Question about Dishwashers
I have a portable GE Dishwasher that seems to be not doing its job like it used to, the dishes are not coming out very clean, What should be looking for?
    Problem Solver:
  • 10 Answers
You probably have a clogged filter. It's usually located in the sump area under the lower spray arm.
I cleaned mine (9 yr old Maytag) and it works like new. Debris like paper from labels, and sandy looking debris (I think coffee grounds) clogged my filter. Good luck!
Posted on Feb 04, 2010
Testimonial: "Thank you, Visually it appears to be clean, should this actually be remove for further inspection below? "
We have had this dishwasher for approximately 2 years. Dishes do not clean well. For example, I put a mixing bowl in that I just mixed brownie in--and the bowl did not come clean (simply a thick...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Mar 01, 2011 | GE Profile PDW8480JSS Built-in Dishwasher
Ge Triton dishwasher GSD5500GOOWW was not cleaning like it used to- I cleaned screens at back bottom-very dirty- also-detergent cup stuck opne - took door apart and got it unstuck - it works fine now. - it...
heatman101
Jan 23, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
When we open dishwasher theres standing water in the drain area and it smells bad this is after washing aload dishs look clean but inside stinks
After you run a load of dishes put 1cup of CLR or vinegar (white) and run a quick wash.no dishes,after running dishes clean out spray arm and clean strainer,use a rinse agent like finish, and spray off dishes before loading.About 35yrs. ago I use to be a dishwasher as one of my first job's and if you did'nt spray the dishes and scrap them off before loading,the dishes would not come out clean,And after each shift the dish washer would be cleaned out.
Aug 04, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Why do my dishes no longer seem to get clean? The glasses are spotty and foggy, small bits of food left on the plates, etc. They not completely dirty as they were when I put in to wash, but they're...
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
May 01, 2010 | General Electric GHDA480N Built-in...
Do these 'portable' dishwashers 'heat' water prior to washing? i have customer complaining bout the dishes not coming clean..yet the water entering the dishwasher is cold, does not appear to heat water...
Most dishwashers require a minimum 120 degree inlet water temp. The heating element will boost this up during the main wash cycle to aprox 140. Do not hook a dishwasher up to inlet water temps above 150.
Feb 06, 2010 | GE Hotpoint HDA3500N Dishwasher
GE Profile Dishwasher not cleaning - older PDW7880GOOSS
My GE Profile Dishwasher PDW8280N00SS wouldn't clean the dishes. I found what looked like plastic particles along with food particles in the wash arm spray holes. I found that heat had warped the gray flat filter in the bottom allowing food particles to bypass the filter, and I found that the flexible plastic sump inlet was disintegrating internally shedding plastic which clogged the filter to the pump and getting into the pump. This shouldn't happen. The material that the sump inlet is made out of is too soft and porous. I noticed other components in the wash water system made from the same white flexible rubber which is an unacceptable material. I bought replacement parts at a cost of $100 for both and this has solved the problem. What's distressing is that the replacement parts appear to be made of the same inferior plastic. And I have noticed upon closer inspection that additional interior parts appear to be heat damaged (warped). This dishwasher has been used less than 4 years and problems like these in a high end dishwasher are unacceptable.
Sep 15, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
Older portable dishwasher
nothing it needs a switching kit or drain solenoid kit rather
Dec 30, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dirty dishwasher
there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at www.dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
Sep 24, 2007 | GE 24 in. GLD5500L Built-in Dishwasher
Dishwashers Logo
73 people viewed this question
Top Dishwashers Experts
Owen Barnes
