The light for my htd 501 lamp indercator came on to change lamp I have done this but tv is not starting up and is saying same problem any ideas on what the problem may be please
  • 476 Answers
While reading up on some solutions the problem you encounter I came across a previous post that might give you some help, depending on how much work are you willing to do to possibly correct the problem(this may not work for your tv) but it very close to the problem you're describing, the post is found here: http://www.fixya.com/support/t468925-sagem_dlp_htd_501
Posted on Feb 02, 2010
How do i change side bulb in mitsubishi space wagon
Mitsubishi change side lamp bulb mitsubishi space wagon ...
www.fixya.com > ... > change side lamp bulb mitsubishi space wagon
Change side lamp bulb Mitsubishi space wagon related problems. Ask your Change side lamp bulb Mitsubishi space wagon questions. Get free help, advice ...
Mitsubishi Space Wagon 91 98 Sidelight Bulbs W5W 501 ...
www.ebay.com > ... > External Lights & Indicators > Bulbs & LEDs
eBayProduct Type: Sidelight. Operates: Sidelight. Further Information: These bulbs are a direct replacement for any W5W 5W (501) wedge bulb no matter what brand.
Nov 26, 2015 | Mitsubishi Cars & Trucks
Should I replace my lamp for my Panasonic 1080i htd t.v. pt-50LC14
Replacing a lamp won't work. There is not even one lamp in your TV. I'm afraid the lightening has done more damage than can be repaired. Even when some tech manages to repair te error, the TV can have the next error in days or weeks.
Try reading something about ESD. Electro Static Discharge and what it does to electronics. Electrostatic discharge
Apr 25, 2015 | Panasonic Televison & Video
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
Lamp went out on DLP TV
Did you replace the lamp door? A flashing red light is an indication of a door open or an impropely seated lamp. Try removing the lamp and reseating it. Reinstall the door and try turning it on again. Also, you may want to unplug the TV from the power source, count to about 20 and then plug it back up again. This may reset the TV.
Good luck
Aug 09, 2009 | Hitachi Televison & Video
My Sagem DLP HTD 501, recently came up with a warning light error,too replace the lamp,and subsequently blew.I replaced the lamp,but still have the same problem,with the screen dead and the warning light...
Ok...this is only a theory. Did u replace bulb..or lamp unit?
To cut along story short the tv has a timing device in it set to about 8000 hours. When u look at a picture (google) of the new replacement lamp unit, there is an additional circuit board on the housing, this aligns to two tiny contacts inside the tv. (you can see it when u look inside the socket. its green and about 10mm by 20mm and labeled lamp saftey). this circuit board (on the lamp unit) is absent on the one that comes with a new htd501. I believe the replacement lamp housings circuit board is a 500Ma fuse, which momentarily sends a current to reset the timing device then immediately blows, leaving your timing device reset to 0hrs.
As i say this is only theory based on reading other materials online, however my friend has this problem and i am waiting for him to give me the go-ahead and try it.
What I will do is make a plasic board with bean tin contacts aligned to the contacts inside the tv, and solder a fuse housing to the home made contacts and use a 500ma fuse. this should reset the timer!!
I cannot guarantee or even recomend this unless u r sure and confident about making the above gadget. however i will return to this page and tell u if i was successful in a week or two.
Mar 26, 2008 | Televison & Video
TV does not come on
Similar problem with my Sony. Unplug for 36 hours from the wall and it fixed my problem
Dec 16, 2007 | Mitsubishi WD-62528 62 in. LCD Television
Tv turns off then on then off then on
I Just had the same problem. Had the LAMP changed work fine now. Just had it done today
Oct 24, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
PT-45LC12 wont power up
You have a bad lamp. The "clicking" sound you hear is the ballast (lamp power supply) attempting to start the lamp. The warning on Panasonics that comes up on screen does so when the life expectancy of the lamp is approaching. Otherwise your "clicking" sound and the red light on front are saying bad lamp. When you replace the lamp remeber to follow the instruction that Panasinc provides with the new lamp on restetting the lamp timer. This is usually done with the volume down on the TV and the PIP button on the remote.
Feb 26, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
