Question about Kenmore 64802 Top Freezer Refrigerator
Reseting My fridge keeps going out, i hear there is a reset switch on it but cannot find it. Where is it? This is the third time its done it.
    President:
  • 1,564 Answers
The only reliable reset on a refridgerator is at the defrost switch. Remove the front bottom panel from your fridge and you'll see a small clockmotor with a couple wires leading to it. In the center of this you'll see a screwdriver slot. Turn the knob very slowly to the right(clockwise) until you hear a click, do not turn the slot counterclockwise. Once you've done this, check for cooling in the freezer part. It should take about five minutes till it starts to cool. If this solves your problem, than the defrost timer should be replaced. Thank you, Dana
Posted on Feb 02, 2010
I forgot my Password on My Emachine Laptop, I keep on Tapping f8 And it dosent do nothing
Forgot Windows password? It seems a terrible thing to hear that. As my personal experience, I think you need to make use of a third party to reset Windows password.
Before, I have used two of WindowsPassword Recovery Tool which did a big help for me. Now I want to share with u.
The first is Ophcack, a freeware. I should mention that it is not so easy to operate if you are not a professional.
The other is Windows Password Reset an easy-to-use and efficient tool with Windows password reset.
Jun 13, 2012 | Computers & Internet
Clock always resets when switch switched off and then need to reset it. is there any way of bypassing this clock. i done need it
no it is designed to stay switched on all the time by keep turning it off at the mains could damage your timer and then it wil not reset keep the main switch on all the time it will be ok the only time you switch off is for cleaning or a repair or you go on holiday
Sep 13, 2011 | Zanussi ZHQ575 Electric Double Oven
Does not overwrite old codes, just keeps accepting new ones. How can I clear all existing codes?
First, I fix this problem after an hour of try.
I conclude that this dorr lock is better that is appear. Is not a 2 codes door lock, it's a 3 codes one.. and the problem you have is the third code not reset. You can put the same code in each third emplacement. you have just to press the program button 3 time for the third code...
I determinate that I put the third code by error the was i program it the firs time.
I guide you...
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Jan 27, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
The original code will not clear from my Weiser lock electronic lock. I have entered multiple codes and the original still stays. How do I get the original to clear.
I guide you...
May 04, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Have a Rona electronic lock (Weiser) and the key works... will lock electronicly... but do not know the code... I have removed it from the door and replaced, but is there a way to reset the code?
I guide you...
Jan 23, 2010 | Weiser Lock Powerbolt 1000 Lock
The battery went dead in my 1995 jeep. I changed the battery. how can i reset the anti-theft system so I can get it started?
easy- close all doors, put key in drivers side door first, then lock/unlock 3 times, then go to passanger side, lock/unlock 3 times and thats it!
Sep 03, 2009 | 1995 Jeep Cherokee
Ps3 wont power all the way up
if you have moved your ps3 to a different tv or something, the video setting can get messed up, thus having to reset the video settings. here are a few steps to do so.
1. put your finger on the reset button and wait until the ps3 is in standby. (Keep holding your finger on it, don't let go)
2. turn off the ps3 completely by switching off the power switch (make sure your still holding your finger on the reset button)
3. turn your ps3 back on (while still holding the reset button) and you will hear a beep. keep holding the reset button until you hear a second beep. let go of the reset button as soon as you hear the second beep
this should reset the video of your ps3. ive done this to my ps3 before because when i was installing linux i almost screwed up my ps3. when i turned on my ps3 no picture or sound would appear. so i called sony and this is what they told me to do and it worked.
Jul 09, 2009 | Sony PS3 40GB Best Sellers Bundle Console
GE Model: GTS22KHPARBB Rerigator not working freezer working.
Look in the fresh food section (Fridge) and see if the cooling fan that blows cold air from the freezer is running, when the door switch is held closed, you might be able to feel and/or hear it while looking up at the "roof" of the fridge section.. Also, check the freezer section to make certain that you don't have food or boxes of frozen items blocking the vent that allows cold air to go from freezer into the fridge. Sometimes this is nothing more than an overstuffed freezer, which can lead to poor air circulation between the freezer and fridge. Another common problem is that when a overstuffed freezer section stays "stuffed" for a long time, (3-4 weeks), the air flow channel between the 2 sections can become frozen solid, thus preventing any air circulation. The fastest way to check for this and attempt to resolve this is to empty the entire fridge and freezer (into a ice chest/cooler, etc.) and allow the unit to defrost completely, but unplugging it and allowing both doors to stay open. Get some towels ready and wait at least 3-4 hours for a complete manual defrosting to occur. Good time to give the unit a cleaning while you're at it!
When done, close the doors and plug it back in and see if the freezer and fridge get to the proper temperature. You might want to reset the temperature controls to the factory defaults as sometimes people keep lowering the temp control trying to get things colder than they need to be.
Jul 07, 2009 | GE Refrigerators
My kindle keeps freezing
In most cases, to avoid freezing, keep battery charged and turn off wireless when it's not being used. To properly reset, hold power switch to the right for 15 seconds.
Resetting the device is not a bad thing, most electronic devices need it to be done. It can be annoying, but it's not fatal.
I would keep track of how many times you need to reset the device. Once the amount get over a few times per day, honestly, I would call Kindle Support. They've got the necessary software to look further into your Kindle.
Mar 11, 2009 | Amazon Kindle Wireless Reading Device
Air difusser between freezer and fridge will not stop running
When things like this happen I usually replace the main electronic circuit board which would control the motor operation timing, etc.
Nov 29, 2008 | Whirlpool Refrigerators
Kenmore 64802 Top Freezer Refrigerator Logo
95 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
