Problem in display
My poratle hard disk drive is not displyed in my computer...
It needs a drive letter assigned! if you don't know how to do this yourself you should definantly call Microsoft. 1-800-microsoft. They can help you do that. Another quick thing to do is check to see if the device is being listed under device manager... It could be a conflicting driver. To get to device manager right click on the my computer icon either on your desktop or in the start menu. then click on the hardware tab then click on device manager, locate Disk Drives, click on the + next to disk drives see if there is more then one drive listed there ( if there is only one, it is likely to be your regular Master hard drive) if you see a yellow exclaimation point you will have to uninstall the driver that has the conflict and reinstall it. I hope this helped a little bit!
Posted on Feb 19, 2008
I have samsung NM0802 hard disk drive. it is not working displayed in my computer.
When the hard disk is not displayed this usually means the hard disk hasfailed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Aug 19, 2011 | Computers & Internet
After instal a pendrive in cpu it doesnot disply in my computer & doesnot flash is working
Did you go to my computer,,thats how you open or find a flash drive,,hit my computer and it should be there removible disk,,,if not try pluging it in and restarting computer,,also try wesite of the usb to see if any updates or u may need new driver,,but I never had any flash drive do that so,,could be faulty or went bad,,tap it on a hard surface a few times ,,could free the disk,,it works eith seized hdds ,,so,,goodluck
Nov 20, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I just got a 250GB Iomega eGo external hard drive and my Vista laptop will not recognize it in my computer but it is displayed as a mass storage device in device manager. I tried to update drivers through...
You may assign a drive letter to it by going to Start
  • right click computer
  • Select Manage
  • Go to disk management
  • select the drive It may be displayed as Disk 1 or Disk 2 (depends on your confug)
  • Change Drive Letter
  • Assign a Drive Letter
  • It should display on your computer
  • If you have not data on it, you may format it by going to Start and
    • Select Manage
    • right click on the drive and select format it.
    Oct 30, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
    Laptop powers on disk light flickers & does not start up. The fan is working.Blank screen, when connected to external screen still no output
    upon turning the computer on keep hitting the F8 key and see if a repair screen appears. If not the hard drive is gone or the disply is at fault
    Aug 02, 2010 | Compaq Presario CQ60-220US PC Laptop
    Xp installation problem
    “No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive) The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
    After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
    Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
    Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
    Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
    If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
    If it is ok , Please vote for me...!!!!
    May 31, 2010 | Computers & Internet
    Dell latitude D610
    This fault usually means the hard disk has failed or the disk controller, in most cases it is the hard disk that has failed.
    Check the BIOS settings and see if the hard disk is detected, if not it is probably a faulty hard disk.
    When you boot up the computer does the hard disk LED light flash and can you hear the hard disk spin up. If the hard disk is making a clicking noise then it is definitely faulty.
    To test the hard disk another way, remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If this computer cannot detect this as an external hard drive and you can't open the folders and files, this confirms it as faulty.
    To get the computer operational again, you need a new hard drive, Install Windows on the new hard drive with the computer's device drivers and your programs.
    Sep 05, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
    Pc problem at booting level
    try to remove the hard disk and see may be it will boot,
    the real problem is the hard drive
    May 30, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
    LG LS50 SCREEN WILL NOT TURN ON
    you need to resit your ram if the problem is not solved then your display adapter is gone, you have to send it for repair
    May 19, 2008 | Computers & Internet
    Open Questions:
    Steps To Fix Toshiba Laptop virus and Freezes Issue Call toll free Number :+1888784-9316 Are you facing sudden pop-ups on your computer or witnessing slow loading of files and programs? If you are getting issues like slow internet and processing, unexpected computer behavior then contact Toshiba support for making your computer free from all such dangerous online threats. Toshiba support provides safe and secure removal of all virus and other infections along with protecting the system from any such instances further. Toshiba support providing technicians make sure that your pc is secure and also that all your important files and documents are safe from any type of harm. If your system is infected with viruses, Trojans or malware then it might show signs like slow computer processing and internet speed, unexpected computer behavior, sudden freezing and crashing down of the system, frequent arrival of error messages, many advertisement pop-ups, non-intended outgoing emails and messages to contacts, files disappearing, problems in hardware and accessory devices, screen freezing and image blurring issue etc. Toshiba support helps in scanning all the variants of virus inhibiting the system by using proper scanning process and removal processes after that. Many a times, user while scanning viruses on his system might not be able to remove all even after many attempts. This happens because system gets infected to new variant of virus due to vulnerabilities of programs used in that system or because of inefficient scanning methods. The anti-virus program used for scanning the presence of that virus might not have got that virus's signature. So, for proper and efficient scanning of all viruses and removal afterwards, it is necessary to take help from experts like Toshiba support technicians. These technicians utilize the efficiency of advanced techniques and much better tools to clean the system and make it infection proof in order to yield greater productivity. Specialists of Toshiba support collect samples of all the variants of new and recent viruses and update the user's software database with their signatures. In case your system is also suffering from the infection of any such viruses which is new and is creating trouble getting detected, then contact Toshiba support us for help on their toll-free Toshiba customer helpline number +1888784-9316 anytime for expert supervision and advice.
    Aug 14, 2018 | Toshiba Computers & Internet
    Computers & Internet Logo
    51 people viewed this question
    Alun Cox
    David Payne
    David Payne
