Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Fault "change battery pack"
Camera says "change battery pack", so I put a new battery pack in and it still has same fault. I can review pics but not take many, if you take a pic the camera will turn off and say "change battery pack". Battery has been charged
  • dlandkathy Feb 02, 2010
    I don't know how you came up with that, I wasn't to sure about it, but it worked. Great job
    President:
  • 1,564 Answers
Take a cotton swab dampened, not soaked, in rubbing alcohol. Clean the contacts inside the battery compartment. Also clean the battery the same way. This should solve your problem. Thank you, Dana
Posted on Feb 02, 2010
Cannot take pictures thru lcd screen on d40x DSLR
The D40x is not capable of Liveview - i.e. looking at the LCD to take a picture. You are mistaken.
If you want Liveview, you need to buy the D3 or D300 cameras. The D40x is an entry-level camera.
Apr 04, 2009 | Nikon D40x Digital Camera
The camera does not show the digital display
CCD IMAGER failed !! if ur display is black in shoot mode and pics u take newones are also turn out to be black then it is called CCD failure
but u can call olympus for free replacement as many are doing the same it is a common fault and it is considered a manufac fault
see this
http://www.imaging-resource.com/badccds.html
just call them and insist on free repairs if u r out of warranty
pls rate me FIXYA for help
Apr 03, 2009 | Olympus FE-220 Digital Camera
Making noise when I turn it on
hi katie!
if u have dropped ur camera, then it is a mechanical fault. take it to the nearest service center.
u can remove your memoy card and put it in an media card reader and view ur pictures,
good luck!
Jan 02, 2009 | Canon PowerShot A520 Digital Camera
Canon 3000N Auto focus fault
No extra batteries.
Usually this is a lens fault as the focusing gear is all in the lens. Clicking sounds as if a rear pinion has cracked. It's not uncomon in the 'prosumer' level lenses where plastic gears are used a lot.
It's just possible the fault is which the auto-manual switch. This usually has a mechanical clutch coupled to it which physically disconnects the gearbox from the focusing ring, as well as operating a switch to tell the camera to turn off the AF system.
Dec 21, 2008 | Nikon F65 35mm SLR Camera
Casio EX-Z18
I have read on Amazon (in a customer review) that there is a known fault with Casio batteries. If the battery is fully discharged (i.e. when new!!!) it won't charge. The reviewer said a free replacement could be obtained from Casio? Either that or buy a new battery - about £6 I believe.
Nov 04, 2008 | Cameras
Having problem with my photosmart435digital camera
An electrical spike  from the battery probally you need to RMA it to HP
Oct 14, 2008 | HP Photosmart 435 & HP Photosmart 145...
Pwereshot A95 suddenly quit!!
This is Manufacturing defect.Canon will repair it free of cost.I had same problem and canon had repaired mine after warrnty period free.
Jul 06, 2008 | Canon PowerShot A95 Digital Camera
New camera won't work!
That message is probably because you have not saved any images in the camera's internal memory. Whatever pictures you took are on the SD card. Try taking a couple of pics using the SD card and try the review. If you are able to review, then all is well. If you cannot review, then one of 2 things:
1. Faulty SD card..Replace or format it.
2. Remove the SD card and take a pic. The pic will be saved in the camera's internal memory. If you still cant preview, probably a fault with the camera, and you'll need to service it.
Jun 02, 2008 | Kodak EasyShare C340 Digital Camera
S2 suddenly draining batteries rapidly
I have the same exact problem. I just now read a possible solution: try opening the battery compartment door and then closing it again to "trick" the camera into thinking it just got new batteries. There is definitely something wrong with the way the camera senses dead batteries.
Jul 28, 2007 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
239 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
