...some are not powerful enough to operate the camera ....Try to change them and buy some real good ones..like Duracell or Tatra...do not make any compromises when buy the batteries...get the best cause these kinda cameras really require powerful ones...or ...try to get a set of rechargeable ...
Jun 20, 2010 | Canon Powershot A480 - Silver Digital...
Conputer won't power on
Hi there.
Remove the power adapter and the battery, plug in AC power and hit the on/off button, if it powers up wait for the OS to load up and the shut it down again, put the laptop battery back in and power it up.
post back with the results please
Good luck and thanks for using Fixya!!
Feb 23, 2009 | Dell Inspiron 8600 Notebook
Lens error
This can work with CoolPix S10
1) Remove battery.
2) Replace Battery (Insure it is fully charged)
3) Press the Shooting/Preview button and keep pressing it while you press the power on button. This tells the camera to go into PREVIEW MODE without checking the lens. See if you can preview a few photos and that it works in preview - If it does NOT I cannot help you here.
4) If the Camera Works in Preview mode then press the Shooting/Preview button to put it back into "Take Photo Mode".
5) There can be a delay but it starts up without the lens error.
6) Make sure the ZOOM IN and OUT works and in most cases if the lens operates then you can take a photo. If the Zoom in and Out does not work you have a jammed lens.
7) If the LENS is Jammed AND it is OUT of warranty you 'might' want to tap the lens barrel against your palm. I have found when you remove the battery you can gently tap the lens into telephoto mode by tapping the back of lens assembly into your palm.
May 28, 2008 | Nikon COOLPIX S10 Digital Camera
Reading lens error on nikoncoolpix l12
Hitting camera on desk once has partial fix.
When camera's batteries taken out & then put back in and the power on button pressed to switch camera on, the lens extends out & the camera now works.
BUT when the power button pressed to switch camera off the lens retracts AND a "Lens Error" msg appears on the LCD screen.
Just have to take batteries out to remove msg & start again as above but WITHOUT hitting the camera.
Thanks
Feb 07, 2008 | Nikon COOLPIX L4 Digital Camera
HP Photosmart M425 Digital Camera (5MP, 3x, 1.7 ) Commercial Channel only Logo
35 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
