Question about Westinghouse LCM-19v1 Monitor
Monitor Brightness Need to know how to dim monitor? 22" Model #LCM 22w2
Nacesito fuente de alimentacion para monitor westinghouse modelo lcm-22w2
Posted on Jul 14, 2012
  • 3 Answers
Most user manuals for these moniters you can get on line (free downloads)
it will explain how to use the buttons on your monitor
Posted on Dec 17, 2011
Trying to program my Westinghouse LCM-22w2 ComputerMonitor/TV with my AT&T U-Verse Remote Control. What's the code?
There is no tuner in the monitor, it only works as a TV with a tuner added. The remote would work with the tuner, not the monitor !
Dec 11, 2010 | Westinghouse LCM-22w2 Television
What and how much is a power supply board for the westington lcm-22w2 monitor. my tv went out i took it apart checked the circutry to me doesnt look like anythings rong. dont know what the caps are the...
Check here: <a href="http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LCM-22W2">http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LCM-22W2</a><br /> <br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">If you are going to DIY and have proper tools and know safety precaution then please read on:</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: <a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Post back what you see inside so we can guide you further and it will help out other people in the future also.</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a><span style="mso-tab-count: 1"> </span></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <span style="mso-spacerun: yes"> </span><a href="http://lcdalternatives.auctivacommerce.com/">http://lcdalternatives.auctivacommerce.com/</a><span style="mso-spacerun: yes"> </span>he can make you a set of caps for you.</span><br />
Aug 26, 2010 | Westinghouse Electric LCM-22W2 Monitor
My LCM-22w2 monitor will now rarely start up. It powers up white-screen and won't do anything. Occasionally it powers up ok and works fine.
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 10, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
My LCM-22w2 monitor will now rarely start up. It powers up white-screen and won't do anything. Occasionally it powers up OK and works fine.
wford451, You should open up the unit and inspect the "switch-mode-power-supply"/"CCFL inverter supply" printed circuit board for the common 2 problems that create symptoms like yours. Do some reading in my and other CCFL back-lit lcd monitor technicians fixya profiles. They are loaded with solutions to fix your unit. Your LCM 22W2 is no different than any other brand in it's basic design and operation!!! 12fixlouie
Mar 17, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
LCM-22w3 monitor suddenly changed colors. All
Try adjusting the monitor cable that goes from your monitor to the back of your computer.
Jul 10, 2009 | Westinghouse Electric LCM-22W2 Monitor
I think I also have a bad power board.
Could be a bad fuse in the powerboard,ore look for bad caps...
Jun 09, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Can't remove cover of Westinghouse LCM-22w2 monitor
Hey Ed,
I hope I can help, It doesn't open from the back, it opens from the front.... carefully! There are four support screws, which hold the LCD screen to the desk stand,after removing all the support screws (4) on the back under the support stand cover.(which pull up to remove) (Remember! the whole case and face frame is plastic, so take your time). Work to separate the black face frame around the LCD from the silver case. Its held together by small plastic clips on the face frame to the wall on the LCD case. Start at one of the corners and slowly pry the face frame and silver case apart. (separate it inch by inch, work your way around the case carefully. If one corner doesn't give, go to another side.
Putting back together works reverse, the face frame and the case snap back together, Carefully! And replace screws (4).
Russell
P.S. I have three LCD models from Westinghouse, LCM-22w2, L2210NW and the L1916HW. They all open the same way.
Dec 07, 2008 | Westinghouse 22" Widescreen LCD Flat Panel...
Westinghouse LCM-19v1 Monitor Logo
126 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
cxbxr_3
cxbxr_3
Level 1 Expert
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
