Question about Canon imagePROGRAF W6400 InkJet Printer
Error Code E0200D
What does this code mean and how can we solve it?
  • 1 more comment
  • joelbub Apr 12, 2008
    I get the same message when loading cut media. The print manager says that the printer is not connected to the my G5 Imac.
    HELP!
  • hassled Jun 06, 2008
    Every time we load a new roll of paper we get this error. Eventually, the plotter will work. But it is a major hassle.
  • matteomatteo Jun 17, 2008
    Any time I turn the printer on I get the E0200D error code "size undetected", no matter the size of the sheet. As all I need is just a sample to show me the thing is working, it is supposed to work offline with this, so it is definitely not a problem of connection or software. What can I do??
I had this same problem with my imagePrograf 6400. The error was occuring because I had not properly seated the paper on the paper holder core. It was pushed all the way onto the holder (1/8th of an inch was all it took). Once I made this correction everything worked properly
Posted on Oct 27, 2009
I think making sure the paper is properly aligned fixes that problem. I get it once in awhile.
Posted on Jun 29, 2008
  • lynax440 Mar 17, 2011
    The best solution for this problem is to unplugg the 220 volt power cord to reset the memory inside the machine...I did it today and it worked properly.
I was trying to load a roll but had presses the cut sheet button instead. When I pressed the roll button, the error message went away.
Posted on Oct 23, 2008
This is displayed when the feed sensor could not detect the roll media even after feeding the prescribed length during loading of the roll media
paper path, roll drive unit, feed sensor, engine controller, system controller
visual check
feed sensor
cable connection
replace engine controller
replace system controller
Posted on Mar 27, 2008
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
What is error code no. F6E5 mean in Whirlpool Dishwasher (ADP 6776), and how to solve this problem?!
The error code F6E5 means "Cancel key error". Press the "Cancel" and "Start" keys in the following order: CANCEL, CANCEL, START. Verify the error code displayed on the control by observing for longer then 1 minute. If the error persists, the display board has to be replaced.
Sep 27, 2013 | Dishwashers
1313 error code
Error Code 1313
System error code 1313 means "A specified privilege does not exist." This error code may also display as "ERROR_NO_SUCH_PRIVILEGE" or as the value 0x521.
I found this page for solve your problem "http://wefixerrors.com/error-code/error-1313.html"
Mar 24, 2013 | ASUS Computers & Internet
Sc107 code error in aficio700
The error SC107 means Lamp regulator malfunction.The possible are
--Lamp regulator defective(Pcb)
--Exposure lamp open
--Optics thermoswitch open
--Scanner control board defective or poor connection
This is a very old machine so I hope you have some luck solving the problem
Sep 06, 2012 | Office Equipment & Supplies
E5 error code on sportcraft tx400 treadmill
E5 erorr code for my gait keeper treadmill ,it starts up after few seconds ,it stops
and error code appear.Can you tell me what this means? How to solve this problems?
Nov 24, 2011 | Exercise & Fitness
How to solve Error Code E02 always appear
Error Code E02 means paper jam.
Solution
1. Unplug the power cord and USB cable.
2. Lift the printer upside down, then shake the printer.
3. This is done, to remove foreign objects, which get into the roller.
Causes of damage
Solution
Oct 27, 2011 | Office Equipment & Supplies
Error code E0200D Have powered off and on says size undetected - any suggestions
danieljudge Thank you!!! You were right! Problem solved. I managed to see that was the problem but didn't know how to change the sheet with the roll. Thanks again!!
Nov 24, 2010 | Canon imagePROGRAF W6400 InkJet Printer
ERRORE E0200D plotter canon W7200
Hi. I have a problem printing the bar code symbol is similar to
Oct 07, 2010 | Canon imagePROGRAF W8400 InkJet Printer
Open Questions:
See all Canon imagePROGRAF W6400 InkJet Printer Questions
Canon imagePROGRAF W6400 InkJet Printer Logo
2,543 people viewed this question
old marine
old marine
