Question about Mitsubishi WS-65809 65" Rear Projection Television
Distorted picture that curves up at the bottom of the screen
I have an 8 year old Mitsubishi WS-65809 HDTV. Over the past few months when the set is initially turned on, the picture is distorted. The picture curves up at the bottom. Earlier it didn't take long before the picture returned to normal and stayed. Now it remains distorted as long as the set is on. Are my rear projection bulbs going bad or is it the intermittent connection on my convergence IC?
Thanks in advance for your assistance,
Dane
    Problem Solver:
  • 12 Answers
I also ordered the kit from Tvrepairkits.com for this TV. The colors would all separate about 2 inches apart so I would have a red person, blue person and a green person! I'd have to whack the tv to get it to stop for awhile. The IC's fixed the tv, but in my case the chips did not have to be replaced, only re soldered after coming loose. I put the new chips in anyway. Most convergence problems for this TV are cause by the IC chips either coming loose, or going bad. More specifically, They become loose, then go bad after time if they're not reattached. I've seen others with a bowing problem similar to yours and were able to fix it with this kit. If your going to attempt to do the repair, Make sure you get the right Wattage soldering iron, as too high will damage your board. I think I used a 40-watt, but that may be too high to recommend. I also suggest practicing your soldering skills on a blank circuit board before attempting the repair. Radioshack has them for like $1. Get some heatsinks or something cheap to solder to the board. I believe the Instructions you get tell you this also. I did so and learned to solder in about 25 minutes. FYI: The expensive board in the TV is much easier to solder to than the cheap stuff, so if you can get it perfect on the practice run, your golden.
Posted on May 16, 2010
My 9 years old Mitsubishi WS-55857 had the same problem (distorted pictures) for couple of months and I was about to buy a new plasma TV. But, I found TvRepairKits.com and I decided to give a try before buying a new TV. I received a convergence repair kit in two days with web site info for detailed instructions with many picutres to explain the process. When I had questions and Ed was very prompt to answer my questions thru the e-mail. I never done solding before, but I am moderate handy person. I spent less than $100 and three hours and my TV picutre looks stunning. I went thru advanced convergence process after I repalced the convergence chips and replaced RCA video cable with better quality and my TV picture looks as good as brand new. Thansk ED for your help! From Portland Oregon
Posted on May 13, 2010
WS-65809 no picture convergance
Model indicated uses two of the stk-392-570 chips--both will have to be replaced (under 20 dollars from Suburban electronics).
I have start to finish instructions for this repair in this set.
Average life is 5-8 years.
The set seems to have another issue that may or may not be related--there is a hidden menu with the OPTION menu in it--allows a hard reset of the entire set--ought to cure the no picture on several inputs---either one very odd problem or two problems.
Apr 22, 2012 | Mitsubishi WS-65809 65" Rear Projection...
For past 6 Months The scren was bowing Horizontally and now it has sever ghosting.. What to do this TV is about 8 years old Model Number WS-65807
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 24, 2010 | Mitsubishi WS-65807 65" Rear Projection...
SCREEN HAS VARIES RED -BLUE-WHITE- LINE SHOWING, I TRIED USE THE
It needs to be repaired by having the convergence ICs replaced or resoldered (if intermittent).
Parts are STK 392-570. Be sure to use thermal paste on the ICs.
Jul 02, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Tv wont turn on its a mitsubishi wide screen model number WS-65809. also forgot password for parental locks so when it is on cant watch anything but Disney, and Nickalodian!!!
I can help you unlock your Mitsubishi HDTV V-Chip at least, for when you get it back on.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Mar 13, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Picture Problem
I have the same situation. Called my repairman, who knew exactly that it needed a "570 kit" . It will be repaired this week. Cost $360
Sep 26, 2008 | Mitsubishi WS-65809 65" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Screen is distorted on the top and bottom
Loose connection on convergence board, you could tapp and should go back to normal, find loose conn. and solder back.
Sep 09, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
363 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
